POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-beta.1 Server Time
22 Oct 2026 17:40:52 EDT (-0400)
  POV-Ray v3.8.0-beta.1 (Message 1 to 5 of 5)
Subject: POV-Ray v3.8.0-beta.1
Date: 11 Jul 2021 07:56:51
Message: <60eadc83$1@news.povray.org>
It's official now:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-beta.1
A note to Unix users:
We're now providing Unix-specific source code packages again. We
recommend that you build from the `povunix-*.tar.gz` tarball, rather
than the "Source code (tar.gz)" or "Source code (zip)" packages or the
raw repo contents.
A note to Windows XP users:
Let us know if there are still any of you out there. Otherwise we'll
presume that Vista (and higher) support should be enough for everybody.
Happy Testing!
Subject: Re: POV-Ray v3.8.0-beta.1
Date: 11 Jul 2021 09:00:00
Message: <web.60eaea21b74fb8af6adeaecb3f378f2@news.povray.org>
> It's official now:
> raw repo contents.
> Happy Testing!
A thousand thanks, though this deprives me of an excuse to further cleanup my
front end addon with the now uniformly supported stochastic AA !
The Doxygen 1700+ pages auto generated developer doc is insanely well formatted
Date: 11 Jul 2021 11:18:57
Message: <60eb0be1$1@news.povray.org>
Am 11.07.2021 um 14:54 schrieb Mr:
Credit for that goes almost entirely to the authors of Doxygen and the
toolchain for its PDF export. LaTeX may be key there, I guess.
Date: 11 Jul 2021 12:55:00
Message: <web.60eb21f4b74fb8af5e0fed26cde94f1@news.povray.org>
hi,
> It's official now:
> raw repo contents.
downloaded the 'povunix' as recommended, was surprised the archive unpacks in
the cwd rather than in a sub-directory.  that said, and one warning (cf
'core/render/trace.cpp') aside, building and install went ok (i5, Slackware
14.2).
(in which scenario is building from "Source code (tar.gz)" still preferred?)
regards, jr.
Date: 11 Jul 2021 13:15:24
Message: <60eb272c$1@news.povray.org>
Am 11.07.2021 um 18:53 schrieb jr:
If you can help wrangling the `tar` and/or `gzip` command to rectify
that, I'd appreciate it.
We're currently using the following sequence of commands to bundle the
files we want:
tarfile="povunix-v${POV_RAY_FULL_VERSION}.tar"
# Bundle relevant portions of the original source tree, making sure
# to exclude interim products placed there by the prebuild process.
tar -chWf "${tarfile}"          \
   --anchored                    \
   --exclude="*Makefile.am"      \
   --exclude="unix/prebuild*"    \
   --exclude="unix/scripts*"     \
   --exclude="platform/windows"  \
   --exclude="vfe/win"           \
   doc platform source unix vfe  \
   LICENSE README.md changes.txt revision.txt
# Add everything created by the prebuild process, except for some
# interim products created by the prebuild process.
# (Note that some files may have already been added by the previous
# command, so we're using `-u` instead of `-r` to avoid duplicates.)
tar -uhWf "${tarfile}"          \
   --anchored                    \
   --exclude="configure.ac"      \
   --exclude="bootstrap"         \
   ${prebuild_made}
# Compress bundle into proper tarball
gzip "${tarfile}"
where `prebuild_made` is a list of files detected as having been created
by `unix/prebuild.sh`.
In the one where you're building for a non-Unix platform but have a ZIP
file format phobia, I guess.
The "Source code (tar.gz)" and "Source code (zip)" assets are added
automatically by GitHub, whether we want it to or not.
