POV-Ray : Newsgroups : povray.beta-test : Experimental v3.8.0-x.tokenizer.9960461 Server Time
25 Apr 2026 05:17:07 EDT (-0400)
  Experimental v3.8.0-x.tokenizer.9960461 (Message 1 to 6 of 6)
Subject: Experimental v3.8.0-x.tokenizer.9960461
Date: 8 Dec 2018 21:26:32
Message: <5c0c7d58$1@news.povray.org>
Hi folks,
another iteration of the new parser needs thorough testing:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-x.tokenizer.9960461
Please let me know of any SDL constructs that work in the latest alpha
but cause this version to throw a tantrum.
Subject: Re: Experimental v3.8.0-x.tokenizer.9960461
Date: 9 Dec 2018 10:10:00
Message: <web.5c0d2f9298d8491ae43b71790@news.povray.org>
hi,
> Hi folks,
it's quite a bit slower than the previous x.tokenizer version (from 5576 to 6095
seconds for the first test), also shows a slight increase in "K tokens"
processed for same scene.
regards, jr.
Date: 9 Dec 2018 20:54:51
Message: <5c0dc76b$1@news.povray.org>
Am 09.12.2018 um 16:09 schrieb jr:
> hi,
> clipka <ano### [at] anonymousorg> wrote:
>> Hi folks,
Performance is the least of my "tactical" priorities (despite being a
strategical goal of the whole thing).
The token count thing worries me a bit. I couldn't care less if I
inadvertently introduced a slight change to the rules for how the number
of tokens is counted as a side effect of some other sensible change, but
I can't think of any recent change that might have such an effect; are
you sure it's not simply an artifact of the way you observe this number?
And are you sure we are talking about the same reference version
(x-tokenizer.9945666)? If so, can you narrow down the scene language
construct for which the values differ?
That said, the main focus of this version is on furthering my
understanding of what's left of the legacy parser code. To that end,
I've peppered the code with checks to verify some assumptions that may
or may not hold true, and what I'm really interested in right now is
reports of cases where they don't. Those should manifest as parse errors.
Date: 10 Dec 2018 08:15:00
Message: <web.5c0e65cc98d8491ae43b71790@news.povray.org>
hi,
there's more than one way to read it? :-)
yes, and not really.  I used 9945627 as the "baseline", then ran the same scene
with 9945666 and 9960461.  all three were run "remote" on an otherwise idling
machine.  as for the language construct, I can not even guess, I have never
really looked at POV-Ray sources.  essentially, nested loops calling a macro
that uses inside() to trace, ie a scan of a volume.
curiously, the alpha reports the "no objects in scene" warning one line earlier
than the x.tokenizer versions.
ah, I might not be much help here, I have no code requiring earlier than 3.6,
still, I'll keep using the latest x.tokenizer as the day-to-day version.
regards ,jr.
Date: 10 Dec 2018 10:39:21
Message: <5c0e88a9$1@news.povray.org>
Am 10.12.2018 um 14:10 schrieb jr:
> hi,
As far as I'm aware, POV-Ray for Windows only reports the token count in
the status line, so the count disappears as soon as the render proper
starts.
I take it you're not running Windows then. (Sorry, I tend to not keep
track of who runs which OS.)
Not much of a surprise there. Line number counting has been rewritten
from scratch, and may differ in how it behaves at the end of the file.
Sorry, misunderstanding I guess. The term "legacy" above wasn't
referring to language constructs (as in e.g. v3.7 vs v3.0 scene
language), but rather the parser itself (as in alpha vs. x.tokenizer
parser code).
Date: 10 Dec 2018 11:50:06
Message: <web.5c0e984398d8491ae43b71790@news.povray.org>
hi,
> >> ... sure it's not simply an artifact of the way you observe this number?
> starts.
same for the *nix version, afaict.
when needed, I capture terminal io with:
  $ script mylog.txt
  $ povray ...
  $ exit
and have complete "transcript" for later.
not anymore.  my household is 100% Microsoft-free.  (well, I kept the fonts :-))
ok.
> >> understanding of what's left of the legacy parser code. ...
> parser code).
ah yes, I (now) see you wrote legacy parser.  so, so far then, six scenes
tested, all run slower in the alpha (all versions self-compiled etc).
regards, jr.
