POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10011104 Server Time
14 Jun 2026 07:22:51 EDT (-0400)
  POV-Ray v3.8.0-alpha.10011104 (Message 15 to 24 of 34)
Subject: Re: POV-Ray v3.8.0-alpha.10011104
Date: 13 Jan 2019 17:30:00
Message: <web.5c3bbaf02cb80e7848892b50@news.povray.org>
hi,
> Users building their own binaries (most notably Unix users) may also use
> `source/core/shape/truetype.cpp` from the latest master, which should
> fix the issue:
https://raw.githubusercontent.com/POV-Ray/povray/master/source/core/shape/truetype.cpp
thanks.  got the files, will recompile etc by midweek or so.
regards, jr.
Date: 13 Jan 2019 19:45:01
Message: <web.5c3bdb322cb80e78cd98345b0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> I used a reduced version of the 'pav-patt.pov' for the test, with the
> latest (ie 10011104) alpha.  it crashes when T2 "visible":
> #declare T2 = text {
>   ttf "arialbd.ttf"
>   S
>   0.001 0
>   pigment { color rgb 0.1 }
>   no_shadow
T2 when used also hard-crashes in Windows (Win7 Ultimate). But the behavior is
strange-- sometimes it doesn't crash for the first 4 out of 5 runs (for
example), sometimes on the first run-- then with a Windows message "... a memory
access violation has occured at ..."
Otherwise, I've run approximately 40 of my own scenes-- with arrays,
user-defined functions, and other text objects in the mix-- and everything works
fine, so far. But my own text objects are of this form...
text{
internal 1 "my text here"
.....rather than
text{
ttf "arielbd.ttf"
S
Date: 13 Jan 2019 22:08:55
Message: <5c3bfd47$1@news.povray.org>
Am 14.01.2019 um 01:43 schrieb Kenneth:
Yeah, memory access violations do that: Sometimes the memory accessed
happens to hold something that the process can legally read.
> text{
You shouldn't use that syntax. Quoth the docs:
"It should be noted that this is only a preliminary solution so the
benchmark program will run without installing POV-Ray. Future versions
may lack this mechanism, so in scene files (other than the built-in
benchmark) you should continue to reference the external font files as
before."
Date: 14 Jan 2019 01:25:01
Message: <web.5c3c2a4d2cb80e78cd98345b0@news.povray.org>
> > ...But my own text objects are of this form...
> > text{
> You shouldn't use that syntax. Quoth the docs...
Funny thing about that: I started using the 'internal' syntax sometime over the
past year(?), because using the font NAME (like JR's example of  ttf "arielbd")
suddenly no longer worked for me-- causing a fatal error, or a crash (I can't
remember which-- or which alpha/beta verson of POV I was running at the time.)
Then I promptly forgot why I changed it! (And never changed it back.)
Thanks for the documentation reminder.
Date: 14 Jan 2019 02:30:00
Message: <web.5c3c397a2cb80e78cd98345b0@news.povray.org>
> suddenly no longer worked for me-- ...
..... or it could have been good ol' human error on my part, like misspelling the
ttf font name.  :-(  The simple error message I *probably* got at the time was,
"Cannot find font file"
Date: 14 Jan 2019 09:07:50
Message: <5c3c97b6$1@news.povray.org>
On 1/13/19 5:07 PM, clipka wrote:
> Am 13.01.2019 um 23:04 schrieb clipka:
>> Another known issue:
>> Scenes making use of `text` primitives may cause a parse error or even
>> hard crash under certain circumstances. This time the Windows version
>> must also be considered vulnerable.
> fix the issue:
Running master at commit f9e8bce or I believe with the change above. The
attached file (Someone's signature scene) from my parser testing
collection gives:
==== [Parsing...] ==========================================================
File 'Sig00.pov' line 2: Parse Warning: Float value promoted to full
color vector where both filter and transmit >0.0.
File 'Sig00.pov' line 1: Parse Error: End of file reached but #end expected.
Fatal error in parser: Cannot parse input.
Render failed
It renders fine in other versions OK.
Unfortunately a change in my own tcl code base caused problems running
the complete set of test cases... Off to fix that and try the complete
set again.
Bill P.
Download 'sig00.pov.txt' (1 KB)
Date: 14 Jan 2019 10:18:48
Message: <5c3ca858$1@news.povray.org>
Just noticed another interesting thing in the tests that did run. The
attached file has not parser cleanly since v3.6.1. Generating the
following error with v3.7:
File 'Sig07_works_v361_earlier.pov' line 1: Parse Error: Unexpected
additional
  '.' in floating-point number
Render failed
It parses and runs cleanly again with the updated parser. Intentional?
Bill P.
Download 'sig07_works_v361_earlier.pov.txt' (1 KB)
Date: 14 Jan 2019 10:54:54
Message: <5c3cb0ce$1@news.povray.org>
Am 14.01.2019 um 16:18 schrieb William F Pokorny:
I presume you mean to say that it worked in v3.6.1, but not in v3.7,
correct?
> additional
> Render failed
Those are some mean pieces of scene code; no surprise they catch the
parser with its pants down ;)
No, just a lucky punch. Turns out sometimes throwing away and rewriting
old code fixes things you didn't even know were broken.
Date: 14 Jan 2019 11:39:12
Message: <5c3cbb30$1@news.povray.org>
Am 14.01.2019 um 15:07 schrieb William F Pokorny:
> expected.
> Render failed
Traced this down to a bug in the scanner that kicks in whenever two
consecutive returns from a macro or include file jump back to the same
binary offset in (formally) different input streams
One such scenario is the return from a macro that has called itself
recursively and hasn't called other macros since.
Date: 14 Jan 2019 12:15:46
Message: <5c3cc3c2$1@news.povray.org>
> correct?
Yes, I did! You are getting good at understand my gibberish. :-)
Suppose my question was too whether we should consider the 3.7/3.8
behavior broken - you seem to be saying it was.
Folks can again cause parsing to separate values by using extra decimal
points in numeric strings. Has me wondering what might happen with typos
like 1..2 (not tried it). Or where we specify lists of values separated
by commas or not. Can the latter get scrambled in ways that are confusing?
I'll go try some things I guess to better understand what can again
happen with this reversion in parser behavior.
Bill P.