Date: 11 Jul 2021 14:00:00
Message: <web.60eb3146b74fb8af5e0fed26cde94f1@news.povray.org>
hi,
> files we want:
>    --anchored                    \
>    --anchored                    \
>    ${prebuild_made}
> gzip "${tarfile}"
had not known '--anchored', interesting.  I guess simplest would be just
repacking, something like (any typos mine):
mkdir v${POV_RAY_FULL_VERSION}
( cd v${POV_RAY_FULL_VERSION} ; tar -xf ../$tarfile )
rm -f $tarfile
tar $tarfile ${POV_RAY_FULL_VERSION} && sync
gzip "${tarfile}"
rm -fr ${POV_RAY_FULL_VERSION}
ah, ok.  thanks.
regards, jr.
Date: 11 Jul 2021 14:30:00
Message: <web.60eb3843b74fb8af5e0fed26cde94f1@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> ... typos ...  </sigh>  even missed out the cli options, sorry.
rm -f $tarfile
tar -cvf $tarfile v${POV_RAY_FULL_VERSION} && sync
gzip "${tarfile}"
rm -fr v${POV_RAY_FULL_VERSION}
regards, jr.
Date: 11 Jul 2021 14:35:54
Message: <60eb3a0a$1@news.povray.org>
Am 11.07.2021 um 19:58 schrieb jr:
I think I've found something: Adding `--transform "s,^,FOO/,"` to the
parameters should do the job (for a suitable definition of `FOO`).
Requires GNU, but we don't need this to work on end-users' machines.
Date: 11 Jul 2021 18:05:00
Message: <web.60eb6a6cb74fb8af5e0fed26cde94f1@news.povray.org>
hi,
works using 'sed'?!  v nice.  (will try and remember to explore this when
opportune)
regards, jr.
Date: 12 Jul 2021 02:11:22
Message: <60ebdd0a$1@news.povray.org>
Am 12.07.2021 um 00:02 schrieb jr:
> opportune)
Not sure if it uses `sed` under the hood, but the syntax seems to be
`sed`-like, yes.
Date: 13 Jul 2021 02:25:00
Message: <web.60ed30a3b74fb8afa3e088d5e0f8c582@news.povray.org>
> It's official now:
> raw repo contents.
> Happy Testing!
I could install and run the benchmark without any problems on two Linux
machines.
Thank you Clipka.
Date: 14 Jul 2021 05:35:00
Message: <web.60eeafa2b74fb8af5e0fed26cde94f1@news.povray.org>
> >> I think I've found something ...
there was one other (small) thing, forgot to mention.  during installation, if
another 3.8 version already exists, the old 'povray.{conf,ini}' files get
renamed to '*.bak' and new files are put in place.  this has the disadvantage
that the existing povray no longer works as configured.  the usual practice is
to leave existing files alone if found, and create the distributed as
'povray.{conf,ini}.new'; "admin" then integrates manually.
regards, jr.
Date: 14 Jul 2021 19:57:33
Message: <60ef79ed$1@news.povray.org>
Am 14.07.2021 um 11:34 schrieb jr:
Can you please file an issue report on GitHub, to put a propoer pin in this?
I tend to lose track of stuff mentioned only on the newsgroups.
Date: 15 Jul 2021 10:15:00
Message: <web.60f042aab74fb8af5e0fed26cde94f1@news.povray.org>
hi,
went there, cannot add an "issue" without acquiring an account.  sorry.
perhaps a "kind soul" with github membership followed this thread and will
create the report.
regards, jr.
Date: 16 Jul 2021 06:54:17
Message: <60f16559$1@news.povray.org>
Am 15.07.2021 um 16:14 schrieb jr:
I'd argue that it's worth it, given that it's free of charge. It may not
be the last issue you might want to report.
GitHub _is_ our preferred place for bug reports these days.
And we're by far not the only ones. There is an ever growing number of
other pieces of open source software out there that have GitHub as their
_only_ official channel for bug reporting. Having a GitHub account opens
up the door to those, too.
