POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10011104 Server Time
13 Mar 2026 17:02:33 EDT (-0400)
  POV-Ray v3.8.0-alpha.10011104 (Message 5 to 14 of 34)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: POV-Ray v3.8.0-alpha.10011104
Date: 13 Jan 2019 11:15:00
Message: <web.5c3b63182cb80e7848892b50@news.povray.org>
hi,
> Known issue:
> User-defined functions may cause a hard crash on some platforms.
I've tried with two scenes, one crashes, the other does not.  the only
difference, afaict, is that the first uses array syntax in both declaration and
in one of the function components, while the second has no array stuff.
> If you encounter this issue, pelase copy
> `source/parser/parser_function_utilities.cpp` from the current master
> branch.
> The Windows binaries appear to be unaffected, so I'm not rushing out a
> new version for now.
regards, jr.
Date: 13 Jan 2019 11:55:23
Message: <5c3b6d7b$1@news.povray.org>
Am 13.01.2019 um 17:11 schrieb jr:
Then the recommended workaround probably applies to your system and, by
extension, presumably Unix systems in general.
Date: 13 Jan 2019 12:25:06
Message: <web.5c3b74002cb80e7848892b50@news.povray.org>
hi,
ok.  do you have a 'wget'able url for that file, please?
btw, the alpha (also) crashes when there's an "old-style" text primitive, ie
without cmap {}, irrespective of charset present in global_settings.  does the
above workaround fix that too?
regards, jr.
Date: 13 Jan 2019 14:46:22
Message: <5c3b958e$1@news.povray.org>
Am 13.01.2019 um 18:23 schrieb jr:
> hi,
I have no idea what a "'wget'able" URL is, but maybe this one qualifies:
https://raw.githubusercontent.com/POV-Ray/povray/master/source/parser/parser_functions_utilities.cpp
I thought you were confirming that v3.8.0-alpha.10011104 fixed your
issue? Please clarify, and double-check the version you're running.
Those `text` primitive crashes you were observing are totally unrelated
to the user-defined function crashes.
Date: 13 Jan 2019 15:10:00
Message: <web.5c3b9a5b2cb80e7848892b50@news.povray.org>
hi,
"man 1 wget", or "curl".  command-line tools to fetch stuff.
will do nicely.  thanks.
yes, I appreciate that.
I used a reduced version of the 'pav-patt.pov' for the test, with the latest (ie
10011104) alpha.  it crashes when T2 "visible":
#version 3.8;
global_settings {assumed_gamma 1}
#declare S = "abcdef";
#declare T1 = text {
  ttf "arialbd.ttf" cmap { 1,0 charset 0 }
  S
  0.001 0
  pigment { color rgb<1.0, 0.6, 0.2>*1.25 }
  no_shadow
#if (0)
#declare T2 = text {
  ttf "arialbd.ttf"
  S
  0.001 0
  pigment { color rgb 0.1 }
  no_shadow
regards, jr.
Date: 13 Jan 2019 15:32:36
Message: <5c3ba064$1@news.povray.org>
Am 13.01.2019 um 21:06 schrieb jr:
Heh, don't expect me to know about any of that; I'm a Windows jockey and
mouse pusher ;)
Date: 13 Jan 2019 16:05:00
Message: <web.5c3ba73e2cb80e7848892b50@news.povray.org>
> mouse pusher ;)
:-)  (or perhaps a frown.  really not sure)
on "the substance" then, you manage to reproduce the crash, I take it?
regards, jr.
Date: 13 Jan 2019 16:55:50
Message: <5c3bb3e6$1@news.povray.org>
Am 13.01.2019 um 22:01 schrieb jr:
>> mouse pusher ;)
More like, "I'll get back to you on that".
That was the status when I wrote that post, anyway. Meanwhile I did find
a bug that could conceivably cause a crash, and am in the process of
submitting a fix.
Date: 13 Jan 2019 17:04:12
Message: <5c3bb5dc$1@news.povray.org>
Another known issue:
Scenes making use of `text` primitives may cause a parse error or even
hard crash under certain circumstances. This time the Windows version
must also be considered vulnerable.
If you encounter this problem, try inserting `cmap { 1,0 charsert 0 }`
after the font file name. Alternatively, using `#version 3.7;
global_setting { charset ascii }` should also be a viable workaround as
long as you do indeed only use ASCII characters.
Date: 13 Jan 2019 17:07:21
Message: <5c3bb699$1@news.povray.org>
Am 13.01.2019 um 23:04 schrieb clipka:
Users building their own binaries (most notably Unix users) may also use
`source/core/shape/truetype.cpp` from the latest master, which should
fix the issue:
https://raw.githubusercontent.com/POV-Ray/povray/master/source/core/shape/truetype.cpp
