POV-Ray : Newsgroups : povray.beta-test : wrong report about max_gradient Server Time
7 Mar 2026 01:20:17 EST (-0500)
  wrong report about max_gradient (Message 1 to 10 of 23)
Subject: wrong report about max_gradient
Date: 19 Nov 2001 03:22:16
Message: <5tfhvt4uj921171obes8j1hfl93eoi64ei@4ax.com>
POV 3.5 b 7 on PII 233 128 MB with NT 4 Sp 6
I had such syntax within isosurface:
  max_gradient 10
  evaluate 1, 10, 0.99
but renderer said after trace
  Warning: The maximum gradient found was 184.775, but max_gradient of
  the isosurface was set to 1988.679. Adjust max_gradient to
  get a faster rendering of the isosurface.
IMO 1988.679 <> 10. Expected behaviour, misunderstand or bug ?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Subject: Re: wrong report about max_gradient
Date: 19 Nov 2001 04:37:16
Message: <3bf8d2cc@news.povray.org>
I think this is something which has been fixed for the next beta. You should
wait for it and see if the problem still exists.
Date: 19 Nov 2001 05:29:42
Message: <3bf8df16$1@news.povray.org>
See  http://news.povray.org/3be10cf9@news.povray.org
>**** Dynamic maximum gradient estimation *****
>max_gradient G_max
>"eval(uate) P0, P1, P2"
>where
>  P0 is the minimum max_gradient value in the estimation process,
>  P1 should be more than 1 (over-estimation parameter), and
>  P2 should be less than 1 (attenuation parameter).
>The max_gradient, G_max, is re-calculated for each ray as following
>        If (G_max< G*P1)
>             then   G_max = G*P1*P1
>             else if (G_max>P0) then G_max = G_max*P2,
So, the max_gradient value in the scene file is the 'initial' value
and it is re-declared in the estimation (or rendering) process.
I think only the sentense "Warning: The maximum gradient found was 184.775."
 is enough for the evaluatation result.
R. Suzuki
Date: 19 Nov 2001 05:35:06
Message: <lunhvt07a7gg1ffmln18bmq6pvug3ftn88@4ax.com>
On Mon, 19 Nov 2001 19:29:39 +0900, "R. Suzuki" <r-s### [at] aistgojp> wrote:
I can't agree. When there are more then one isosurfaces simetimes initial value
is only way to recognize where founded value shuold be applied.
ABX
Date: 19 Nov 2001 06:37:43
Message: <3bf8ef07@news.povray.org>
>   max_gradient 10
See
Newsgroups: povray.beta-test
Subject: Isosurfaces *much* slower in beta 7?
Date: Tue, 30 Oct 2001 23:07:31 +0100
Message-ID: <3bdf24b3$1@news.povray.org>
Xref: news.povray.org povray.beta-test:2475
e-mail: tho### [at] trfde
Date: 19 Nov 2001 06:41:54
Message: <3bf8f002@news.povray.org>
In article <3bf8df16$1@news.povray.org> , "R. Suzuki" <r-s### [at] aistgojp>
The problem is that many people don't read the documentation and then
complain about "holes and other bugs" with isosurfaces (see several messages
in these groups).  I would also prefer a shorter message, but as long as
many people who use a free software cannot be asked to read the
documentation before reporting something as a bug this message is a
inconvenience that has to be forced upon all users :-(
    Thorsten
Date: 19 Nov 2001 07:21:54
Message: <k0uhvt4l9ppp8pgs655obeirbedjovd74n@4ax.com>
On Mon, 19 Nov 2001 12:37:42 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> See
> From: "JRG" <jrg### [at] hotmailcom>
I don't like bothering but there is nothing about difference between typed value
and outputed value. in that thread :-(
Perhaps it was misunderstand but I reported here that I wrote 10 in script but
report message said I wrote 1988.679. I know meaning of the message. It is
annoing when you are trying find isosurface from many isosurfaces to apply
calculated value.
ABX
Date: 19 Nov 2001 07:28:02
Message: <8duhvto4s52070im27o3fkomaif4cms34e@4ax.com>
On Mon, 19 Nov 2001 12:41:53 +0100, "Thorsten Froehlich" <tho### [at] trfde>
> complain about "holes and other bugs" with isosurfaces.
IMO you misunderstand this bug report. I wrote 10 but report said I wrote more
than 1900. I understand inner behaviour, I just pointed out is says false.
ABX
Date: 19 Nov 2001 08:01:41
Message: <3bf902b5@news.povray.org>
I was not refering to you or the bug report at all.  I was only pointing out
the need for the additional parts of the message that appear unnecessary for
those who did read the documentation.
    Thorsten
Date: 19 Nov 2001 08:05:40
Message: <3bf903a4@news.povray.org>
> value and outputed value. in that thread :-(
> calculated value.
Here it is:
>From: "Thorsten Froehlich" <tho### [at] trfde>
>Subject: Re: Isosurfaces *much* slower in beta 7?
>Date: Mit, 31. Okt 2001 10:27 Uhr
>Message-ID: <3bdfc402@news.povray.org>
>Xref: news.povray.org povray.beta-test:2503
>> That's really sad, i was just starting to use it intensively.
> That is part of beta testing.  It is not really a serious problem, it is
> just very slow...
>> Apart from
>> being incredibly slow it also seems to produce wrong results.
> No, it only changes your max_gradient.  The reported found maximum gradient
> value is still correct.
