POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10013324 Server Time
21 Jan 2026 21:12:57 EST (-0500)
  POV-Ray v3.8.0-alpha.10013324 (Message 1 to 7 of 7)
Subject: POV-Ray v3.8.0-alpha.10013324
Date: 14 Jan 2019 11:58:46
Message: <5c3cbfc6@news.povray.org>
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-alpha.10013324
This version should fix crashes from user-defined functions, `text`
primitives and recursive macro invocations.
Subject: Re: POV-Ray v3.8.0-alpha.10013324
Date: 14 Jan 2019 13:29:31
Message: <5c3cd50b$1@news.povray.org>
Given you are looking at the parser, the text object and fonts I want to
pass along an old signature scene file which has not never run correctly
for me unless I create a COUR.TTF file.
I've made a couple runs at trying to find where the COUR.TTF default
comes from in the code - including again just now - and failed. Guessing
at some point just using the string ttf caused some defaulting to a font
called COUR.TTF and some string perhaps. Think it something which should
be cleaned up (just 'ttf' should fail parsing I think). The latest
alpha.10013324 still generates:
File 'Sig34_LookAtWeirdDefaultAndFailSomeday.pov' line 2: Possible Parse
Error:
  Text may not be displayed as expected. Please refer to the user manual
  regarding changes in POV-Ray v3.8 and later.
File 'Sig34_LookAtWeirdDefaultAndFailSomeday.pov' line 3: Possible Parse
Error:
  Cannot find file 'COUR.TTF', even after trying to append file type
extension.
Error:
  Cannot open font file.
Fatal error in parser: Cannot open file.
Render failed
Bill P.
Download 'sig34_lookatweirddefaultandfailsomeday.pov.txt' (1 KB)
Date: 14 Jan 2019 13:51:48
Message: <5c3cda44$1@news.povray.org>
> Error:
> Error:
> extension.
> Error:
> Render failed
> Bill P.
And I walk to get a coffee and it pops into my head what is happening
here.... chr() Never mind. I spent all my time looking in the source
code instead of the SDL...
Bill P.
Date: 14 Jan 2019 14:08:11
Message: <5c3cde1b$1@news.povray.org>
Am 14.01.2019 um 19:29 schrieb William F Pokorny:
The text is encoded in only mildly obfuscated form in the R vector:
     #local R=<7084844682857967,0787982,826975826580>
     70 84 84 46 82 85 79 67   78 79 82   82 69 75 82 65 80
     F  T  T  .  R  U  O  C    N  O  R    R  E  K  R  A  P
Both text objects use macro `L(P)` to decode R.x into "COUR.TTF" as the
font name, and R.y and R.z respectively into "RON" and "PARKER" as the
text string.
I actually found it pretty easy to untangle: Knowing that there is no
such default, I looked for /some/ mechanism that could conjure strings
out of thin air. `chr` was my hottest candidate, and once I spotted it
in macro `L(P)`, the rest almost trivially fell into place.
Date: 15 Jan 2019 08:35:01
Message: <web.5c3ddd2cb703701fcd98345b0@news.povray.org>
I've at least tried the text-object example that was crashing the previous
alpha-version, and it works fine now. Kudos!
[Clipka wrote]:
Trivial??!  :-O  Nice detective work!
I just spent several hours going through that code-- which is really brilliant--
to dissect it. I understand *most* of it now, but there are some particular
pieces of code syntax that I'm not quite grasping. (Sorry to go off-topic, but
the code is fascinating.)
BTW, #debugging  mod(P,100) in the #while loop gives me these values (i.e.,
in reversed order from yours):
        67 79 85 82 46 84 84 70   82 79 78   80 65 82 75 69 82
        C  O  U  R   . T  T  F    R  O  N    P  A  R  K  E  R
..... along with some less-than-1.0 fractional values.
The syntax questions:
1) In the #while loop, the value of mod(P,100) eventually falls below 1.0 to a
decimal fraction (before P itself finally reaches such a small value as to be
considered zero or 'false', to end the loop.) But what does   chr(...)  'see'
when it sees a fraction like
         0.70848?
