POV-Ray : Newsgroups : povray.beta-test : Front end cannot process .ini files Server Time
25 Apr 2026 05:12:14 EDT (-0400)
  Front end cannot process .ini files (Message 1 to 4 of 4)
Subject: Front end cannot process .ini files
Date: 4 Nov 2018 17:41:47
Message: <5bdf75ab$1@news.povray.org>
POV-Ray 3.8 cannot process .ini files in my library path; I have to
provide the path to the .ini file in order to get a successful render.
For example:
My povray.ini contains:
---------- [BEGIN FILE EXCERPT] ----------
Library_Path="/usr/local/share/povray-3.8"
Library_Path="/usr/local/share/povray-3.8/ini"
Library_Path="/usr/local/share/povray-3.8/include"
Library_Path="/home/ricky/Documents/POV-Ray/include"
Library_Path="/home/ricky/Documents/POV-Ray/include-others"
Library_Path="/home/ricky/Documents/POV-Ray/Object_Collection"
Library_Path="/home/ricky/Documents/POV-Ray/LightsysIV"
Library_Path="/usr/share/fonts/truetype"
Library_Path="/home/ricky/.fonts"
----------- [END FILE EXCERPT] -----------
These paths are confirmed in the message window of a successful render.
Directory /home/ricky/Documents/POV-Ray/include, which is in the library
path, contains the file:
   jpeg.ini
Directory /home/ricky/Documents/POV-Ray/plane contains the file:
   myscene.pov
 From /home/ricky/Documents/POV-Ray/plane I run the command:
   povray-3.8 myscene.pov jpeg
("povray-3.8" is what I renamed the 3.8 executable, as I still default
to POV-Ray 3.7.0.)
The command fails with the message:
---------- [BEGIN ERROR MESSAGE] ----------
Problem with option setting
Failed to parse command-line option
----------- [END ERROR MESSAGE] -----------
This command renders without errors:
   povray-3.8 myscene.pov ../include/jpeg
This problem has existed since the POV-Ray 3.7.1 betas, and is present
in the latest UberPOV.  Previous versions of POV-Ray do not have this
problem.  (Earlier, I reported a failure to process certain .ini files
from within their own directory; that problem no longer occurs.)
There is no problem locating #include files from within a scene file.
POV-Ray version: 3.8.0-alpha.9893777.unofficial (g++ 7 @
x86_64-pc-linux-gnu)
OS: openSUSE Leap 15.0 (GNU/Linux)
Subject: Re: Front end cannot process .ini files
Date: 5 Nov 2018 09:00:01
Message: <web.5be04c93d0fde9736dfe572e0@news.povray.org>
> For example:
The parsing of INI files works as designed and documented in 3.7. As you know,
the Library_Path option is documented in the "Scene Parsing Options" section. It
has effects only within the scene file.
The behavior in 3.6 and before was rather confusing and would pick up
configuration options in the order they were provided and execute them
instantly. This means it would also parse your INI file and the overwrite
whatever that file specified with whatever came after it in the original INI
file. Your usage only worked due to side effects of the INI parser already
storing the library include paths while it was parsing the options and the code
using the same function to locate files.
Date: 5 Nov 2018 18:22:44
Message: <5be0d0c4$1@news.povray.org>
So what is the point of having /usr/local/share/povray-3.8/ini in the
default povray.ini?  That directory only has .ini files.
Date: 6 Nov 2018 01:35:00
Message: <web.5be134f3d0fde9736547880d0@news.povray.org>
The lack of a permanent Unix version maintainer.