Date: 16 Jul 2021 07:50:00
Message: <web.60f17163b74fb8af5e0fed26cde94f1@news.povray.org>
hi,
I'm sure that people like you, self-confessed "Windows jockeys" that is, find
the  environment .. conducive to your working.  a bit like Linux distributions,
some people find Ubuntu/Debian "floats their boat".
fwiw, the 'github.com/POV-Ray/povray/tags' page would benefit from showing
checksums (sha256?) for the archives, too.
sure.  (though regrettable from my perspective)  as long as no account is needed
to download the source archive.
> other pieces of open source software ...
the "not the only ones" argument reminds me of an old saying "people, eat more
shit, four billion flies can't be wrong".  fifteen or twenty years ago,
SourceForge was the place to be (seen) on, maybe github will do better, who
knows?
regards, jr.
Date: 16 Jul 2021 23:16:31
Message: <60f24b8f$1@news.povray.org>
Am 16.07.2021 um 13:45 schrieb jr:
I'm not sure what the benefit of that would be.
If you do not trust to get the proper archives from GitHub, I see no
reason to trust that you'll see the proper SHAs for those files.
(Or do you mena SHAs of the commits corresponding to those tags? Well,
the first 7 digits of those _are_ shown on that page; and if you click
on those, it'll take you to a page where the full SHA of the commit is
shown in all its glory.)
Now, publishing checksums on the POV-Ray home page, that might be
another matter. But even then, it only really makes sense for versions
we build on our own machines and upload to GitHub later. Not so much for
the betas: They are built directly on GitHub servers.
(And yes, I do trust Microsoft's GitHub servers more than I do my own
Windows 10 machine.)
These days, there is pretty much no software project that allows the
reporting of bugs without _some_ form of identification. It's just not
possible anymore - they'd be swamped by spambots.
And with that in mind, I for one welcome our new insect overl... erm, I
mean, I for one applaud every project that uses some reasonably common
bug tracking service, rather than rolling their own. Because although I
do agree that it sucks to be unable to report a bug without registering
_somewhere_, in my opinion it sucks less if that registration is good
for multiple pieces of software that I use.
> knows?
SourceForge thought they could exploit their pole position with
impunity. Which is how they lost it to GitHub.
We didn't go to GitHub because we thought it was the bee's knees; we
went there because we decided to set up a public repository, in hopes to
get more people to contribute - and SourceForge had just gone rogue at
the time we were ready to actually go ahead with that step. GitHub just
happened to be pretty much the only contender, and actually we were
initially quite skeptical, not the least because we had no experience
with Git in particular nor even any other distributed version control
system in general.
Looking back, I'm sure it wasn't the worst of choices.
Also, I'm not saying you should join the flies and host your own
projects there (although I might, if you were to ask for advice in that
matter). Going with that image, it's more like I'm saying that if you
want to catch flies, that's where to find lots of them. That's not a
question of taste - it's just pure matter of fact.
Date: 17 Jul 2021 12:05:00
Message: <web.60f2fe9cb74fb8af5e0fed26cde94f1@news.povray.org>
hi,
> ... github ...
I suspect you could sell ice boxes to the inuit -- in mid-winter.  ;-)
>> fwiw, ... checksums ...
not worried/paranoid about GitHub as an organisation, just wary of .. clever
individuals, who always find some nook or cranny.
regards, jr.
Date: 18 Jul 2021 07:10:00
Message: <web.60f40b7eb74fb8af5e0fed26cde94f1@news.povray.org>
hi,
> ... v3.8.0-beta.1 ...
> Happy Testing!
when I run the beta with '-cc +w400 +h300 +a +rtr +kla', the preview window pops
up but shows nothing.  the current 'povr' is fine with exact same command-line.
regards, jr.
Date: 18 Jul 2021 12:56:13
Message: <60f45d2d$1@news.povray.org>
Am 18.07.2021 um 13:07 schrieb jr:
> hi,
>> Happy Testing!