Or rather, does mod(...) truncate fractions to zero? Whatever ASCII character
that  chr(...) *does* return in such a case would seem to be part of the final
text string (via the #while loop); but I'm wondering how that affects the final
text object, if at all?
I'm also wondering how the code's #macro construct adds the required
double-quotes around the #while-loop's created strings (for final use in the
text objects). The syntax used there is new to me. There's a pair of
double-quotes near the end of the macro that *looks* like it's just an 'empty
string', but I don't grasp what it's doing.
Date: 15 Jan 2019 14:58:09
Message: <5c3e3b51$1@news.povray.org>
Am 15.01.2019 um 14:31 schrieb Kenneth:
Note that I'm not looking at the details; the general idea is all I'm after.
>           0.70848?
The `mod()` does not truncate fractions. The `chr()` function does
truncate fractions first, then converts the resulting integer value to a
character (according to the UCS-2 character set, of which ASCII is a
subset).
The result would be U+0000, which happens to be the value used
internally to mark the end of the string; so even if other characters
were to follow, downstream code would truncate the string at that
position. For all other intents and purposes, the U+0000 character
itself is ignored.
There is no need for double quotes. You only need those when you specify
strings literally, not when using any other mechanism that gives you a
string.
Consider the following code:
     #declare LetterA = chr(65);
This gives you a string consisting of only the uppercase letter `A`. No
need for quotes - you got the string already. It is equivalent to:
     #declare LetterA = "A";
There, you need the quotes to tell POV-Ray that you want the `A` to be
taken as a string containing that letter, as opposed to the value of an
identifier named `A`.
Now consider the following code:
     #declare S = concat(LetterA,LetterB)
This will take the strings currently stored in `LetterA` and `LetterB`,
and pass them to the function `concat`, which will compose a new string
containing the concatenation of those strings. Again no quotes
necessary, because at no point do you mean the literal character
sequences `concat`, `LetterA` or `LetterB`, but rather the function
asssociated with the keyword and the values stored in the variables,
respectively.
Now consider the following:
     text { ttf "MyFont", "MyText", ... }
This means a text object with a font literally named `MyFont`[.ttf], and
with the literal text `MyText`. Compare this to:
     text { ttf MyFont MyText ... }
This instead means a text object with a font name as per the current
value of the variable named `MyFont` and with the same text as currently
stored in the variable named `MyText`.
Now back to the functions:
     text { ttf concat(chr(65),chr(66))
                concat(chr(67),chr(68)) ... }
This means a text object with a font whose name is the concatenation of
the characters 65 and 66 of the ASCII character set (that would be the
literal string `AB`[ttf]), and a text which is the concatenation of the
characters 67 and 68 (that would be `CD`).
If you were to place double quotes around it, like so:
     text { ttf "concat(chr(65),chr(66))"
                "concat(chr(67),chr(68))" ... }
then this would mean a text object with a font literally named
`concat(chr(65),chr(66)).ttf` and literally the text
`concat(chr(67),chr(68))`. I'm not even sure whether the font name would
be a valid file name, but that's what POV-Ray would try.
If you want to use quotes but have the same result as the earlier code,
you'd instead have to use:
     text { ttf "AB" "CD" ... }
I hope this gives you a clearer picture.
So, to sum up: Quotes are only necessary where you want to specify a
string by literally spelling out the string's content. If you construct
the string's content in any other way, quotes would only be in the way.
Date: 15 Jan 2019 17:40:01
Message: <web.5c3e60beb703701fcd98345b0@news.povray.org>
I have to admit my ignorance: That's a true revelation to me, after all this
time working with POV-Ray! I've always assumed that strings *required*
double-quotes, no matter how they were created or how they were used.
Thanks for taking the time to give such a clear and detailed explanation. It
will go into my archive of 'most-useful' discoveries :-)
And thanks to Bill Pokorny for posting the intriguing code. I would not have
thought to ask my questions otherwise.
