POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10011104 Server Time
13 Mar 2026 13:51:44 EDT (-0400)
  POV-Ray v3.8.0-alpha.10011104 (Message 25 to 34 of 34)
Subject: Re: POV-Ray v3.8.0-alpha.10011104
Date: 14 Jan 2019 12:16:43
Message: <5c3cc3fb$1@news.povray.org>
On 1/14/19 11:39 AM, clipka wrote:
> Am 14.01.2019 um 15:07 schrieb William F Pokorny:
>> File 'Sig00.pov' line 2: Parse Warning: Float value promoted to full
>> color vector where both filter and transmit >0.0.
>> File 'Sig00.pov' line 1: Parse Error: End of file reached but #end
>> expected.
>> Fatal error in parser: Cannot parse input.
>> Render failed
> Traced this down to a bug in the scanner that kicks in whenever two
> consecutive returns from a macro or include file jump back to the same
> binary offset in (formally) different input streams
> One such scenario is the return from a macro that has called itself
> recursively and hasn't called other macros since.
Cool. Glad you found it.
Bill P.
Date: 14 Jan 2019 12:23:12
Message: <5c3cc580$1@news.povray.org>
On 1/13/19 5:07 PM, clipka wrote:
> Am 13.01.2019 um 23:04 schrieb clipka:
>> Another known issue:
> Users building their own binaries (most notably Unix users) may also use
> `source/core/shape/truetype.cpp` from the latest master, which should
> fix the issue:
https://raw.githubusercontent.com/POV-Ray/povray/master/source/core/shape/truetype.cpp
Stuff still running. I've turned up several more of the macro/include
return type.
One of our standard shipped scene files fails due a form feed character
'0c' very near the end the end of the file. That scene is:
.../distribution/scenes/objects/superel2.pov
and here I think we just need to update that scene file.
Bill P.
Date: 14 Jan 2019 13:41:32
Message: <5c3cd7dc$1@news.povray.org>
Am 14.01.2019 um 18:15 schrieb William F Pokorny:
> Suppose my question was too whether we should consider the 3.7/3.8
> behavior broken - you seem to be saying it was.
Let's put it this way: Going by the reference docs on numeric
expressions - specifically FLOAT_LITERAL - the v3.7 behaviour would have
to be considered broken, unless interpreting the syntax in a
self-inconsistent manner.
The key question is under what circumstances a sequence of characters
that matches the production rules of FLOAT_LITERAL, followed by some
other character that does not fit in, constitutes a broken
FLOAT_LITERAL, as opposed to a valid FLOAT_LITERAL token immediately
followed by the next token.
The v3.6 behaviour can easily be interpreted as consistently treating
such cases as valid, but erroneously implementing MANTISSA as:
     MANTISSA:
       DIGIT... [DECIMAL_POINT | [DIGIT2...] |
       DECIMAL_POINT DIGIT2...
     DIGIT2:
       DIGIT | DECIMAL_POINT
The v3.7 behaviour must be interpreted as treating such cases as broken
if the non-matching character is a dot, but valid if it is any other
character. That's a pretty arbitrary distinction.
The (new) v3.8 behaviour consistently treats all such cases as valid
again, while implementing MANTISSA as documented.
> Folks can again cause parsing to separate values by using extra decimal
> points in numeric strings. Has me wondering what might happen with typos
> like 1..2 (not tried it).
That would have to be `1.` followed by `.2`.
> Or where we specify lists of values separated
> by commas or not. Can the latter get scrambled in ways that are confusing?
Dots don't constitute valid infix or postfix operators in numeric
expressions, so there's no ambiguity there.
Date: 14 Jan 2019 15:29:29
Message: <5c3cf129$1@news.povray.org>
>      MANTISSA:
>      DIGIT2:
>> decimal points in numeric strings. Has me wondering what might happen
>> with typos like 1..2 (not tried it).
>> Or where we specify lists of values separated by commas or not. Can
Thanks for the detail. I've been playing with variations for the last
hour or so and created some new parser test cases in my collection to
track this change. While 1..2 gets treated as two numbers .1..2 and the
like do not - so even the exposure to period over comma typos is small.
Not picked up anything new and have switched over to your latest code -
it fixed all the recursive return fails I had. Should finish up tomorrow
sometime and will post again only if something new turns up.
For the record I'm only checking the parser with my tests. I'm not doing
image to image compares. Image compares will happen over time after I
rebase my branches onto the current master head and continue other
efforts.
Bill P.
Date: 14 Jan 2019 15:47:39
Message: <5c3cf56b$1@news.povray.org>
Am 14.01.2019 um 21:29 schrieb William F Pokorny:
> rebase my branches onto the current master head and continue other efforts.
I think that's perfectly fine; I don't expect any parser issues to be
subtle enough to make it to the rendering stage - with the exception of
string and text handling, specifically non-ASCII stuff.
Date: 14 Jan 2019 15:54:21
Message: <5c3cf6fd$1@news.povray.org>
Am 14.01.2019 um 18:23 schrieb William F Pokorny:
> ..../distribution/scenes/objects/superel2.pov
Page breaks used to be common in ASCII files a while ago; I feel somehow
inclined to just allow them as whitespace.
The only thing that's holding me back is that I'm not exactly sure what
effect they should have on column and line counting.
Date: 15 Jan 2019 06:03:57
Message: <5c3dbe1d$1@news.povray.org>
>> character '0c' very near the end the end of the file. That scene is:
Yeah, suppose they could be as whitespace. Then we'd want to provide the
same treatment for some other printer(system bell?) oriented encodings
too if you go that route. Vertical-tab comes to mind & expect there are
a few more.
Even in the old days it was printer dependent in terms of real world
space(1) so not sure treating those special characters as something
other than a single white space makes sense. I say this, though, not
knowing what the POV-Ray windows editor does which such characters?
As for having these kind of characters in sample scene files we ship,
suppose I'd argue they shouldn't exist. In my editor/font I get some odd
fill-in character for it. I'm not sure what others might or might not see.
Bill P.
(1) - Do I admit my earliest college programming classes used teletype
computer terminals... Ah, the noise. :-)
Date: 15 Jan 2019 08:25:00
Message: <web.5c3dde4a2cb80e7893ab27150@news.povray.org>
> a few more.
At the very least, it seems logical to increment the line count.  I don't think
it would be necessary--or, at this late date, prudent--to assume a certain
number of lines per page.
You make me feel young, now.  I had VT-100s in college.
Although at my co-op job, I actually had to deal with punched cards and IBM's
JCL.
Date: 16 Jan 2019 09:33:58
Message: <5c3f40d6$1@news.povray.org>
Not sure. The common unix line counting command shows the line count
(and character) as if the form feed and vertical tab characters are just
spaces.
Editors seem to be different. GVim (1) is showing ^L and ^K stand in
sequences and then columns after in each line as a range, 10-11 say,
instead of a fixed 10. Gedit shows single undefined unicode characters
breaking the mono-space width. Others tried create a mono-space stand at
least indicating some odd character is present and the visual
representation stays aligned. Expect some of the editor behavior is
driven by the font in use. Though in trying a few different fonts with
gvim, fixed and not, it is always showing the ^L or ^K sequence and some
visual miss-alignment.
(1) - all vi based editors I expect
> JCL.
JCL :-). How do we want the file xyz to physically exist on the drive...
I worked with it a fair bit early in my work career.
Date: 16 Jan 2019 15:06:14
Message: <5c3f8eb6$1@news.povray.org>
>> somehow inclined to just allow them as whitespace.
>> what effect they should have on column and line counting.
> a few more.
> Bill P.
Treating form feed as just line feed or new line should be correct.