"povr" is not POV-Ray. It is a derivative work by someone who also
happens to work on POV.Ray.
I don't have the capacity (nor even an overwiew of what would have to be
done) to merge Bill's changes into POV-Ray proper.
Date: 18 Jul 2021 19:05:00
Message: <web.60f4b355b74fb8af4cef624e6e066e29@news.povray.org>
Those settings work OK in the Windows version.
Do you correctly have *multiple* camera in your scene for rtr and kla to work
properly? (or a #while/#for loop to generate the multiple cameras?) With just a
single camera in such a scene, the parsing/rendering seems to go into an
endless(?) loop-- although I still see a single render of my scene in the
preview, not a blank screen like you mention.
Date: 18 Jul 2021 19:15:00
Message: <web.60f4b55db74fb8af4cef624e6e066e29@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> ...With just a
> endless(?) loop--
I mean an endless loop with the computer chugging away, but doing nothing. The
real-time raytracing feature, when working properly, also generates an endless
looping animation-- but that's with all the new camera positions, one after the
other.
Date: 19 Jul 2021 05:20:00
Message: <web.60f542e4b74fb8af5e0fed26cde94f1@news.povray.org>
hi,
> properly? ...
I think so, yes.  the code (and command-line) works fine with one particular
executable (WFP's povr) but not with the official "unofficial" alpha + beta
versions I have.  cheers.
regards, jr.
Date: 19 Jul 2021 08:17:24
Message: <60f56d54$1@news.povray.org>
Rendering a 3.8 version scene which includes functions.inc, I get the
following parse warning:
"functions.inc" line 167: Parse warning: use of POV-Ray v3.7 keyword
('deprecated') detected in alleged v3.5 scene.
The only place were version 3.5 is mentioned is precisely at the start
of functions.inc:
#ifndef(Functions_Inc_Temp)
#declare Functions_Inc_Temp = version;
#version 3.5;
At the mentioned line 167 of this /new/ functions.inc shipped with the
beta, a /new/ if statement has been introduced, not there in previous
versions:
#if (Functions_Inc_Temp < 3.8)
     #declare deprecated once "f_enneper was broken prior to v3.8;
results will most likely differ."
              f_enneper = function { internal(18) }
#else
     #declare f_enneper = function { internal(18) }
Date: 29 Jul 2021 11:45:03
Message: <6102ccff$1@news.povray.org>
I still do not understand this parse warning as I do *not* run a version
3.5 scene. Does it refer to POV-Ray includes which /mention/ version 3.5?
functions.inc seem to be the only include file containing this.
Just a short explanation would be enough about this mysterious warning.
Thanks,
Op 19-7-2021 om 14:17 schreef Thomas de Groot:
> of functions.inc:
> #version 3.5;
> #end
> versions:
> #else
> #end
Date: 29 Jul 2021 15:54:36
Message: <6103077c$1@news.povray.org>
Am 29.07.2021 um 17:45 schrieb Thomas de Groot:
It's a bug in `functions.inc`: At the start it claims that it needs only
v3.5, but later it uses the `deprecated` keyword, which wasn't
introduced until v3.7.
In other words, if someone were to use genuine POV-Ray v3.5, and render
the scene with that very same include file, they'd get an error message.
The fact that POV-Ray warns about such scenarios is a brand new feature
of v3.8.0-beta.1.
Date: 30 Jul 2021 01:57:15
Message: <610394bb$1@news.povray.org>
Op 29/07/2021 om 21:54 schreef clipka:
>> version 3.5 scene. Does it refer to POV-Ray includes which /mention/
>> version 3.5?
> of v3.8.0-beta.1.
OK. Thanks for this. I shall just close my eyes ;-)
Date: 4 Aug 2021 17:55:00
Message: <web.610b0c50b74fb8af5e0fed26cde94f1@news.povray.org>
hi,
fwiw, same bug/keyword use for 'glass_old.inc'.
regards, jr.
