POV-Ray : Newsgroups : povray.beta-test : Finish block dispersion handling. v3.8 (and v3.7). Server Time
18 May 2024 20:34:45 EDT (-0400)
  Finish block dispersion handling. v3.8 (and v3.7). (Message 1 to 6 of 6)
Subject: Finish block dispersion handling. v3.8 (and v3.7).
Date: 1 Jul 2021 07:37:40
Message: <60dda904$1@news.povray.org>
Expect not much of an issue given how long it's been this way, but, FWIW...
For backward compatibility we support some interior keywords in the
finish block too. The related finish variables are Temp_Caustics,
Temp_IOR, Temp_Dispersion and Temp_Refract.
The documentation doesn't indicate dispersion was ever previously
supported for the finish block, but we have partial code for it.
The finish block parsing is missing for Temp_Dispersion. User's having
scenes with finish block dispersion get syntax errors.
Taking the ior as being specified in the finish block, if a user were to
specify dispersion in the interior block, as our documentation
indicates, they get confusing results due this code in object.cpp:
if (Finish->Temp_IOR >= 0.0)
     Object->interior->IOR = Finish->Temp_IOR;
     Object->interior->Dispersion = Finish->Temp_Dispersion;
The defaulted Finish->Temp_Dispersion value (1.0) is used and the user
has no way to override the default due the lack of finish { dispersion }
parsing.
And, yes, users can mix the interior vs finish block definitions
supported in both blocks in confusing ways. We don't warn that
conflicting definitions are a problem, and, such conflicts are not
flagged during parsing. A finish block ior>0.0 overrides any ior set in
the interior block.
Aside:
The compatibility warning message when you specify, for example, ior in
the finish block is misleading. All about backwards compatibility when
the concern is, I believe, forward compatibility.
Index of refraction value should be specified in 'interior{...}' statement.
Use of this syntax may not be backwards compatible with earlier versions
of POV-Ray.
Bill P.
Subject: Re: Finish block dispersion handling. v3.8 (and v3.7).
Date: 1 Jul 2021 09:27:57
Message: <60ddc2dd$1@news.povray.org>
Am 01.07.2021 um 13:37 schrieb William F Pokorny:
> parsing.
Refraction settings seem to have been officially moved from `finish` to
the then-new `interior` in POV-Ray v3.1.
Dispersion was only added later, in POV-Ray v3.5. My guess is that
whoever added the feature has probably considered whether to extend the
old in-finish syntax to also support dispersion, but came to no definite
conclusion, and therefore designed the mechanism under the hood to
easily support such an extension, but that extension never materialized.
> the interior block.
A finish block ior >0.0 does trigger a warning, which should be enough
of an indication for anyone to notice that they're doing an oopsie. If
they're deliberately continuing to use an entirely undocumented feature
despite earning warnings, I'd argue that we're not their baby-sitters.
> Aside:
> of POV-Ray.
The intention of the message is to say, "when you use this syntax, the
behavior of this version may not be backwards compatible with that of
earlier versions".
I'd be happy to hear a better phrasing.
Date: 5 Jul 2021 08:30:00
Message: <web.60e2fa31e6d4fedfd98418916e066e29@news.povray.org>
[Windows 10, running a v3.8xx 'experimental' pvengine  that piggybacks on
v3.7.0]
Both of these examples produce fatal errors:
1) Using ONLY dispersion and dispersion_samples in a finish{}block, PLUS an
interior{ior} block:
Possible Parse Error: Unmatched {
Parse Error: No matching }, dispersion found instead
[This warning message makes no sense, IMO]
2) Using BOTH ior and dispersion/dispersion_samples in a finish{} block, but NO
interior {} block:
Parse Warning: Index of refraction value should be specified in 'interior{...}'
statement...   Use of this syntax may not be backwards compatible with earlier
versions of POV-Ray.
[The 'Parse Warning' part of this message seems to indicate that such syntax can
(or could) be used at some point in the past...but it completely fails in 3.8xx
-- which makes the 'backwards-compatible' part of the warning no longer
necessary or even meaningful now. In other words, how can such syntax be used at
all now if it produces a fatal error anyway? ]
I tried the same constructs in v3.7.0, and got the same fatal errors and warning
messages.
If the 'dispersion' feature was newly added in v3.5-- and was apparently usable
in a finish{} block at that point(?)-- at what point in POV-ray's later
development did such syntax start causing *fatal* errors?
Date: 5 Jul 2021 08:39:23
Message: <60e2fd7b$1@news.povray.org>
Am 05.07.2021 um 14:25 schrieb Kenneth:
It does, because `dispersion` does not belong in `finish`, and never did.
> interior {} block:
Using `ior` in `finish` _was_ valid official syntax at some point, and
you only get a warning for it. Using `dispersion` alongside of it has
_never_ been valid in `finish`, and you get an error for even trying.
Refraction parameters had been deprecated in `finish` even before
`dispersion` was added to the set of refraction parameters. Using the
latter in `finish` would _always_ have raised a fatal error: Originally
because `dispersion` wasn't a thing at all, and later because once it
became a thing, refraction parameters in `finish` had already ceased to
be a thing.
Date: 5 Jul 2021 09:15:00
Message: <web.60e3059be6d4fedfd98418916e066e29@news.povray.org>
Hmm. It would be nicer for us plebeians if the message said, "The dispersion
keyword is not allowed in a finish block. Use it in an interior block instead."
Basic yet informative! :-)  Those "Unmatched brackets..." warnings seem to be
'generic' at times IIRC, causing me to scratch my head in wonder.
Aha! My methodology was wrong. Thanks.
Date: 5 Jul 2021 11:08:39
Message: <60e32077@news.povray.org>
Am 05.07.2021 um 15:14 schrieb Kenneth:
Yes, that's why they're categorized as "possible parse error", rather
than "parse error".
Essentially, that's POV-Ray saying, "I've encountered _something_ I
haven't expected here at all; did you perhaps forget a closing `}`? No?
Well, then never mind, and let's see what other complaints I may raise
that might be more helpful."
