POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10011104 Server Time
20 Jun 2026 04:33:53 EDT (-0400)
  POV-Ray v3.8.0-alpha.10011104 (Message 21 to 30 of 34)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: POV-Ray v3.8.0-alpha.10011104
Date: 14 Jan 2019 10:18:48
Message: <5c3ca858$1@news.povray.org>
On 1/14/19 9:07 AM, William F Pokorny wrote:
> On 1/13/19 5:07 PM, clipka wrote:
Just noticed another interesting thing in the tests that did run. The
attached file has not parser cleanly since v3.6.1. Generating the
following error with v3.7:
File 'Sig07_works_v361_earlier.pov' line 1: Parse Error: Unexpected
additional
  '.' in floating-point number
Fatal error in parser: Cannot parse input.
Render failed
It parses and runs cleanly again with the updated parser. Intentional?
Bill P.
Download 'sig07_works_v361_earlier.pov.txt' (1 KB)
Date: 14 Jan 2019 10:54:54
Message: <5c3cb0ce$1@news.povray.org>
Am 14.01.2019 um 16:18 schrieb William F Pokorny:
I presume you mean to say that it worked in v3.6.1, but not in v3.7,
correct?
> additional
> Render failed
Those are some mean pieces of scene code; no surprise they catch the
parser with its pants down ;)
No, just a lucky punch. Turns out sometimes throwing away and rewriting
old code fixes things you didn't even know were broken.
Date: 14 Jan 2019 11:39:12
Message: <5c3cbb30$1@news.povray.org>
Am 14.01.2019 um 15:07 schrieb William F Pokorny:
> File 'Sig00.pov' line 2: Parse Warning: Float value promoted to full
> color vector where both filter and transmit >0.0.
> File 'Sig00.pov' line 1: Parse Error: End of file reached but #end
> expected.
> Render failed
Traced this down to a bug in the scanner that kicks in whenever two
consecutive returns from a macro or include file jump back to the same
binary offset in (formally) different input streams
One such scenario is the return from a macro that has called itself
recursively and hasn't called other macros since.
Date: 14 Jan 2019 12:15:46
Message: <5c3cc3c2$1@news.povray.org>
> correct?
Yes, I did! You are getting good at understand my gibberish. :-)
Suppose my question was too whether we should consider the 3.7/3.8
behavior broken - you seem to be saying it was.
Folks can again cause parsing to separate values by using extra decimal
points in numeric strings. Has me wondering what might happen with typos
like 1..2 (not tried it). Or where we specify lists of values separated
by commas or not. Can the latter get scrambled in ways that are confusing?
I'll go try some things I guess to better understand what can again
happen with this reversion in parser behavior.
Bill P.
Date: 14 Jan 2019 12:16:43
Message: <5c3cc3fb$1@news.povray.org>
>> expected.
>> Render failed
Cool. Glad you found it.
Bill P.
Date: 14 Jan 2019 12:23:12
Message: <5c3cc580$1@news.povray.org>
> Am 13.01.2019 um 23:04 schrieb clipka:
>> Another known issue:
> Users building their own binaries (most notably Unix users) may also use
> `source/core/shape/truetype.cpp` from the latest master, which should
> fix the issue:
https://raw.githubusercontent.com/POV-Ray/povray/master/source/core/shape/truetype.cpp
Stuff still running. I've turned up several more of the macro/include
return type.
One of our standard shipped scene files fails due a form feed character
'0c' very near the end the end of the file. That scene is:
.../distribution/scenes/objects/superel2.pov
and here I think we just need to update that scene file.
Bill P.
Date: 14 Jan 2019 13:41:32
Message: <5c3cd7dc$1@news.povray.org>
Am 14.01.2019 um 18:15 schrieb William F Pokorny:
Let's put it this way: Going by the reference docs on numeric
expressions - specifically FLOAT_LITERAL - the v3.7 behaviour would have
to be considered broken, unless interpreting the syntax in a
self-inconsistent manner.
The key question is under what circumstances a sequence of characters
that matches the production rules of FLOAT_LITERAL, followed by some
other character that does not fit in, constitutes a broken
FLOAT_LITERAL, as opposed to a valid FLOAT_LITERAL token immediately
followed by the next token.
The v3.6 behaviour can easily be interpreted as consistently treating
such cases as valid, but erroneously implementing MANTISSA as:
     MANTISSA:
       DIGIT... [DECIMAL_POINT | [DIGIT2...] |
       DECIMAL_POINT DIGIT2...
     DIGIT2:
       DIGIT | DECIMAL_POINT
The v3.7 behaviour must be interpreted as treating such cases as broken
if the non-matching character is a dot, but valid if it is any other
character. That's a pretty arbitrary distinction.
The (new) v3.8 behaviour consistently treats all such cases as valid
again, while implementing MANTISSA as documented.
That would have to be `1.` followed by `.2`.
Dots don't constitute valid infix or postfix operators in numeric
expressions, so there's no ambiguity there.
Date: 14 Jan 2019 15:29:29
Message: <5c3cf129$1@news.povray.org>
>      MANTISSA:
>      DIGIT2:
>> decimal points in numeric strings. Has me wondering what might happen
>> with typos like 1..2 (not tried it).
>> Or where we specify lists of values separated by commas or not. Can
Thanks for the detail. I've been playing with variations for the last
hour or so and created some new parser test cases in my collection to
track this change. While 1..2 gets treated as two numbers .1..2 and the
like do not - so even the exposure to period over comma typos is small.
Not picked up anything new and have switched over to your latest code -
it fixed all the recursive return fails I had. Should finish up tomorrow
sometime and will post again only if something new turns up.
For the record I'm only checking the parser with my tests. I'm not doing
image to image compares. Image compares will happen over time after I
rebase my branches onto the current master head and continue other
efforts.
Bill P.
Date: 14 Jan 2019 15:47:39
Message: <5c3cf56b$1@news.povray.org>
Am 14.01.2019 um 21:29 schrieb William F Pokorny:
> rebase my branches onto the current master head and continue other efforts.
I think that's perfectly fine; I don't expect any parser issues to be
subtle enough to make it to the rendering stage - with the exception of
string and text handling, specifically non-ASCII stuff.
Date: 14 Jan 2019 15:54:21
Message: <5c3cf6fd$1@news.povray.org>
Am 14.01.2019 um 18:23 schrieb William F Pokorny:
> ..../distribution/scenes/objects/superel2.pov
Page breaks used to be common in ASCII files a while ago; I feel somehow
inclined to just allow them as whitespace.
The only thing that's holding me back is that I'm not exactly sure what
effect they should have on column and line counting.
