POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10011104 Server Time
29 Apr 2024 03:36:42 EDT (-0400)
  POV-Ray v3.8.0-alpha.10011104 (Message 11 to 20 of 34)
Subject: Re: POV-Ray v3.8.0-alpha.10011104
Date: 13 Jan 2019 16:05:00
Message: <web.5c3ba73e2cb80e7848892b50@news.povray.org>
> Am 13.01.2019 um 21:06 schrieb jr:
> >> I have no idea what a "'wget'able" URL is, but maybe this one qualifies:
> > "man 1 wget", or "curl".  command-line tools to fetch stuff.
> Heh, don't expect me to know about any of that; I'm a Windows jockey and
> mouse pusher ;)
:-)  (or perhaps a frown.  really not sure)
on "the substance" then, you manage to reproduce the crash, I take it?
regards, jr.
Date: 13 Jan 2019 16:55:50
Message: <5c3bb3e6$1@news.povray.org>
Am 13.01.2019 um 22:01 schrieb jr:
>> mouse pusher ;)
More like, "I'll get back to you on that".
That was the status when I wrote that post, anyway. Meanwhile I did find
a bug that could conceivably cause a crash, and am in the process of
submitting a fix.
Date: 13 Jan 2019 17:04:12
Message: <5c3bb5dc$1@news.povray.org>
Another known issue:
Scenes making use of `text` primitives may cause a parse error or even
hard crash under certain circumstances. This time the Windows version
must also be considered vulnerable.
If you encounter this problem, try inserting `cmap { 1,0 charsert 0 }`
after the font file name. Alternatively, using `#version 3.7;
global_setting { charset ascii }` should also be a viable workaround as
long as you do indeed only use ASCII characters.
Date: 13 Jan 2019 17:07:21
Message: <5c3bb699$1@news.povray.org>
Am 13.01.2019 um 23:04 schrieb clipka:
Users building their own binaries (most notably Unix users) may also use
`source/core/shape/truetype.cpp` from the latest master, which should
fix the issue:
https://raw.githubusercontent.com/POV-Ray/povray/master/source/core/shape/truetype.cpp
Date: 13 Jan 2019 17:30:00
Message: <web.5c3bbaf02cb80e7848892b50@news.povray.org>
hi,
> fix the issue:
thanks.  got the files, will recompile etc by midweek or so.
regards, jr.
Date: 13 Jan 2019 19:45:01
Message: <web.5c3bdb322cb80e78cd98345b0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> I used a reduced version of the 'pav-patt.pov' for the test, with the
> latest (ie 10011104) alpha.  it crashes when T2 "visible":
> #declare T2 = text {
>   ttf "arialbd.ttf"
>   S
>   0.001 0
>   pigment { color rgb 0.1 }
>   no_shadow
T2 when used also hard-crashes in Windows (Win7 Ultimate). But the behavior is
strange-- sometimes it doesn't crash for the first 4 out of 5 runs (for
example), sometimes on the first run-- then with a Windows message "... a memory
access violation has occured at ..."
Otherwise, I've run approximately 40 of my own scenes-- with arrays,
user-defined functions, and other text objects in the mix-- and everything works
fine, so far. But my own text objects are of this form...
text{
internal 1 "my text here"
.....rather than
text{
ttf "arielbd.ttf"
S
Date: 13 Jan 2019 22:08:55
Message: <5c3bfd47$1@news.povray.org>
Am 14.01.2019 um 01:43 schrieb Kenneth:
Yeah, memory access violations do that: Sometimes the memory accessed
happens to hold something that the process can legally read.
> text{
You shouldn't use that syntax. Quoth the docs:
"It should be noted that this is only a preliminary solution so the
benchmark program will run without installing POV-Ray. Future versions
may lack this mechanism, so in scene files (other than the built-in
benchmark) you should continue to reference the external font files as
before."
Date: 14 Jan 2019 01:25:01
Message: <web.5c3c2a4d2cb80e78cd98345b0@news.povray.org>
> > ...But my own text objects are of this form...
> > text{
> You shouldn't use that syntax. Quoth the docs...
Funny thing about that: I started using the 'internal' syntax sometime over the
past year(?), because using the font NAME (like JR's example of  ttf "arielbd")
suddenly no longer worked for me-- causing a fatal error, or a crash (I can't
remember which-- or which alpha/beta verson of POV I was running at the time.)
Then I promptly forgot why I changed it! (And never changed it back.)
Thanks for the documentation reminder.
Date: 14 Jan 2019 02:30:00
Message: <web.5c3c397a2cb80e78cd98345b0@news.povray.org>
> suddenly no longer worked for me-- ...
..... or it could have been good ol' human error on my part, like misspelling the
ttf font name.  :-(  The simple error message I *probably* got at the time was,
"Cannot find font file"
Date: 14 Jan 2019 09:07:50
Message: <5c3c97b6$1@news.povray.org>
> fix the issue:
Running master at commit f9e8bce or I believe with the change above. The
attached file (Someone's signature scene) from my parser testing
collection gives:
==== [Parsing...] ==========================================================
File 'Sig00.pov' line 2: Parse Warning: Float value promoted to full
color vector where both filter and transmit >0.0.
File 'Sig00.pov' line 1: Parse Error: End of file reached but #end expected.
Fatal error in parser: Cannot parse input.
Render failed
It renders fine in other versions OK.
Unfortunately a change in my own tcl code base caused problems running
the complete set of test cases... Off to fix that and try the complete
set again.
Bill P.
Download 'sig00.pov.txt' (1 KB)
