POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10011104 Server Time
24 Jun 2026 01:53:51 EDT (-0400)
  POV-Ray v3.8.0-alpha.10011104 (Message 1 to 10 of 34)
Subject: POV-Ray v3.8.0-alpha.10011104
Date: 12 Jan 2019 23:39:16
Message: <5c3ac0f4@news.povray.org>
(Dang, committed 3 or 4 minutes too late or 6 or 7 minutes too soon for
a really neat pre-release tag number ;))
Please try this - I hope it solves the crashes:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-alpha.10011104
Subject: Re: POV-Ray v3.8.0-alpha.10011104
Date: 13 Jan 2019 04:43:10
Message: <5c3b082e@news.povray.org>
Date: 13 Jan 2019 04:50:01
Message: <web.5c3b09a32cb80e7848892b50@news.povray.org>
hi,
development is now driven by numerology?!  :-)
will do, thanks.
regards, jr.
Date: 13 Jan 2019 10:29:49
Message: <5c3b596d$1@news.povray.org>
Known issue:
User-defined functions may cause a hard crash on some platforms.
If you encounter this issue, pelase copy
`source/parser/parser_function_utilities.cpp` from the current master
branch.
The Windows binaries appear to be unaffected, so I'm not rushing out a
new version for now.
Date: 13 Jan 2019 11:15:00
Message: <web.5c3b63182cb80e7848892b50@news.povray.org>
hi,
> Known issue:
I've tried with two scenes, one crashes, the other does not.  the only
difference, afaict, is that the first uses array syntax in both declaration and
in one of the function components, while the second has no array stuff.
> branch.
regards, jr.
Date: 13 Jan 2019 11:55:23
Message: <5c3b6d7b$1@news.povray.org>
Am 13.01.2019 um 17:11 schrieb jr:
Then the recommended workaround probably applies to your system and, by
extension, presumably Unix systems in general.
Date: 13 Jan 2019 12:25:06
Message: <web.5c3b74002cb80e7848892b50@news.povray.org>
hi,
ok.  do you have a 'wget'able url for that file, please?
btw, the alpha (also) crashes when there's an "old-style" text primitive, ie
without cmap {}, irrespective of charset present in global_settings.  does the
above workaround fix that too?
regards, jr.
Date: 13 Jan 2019 14:46:22
Message: <5c3b958e$1@news.povray.org>
Am 13.01.2019 um 18:23 schrieb jr:
> hi,
I have no idea what a "'wget'able" URL is, but maybe this one qualifies:
https://raw.githubusercontent.com/POV-Ray/povray/master/source/parser/parser_functions_utilities.cpp
I thought you were confirming that v3.8.0-alpha.10011104 fixed your
issue? Please clarify, and double-check the version you're running.
Those `text` primitive crashes you were observing are totally unrelated
to the user-defined function crashes.
Date: 13 Jan 2019 15:10:00
Message: <web.5c3b9a5b2cb80e7848892b50@news.povray.org>
hi,
"man 1 wget", or "curl".  command-line tools to fetch stuff.
will do nicely.  thanks.
yes, I appreciate that.
I used a reduced version of the 'pav-patt.pov' for the test, with the latest (ie
10011104) alpha.  it crashes when T2 "visible":
#version 3.8;
global_settings {assumed_gamma 1}
#declare S = "abcdef";
#declare T1 = text {
  ttf "arialbd.ttf" cmap { 1,0 charset 0 }
  S
  0.001 0
  pigment { color rgb<1.0, 0.6, 0.2>*1.25 }
  no_shadow
#if (0)
#declare T2 = text {
  ttf "arialbd.ttf"
  S
  0.001 0
  pigment { color rgb 0.1 }
  no_shadow
regards, jr.
Date: 13 Jan 2019 15:32:36
Message: <5c3ba064$1@news.povray.org>
Am 13.01.2019 um 21:06 schrieb jr:
Heh, don't expect me to know about any of that; I'm a Windows jockey and
mouse pusher ;)
