POV-Ray : Newsgroups : povray.beta-test : Fwd: Stack Size Testers Wanted Server Time
13 Mar 2026 13:52:30 EDT (-0400)
  Fwd: Stack Size Testers Wanted (Message 11 to 12 of 12)
Subject: Re: Fwd: Stack Size Testers Wanted
Date: 18 Feb 2019 08:45:07
Message: <5c6ab6e3$1@news.povray.org>
On 2/17/19 9:39 PM, clipka wrote:
> Am 18.02.2019 um 00:41 schrieb William F Pokorny:
>> OK. Surprised the heap allocation is slower than one on the stack. I
>> figured the allocation and free mechanisms were more or less the same
>> - just being a difference of where in memory it happened. Guess not?
> Definitely not.
Dick, Christoph, Thanks both for the helpful tutorials on stack operation.
> As a matter of fact, as I just discovered, C99 _does_ support such a
> thing; but it's not "flexible array member" but "variable length
> arrays"; and they can't be nested in structs, and C++ did not adopt them.
> One reason why C++ did not adopt them is some entirely unrelated
> fundamental stumbling block rooted in the C++ type concept. But I guess
> they might also mess up - or at least complicate - exception handling;
> "stack unwinding" would be the buzzword there.
This last I'd come across as I was thrashing around. I must have blended
the two features together as one in my mind...
Bill P.
Date: 18 Feb 2019 09:08:58
Message: <5c6abc7a$1@news.povray.org>
On 2/17/19 6:41 PM, William F Pokorny wrote:
>> IIRC there was a use case for a `polynomial` primitive that needed an
>> order of 16, and Jerome decided it would be nonsense to increase it by
>> 1 just to wait for the next use case to require an order of 17; so he
>> went ahead and increased the limit to something that was not totally
>> arbitrary. 35 was a natural choice because above this threshold the
>> `binomials` array of constants would overflow the data type on some
>> machines (32-bit `unsigned int`).
>> If we want to use a lower maximum order, 19 would be a logical choice,
>> as it's the threshold at which we could change the datat type of the
>> `binomials` array from `unsigned int` to `unsigned short` to save some
>> memory.
> Thanks for the background. I'll put it on my list to look at what 19
> would give us performance wise.
Same test set up as before; setting MAX_ORDER to 19.
+wt1
14.25 -> 14.14 ---> -0.77%
+wt2
14.31 -> 14.16 ---> -1.05%
+wt3
19.11 -> 18.79 ---> -1.67%
+wt4
22.90 -> 22.35 ---> -2.40%
For my own day to day use I plan to hard code my working POV-Ray version
to 10 (sphere_sweep) as that's the largest needed for other than user
coded polynomials as far as I know.
Bill P.
