POV-Ray : Newsgroups : povray.beta-test : wrong report about max_gradient Server Time
18 May 2026 21:48:53 EDT (-0400)
  wrong report about max_gradient (Message 14 to 23 of 23)
Subject: Re: wrong report about max_gradient
Date: 19 Nov 2001 08:25:33
Message: <8p1ivtseldt44no1iddgo697vlkuqqpnt2@4ax.com>
On Mon, 19 Nov 2001 14:16:26 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> Yes, I say it "changes your max_gradient", so if it *changes* your
> max_gradient, how can it report *your* max_gradient?
Can't it be remembered in local variable? It can report isosurface line within
source. Why it can't remember initial value? It shows line and then says 'value
was set to ...'
> Anyway, just take my word for it:  This has long ago been fixed for the
> _next_ beta.
Ok. I don't like bothering so sorry for this long bothering :-)
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 19 Nov 2001 08:33:35
Message: <s52ivt885j48ckodtdit0dtseqp7u8fekn@4ax.com>
On Mon, 19 Nov 2001 14:22:52 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> BTW, why do you try to convince me that it is a bug when I have already
> *acknowledged* that it is a bug?
Becouse I thought all the time you're talking about different thing.
> (Rhetoric question only, no answer expected!)
Please don't read  above answer ;-)
> Somehow communication failed completely...
The easiest explanation for me is my english
but I don't know if it is good enough :-(
Sorry again for bothering, really sorry.
ABX
Date: 19 Nov 2001 08:56:39
Message: <3bf90f97@news.povray.org>
Because it is a ***bug*that*it*changes*the*user*supplied*max_gradient***!!!
It was never supposed to change it the way it does and then output that as
the user supplied max_gradient!!!
> 'value was set to ...'
It has nothing to do with the *algorithm*, but a ***bug*** in the
*implementation* of the algorithm.  This obviously has to be fixed by
changing the *implementation* of the algorithm, not by *changing* the
*algorithm* itself!!!  And as I said:  It *has* been fixed this way already,
so any suggestion on how to change the *algorithm* to fix it is completely
unnecessary because the *algorithm* is correct, only its *implementation* is
*not* correct in beta 7!!!
    Thorsten
e-mail: tho### [at] trfde
Date: 19 Nov 2001 08:59:05
Message: <3bf91029@news.povray.org>
Try reading more English and using it actively whenever you a chance.  It
really helps!
No problem.
    Thorsten
Date: 19 Nov 2001 09:07:45
Message: <3bf91230@news.povray.org>
: I don't like bothering but there is nothing about difference between typed value
: and outputed value. in that thread :-(
  Really? Did you actually read the whole thread? More precisely, this
article of mine:
From war### [at] tagpovrayorg Mon Nov 19 16:05:26 2001
Message-ID: <3be0175a@news.povray.org>
Subject: Re: Isosurfaces *much* slower in beta 7?
Newsgroups: povray.beta-test
Thorsten Froehlich <tho### [at] trfde> wrote:
: * Warp: Do a sync (get change 1235) to try it.
  Ok, I did it, and there clearly is a difference.
  I tested with this small example:
#include "functions.inc"
camera { location -z*5 look_at 0 angle 35 }
light_source { <100,200,-300>, 1 }
isosurface
{ function { x^2+y^2+z^2-(1-.2*f_noise3d(x*8,y*8,z*8)) }
  contained_by { sphere { 0,1 } }
  max_gradient 2
  evaluate 1,10,.99
  pigment { rgb x } finish { specular .5 }
  The older version (ie. beta7) rendered that in 1 min 30 seconds in this
computer. The report was a bit odd:
Warning: The maximum gradient found was 3.555, but max_gradient of
the isosurface was set to 310.201. Adjust max_gradient to
get a faster rendering of the isosurface.
  The newer version renders the example above in 13 seconds, which is a clear
improvement.
Warning: The maximum gradient found was 3.477, but max_gradient of the
isosurface was set to 2.000. The isosurface may contain holes!
Adjust max_gradient to get a proper rendering of the isosurface.
  The max_gradient value of 3.477 seems to be correct. When I set max_gradient
to that, the isosurface renders ok.
  It seems that now 'evaluate' doesn't actually change the max_gradient, but
just calculates the correct one and reports it. The example above renders
equally whether or not the 'evaluate' is there.
  This behaviour seems logical to me.
Date: 19 Nov 2001 09:08:54
Message: <3bf91276@news.povray.org>
> I can't agree. When there are more then one isosurfaces simetimes initial
value
> is only way to recognize where founded value shuold be applied.
You do realize that it outputs the line number of the isosurface, don't you?
So there is absolutely no need to use the max_gradient to identify different
isosurfaces...
    Thorsten
Date: 19 Nov 2001 09:11:08
Message: <ul4ivt0ibrum7gmdsfseofsh6jc1ukfjp9@4ax.com>
On Mon, 19 Nov 2001 15:08:52 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Yes, before I missed this.
> isosurfaces...
Yes, I agree now. Congratulations of your patience :-)
ABX
Date: 19 Nov 2001 09:14:37
Message: <hq4ivt851smfiln0i3t9iakt95e1mkrc32@4ax.com>
>article of mine:
Please, stop. I repeat it was my wrong perception of words. Should I repeat 100
times "I'm guilty"? Sorry again and again.
ABX
Date: 19 Nov 2001 09:17:59
Message: <3bf91497@news.povray.org>
: Please, stop. I repeat it was my wrong perception of words. Should I repeat 100
: times "I'm guilty"? Sorry again and again.
  Your punishment: Write 100 times "I will not do it again".
  Just kidding ;)
Date: 20 Nov 2001 07:33:35
Message: <53jkvt4kt904487q74gncv0eddlq84rru1@4ax.com>
Without using a #while loop!
Peter Popov ICQ : 15002700
