![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Please give this version a thorough shakedown, with focus on parsing:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-x.tokenizer.9999
Besides testing functionality, please also look at parsing speed.
Known issues:
- `#read` currently disabled
- macro caching currently disabled
- system-specific character encoding in strings currently not supported
(but utf8 should work)
- signature BOM in utf8-encoded files currently not supported
- probably one or two things I'm forgetting to mention
- Backward compatibility with scenes that use single backslashes in
literal filenames has been sacrificed, and will most likely not be restored.
The parser overhaul has been extended to cover not just the "scanner"
stage, but also "raw tokenization", whereby literals are already
evaluated (e.g. digit sequences converted to numbers, and escape
sequences in strings resolved) and reserved words identified. Pretty
much the only tokenization-related task remaining in the monolithic bulk
of the parser is identifying variables, which requires knowledge and
understanding of context.
In passing, a few internal limitations of the parser have also been
lifted; for instance, there is no longer any fixed limit to the nesting
depth of include files, or the nesting depth of parentheses, braces etc.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
A test of a scene comprising a height_field, media clouds, and 4000
cubes distributed on the hf (a scene I am working on at this moment).
Tested with (1) the experimental 3.8 version; (2) UberPOV patch 3.71;
(3) version 3.71.
See attachment for parser details.
Is this what you want?
Download 'testing pov-ray.txt' (4 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> (3) version 3.71.
I'm not really interested in individual scenes, unless they demonstrate a
problem with the new version. More a general "wow that's fast" or "uh, that's
slow" feedback.
Also, when testing parser performance, remember parsing a "cold" file tends to
take longer than a "hot" one.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> (3) version 3.71.
> slow" feedback.
Ok. So it this particular case, the parser was slower (29s. vs 4sec).
Can you explain hot vs cold?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
By "hot" I mean recently read (by this or any other application), increasing the
probability that it is still cached somewhere and doesn't have to be read
completely new from disk.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I've not got a lot of POV-Ray time today, but ran a few random quick
parse scenes - all OK. Then three sets using the Harmonograph.pov
code posted to the newsgroups early last year - loops of the type we
want sped up. Comparing master to your tagged release. All testing done
on a ramdisk though doesn't matter much in the cases I ran. Ubuntu 16.04
g++ 5.4.0.
New parser faster :
28.80 -> 26.60 ---> -7.64%
28.80 -> 26.34 ---> -8.54%
29.24 -> 26.36 ---> -9.85%
Bill P.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 22.05.2018 um 12:57 schrieb Thomas de Groot:
Hm... that's actually quite the difference.
Does the scene in question perhaps rely heavily on macros defined in
another file? Then the disabled macro caching might be a fitting
explanation.
Also, care to share the scene?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 22.05.2018 um 15:35 schrieb William F Pokorny:
> g++ 5.4.0.
> New parser faster :
Now that's what I call better news than those from the country of cheese ;)
And I haven't even really started working on the mechanism by which I
intend to speed up those loops.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
i tried this versus uberpov, win7 64bits. uberpov first at 7m44s (parse only),
with x.tokenizer immediately after (for whatever that means cold/hot) at 7m42s.
essentially identical.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Restructured Parser wants Testing
Date: 23 May 2018 02:54:21
Message: <5b05101d@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> explanation.
From the Land of Cheese:
Where the longer parse time comes from is in the while loop distributing
the cubes. This loop resides in a separate inc file. and looks like this:
#local R1 = seed(1929);
#local R2 = seed(9732);
#local R3 = seed(6493);
#local N1 = 4000;
#local I = 0;
#while (I <= N1)
#local Start = VRand_In_Obj(RocksBox, R1);
#local Norm = <0, 0, 0>;
#local RockPos = trace(Landscape, Start, -y, Norm);
#declare Visible = IsObjectVisible(RockPos)
#if (Visible)
#if (vdot(Norm, y)>0.8 & RockPos.y<50.0*(0.8+rand(R1)*0.4) &
RockF(RockPos.x,RockPos.y,RockPos.z)<0.5+rand(R1)*0.1 & RockPos.y>0 )
object {Rock
//scale (RockPos.y+(1/RockPos.y))*RRand(0.9, 1.1, R2)
scale RockPos.y*RRand(0.9, 1.1, R2)
rotate RRand(-180, 180, R3)
translate RockPos
#if (mod(I, N1/10) = 0)
#debug concat(" Rocks: ", str(I,5,0), "\n")
#local I = I + 1;
#end //slope & altitude
#end //Visible
Otherwise, parse time is about equal between versions when the loop is
disabled.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
