POV-Ray : Newsgroups : povray.beta-test : Subsurface scattering Server Time
10 Nov 2026 11:20:05 EST (-0500)
  Subsurface scattering (Message 1 to 18 of 18)
Subject: Subsurface scattering
Date: 4 Feb 2018 01:59:23
Message: <5a76af4b$1@news.povray.org>
Does POV have this feature yet, or is it still just an Uberpov thing?
Mike
Subject: Re: Subsurface scattering
Date: 4 Feb 2018 03:03:22
Message: <5a76be4a@news.povray.org>
Yes in Ver 3.7
Regards
Date: 4 Feb 2018 21:09:53
Message: <5a77bcf1@news.povray.org>
> Yes in Ver 3.7
Does anyone know what appropriate values might be for LEGO (Ldraw) models?
Here are the mm and ldu units:
http://www.brickwiki.info/wiki/LDraw_unit
Mike
Date: 5 Feb 2018 01:19:09
Message: <5a77f75d$1@news.povray.org>
> Yes in Ver 3.7
Wow, there are a lot of _conditions_ that need to be met before sss will
work.
Mike
Date: 5 Feb 2018 02:28:21
Message: <5a780795$1@news.povray.org>
>> Yes in Ver 3.7
> work.
And if you don't use the mm_per_unit correctly. An angel with a fiery
sword comes after you. ;-)
You will get a severe finger wagging. :-)
Regards
Date: 5 Feb 2018 03:57:41
Message: <5a781c85$1@news.povray.org>
> Yes in Ver 3.7
Do you mean 3.7.1? Because that's what it says in my old uberpov scenes.
Mike
Date: 5 Feb 2018 04:19:57
Message: <5a7821bd$1@news.povray.org>
I tried an old scene that worked properly in uberpov, but I see no
effect in 3.7.0 or 3.8.0 alpha.
Here are my global_settings:
global_settings
	assumed_gamma	1
	#if (Use_Radiosity = 1)
		radiosity
			pretrace_start	0.1
			pretrace_end	0.001
			recursion_limit	2
			count			3
			nearest_count	20,10
			always_sample	off
			maximum_reuse	0.1
			minimum_reuse	0.001
//			no_cache
	ambient_light	0
//	mm_per_unit		0.4
	mm_per_unit		1/4000
	adc_bailout		0.001
	max_trace_level	8
	subsurface
		samples 5, 5
		radiosity true
Here is my finish:
	#declare lg_solid_finish = finish
		ambient	0
		#if (lg_quality >= 2)
			diffuse albedo	0.9
			specular albedo	PlasticSpecularity
			roughness PlasticRoughness
			fresnel on
			reflection
				PlasticSpecularity
//				roughness PlasticRoughness
				fresnel on
	    conserve_energy
Are there additional settings I am missing?
Mike
Date: 5 Feb 2018 04:50:07
Message: <5a7828cf$1@news.povray.org>
> global_settings
>      assumed_gamma    1
>          radiosity
>              pretrace_start    0.1
>              pretrace_end    0.001
>              recursion_limit    2
>              count            3
>              nearest_count    20,10
>              always_sample    off
>              maximum_reuse    0.1
>              minimum_reuse    0.001
> //            no_cache
>      #end
>      ambient_light    0
> //    mm_per_unit        0.4
>      mm_per_unit        1/4000
>      adc_bailout        0.001
>      max_trace_level    8
>      subsurface
>          samples 5, 5
>          radiosity true
> Here is my finish:
>          ambient    0
>              diffuse albedo    0.9
>              fresnel on
>              reflection
>                  PlasticSpecularity
>                  fresnel on
>          #end
>          conserve_energy
> Mike
	#declare PlasticSpecularity  = 1.0;
	#declare PlasticRoughness    = 0.001;
Mike
Date: 5 Feb 2018 05:03:45
Message: <5a782c01$1@news.povray.org>
>> Yes in Ver 3.7
3.7.0 on my machine. I've not used it much recently.
Regards
Date: 5 Feb 2018 06:16:13
Message: <5a783cfd$1@news.povray.org>
> global_settings
>      assumed_gamma    1
>          radiosity
>              pretrace_start    0.1
>              pretrace_end    0.001
>              recursion_limit    2
>              count            3
>              nearest_count    20,10
>              always_sample    off
>              maximum_reuse    0.1
>              minimum_reuse    0.001
> //            no_cache
>      #end
>      ambient_light    0
> //    mm_per_unit        0.4
>      mm_per_unit        1/4000
>      adc_bailout        0.001
>      max_trace_level    8
>      subsurface
>          samples 5, 5
>          radiosity true
> Here is my finish:
>          ambient    0
>              diffuse albedo    0.9
>              fresnel on
>              reflection
>                  PlasticSpecularity
>                  fresnel on
>          #end
>          conserve_energy
> Mike
You need a subsurface {} block in your finish {} block in addition too
the one in global_settings {}.
Remember there are almost always example scenes for features. A
subsurface.pov sample scene ships with POV-Ray. It can also be found
online at:
https://github.com/POV-Ray/povray/tree/master/distribution/scenes/subsurface
Bill P.
Date: 5 Feb 2018 07:56:30
Message: <5a78547e@news.povray.org>
>> global_settings
>>      assumed_gamma    1
>>          radiosity
>>              pretrace_start    0.1
>>              pretrace_end    0.001
>>              recursion_limit    2
>>              count            3
>>              nearest_count    20,10
>>              always_sample    off
>>              maximum_reuse    0.1
>>              minimum_reuse    0.001
>> //            no_cache
>>      #end
>>      ambient_light    0
>> //    mm_per_unit        0.4
>>      mm_per_unit        1/4000
>>      adc_bailout        0.001
>>      max_trace_level    8
>>      subsurface
>>          samples 5, 5
>>          radiosity true
>> Here is my finish:
>>          ambient    0
>>              diffuse albedo    0.9
>>              fresnel on
>>              reflection
>>                  PlasticSpecularity
>>                  fresnel on
>>          #end
>>          conserve_energy
>> Mike
> online at:
> Bill P.
Thanks!!
For LEGO, should I just reuse the surface color for the transparency? Or
something else, like white or black?
Mike
Date: 5 Feb 2018 11:43:31
Message: <5a7889b3@news.povray.org>
Am 04.02.2018 um 07:59 schrieb Mike Horvath:
It never was an UberPOV-only thing in the first place ;)
Date: 5 Feb 2018 12:18:13
Message: <5a7891d5$1@news.povray.org>
Am 05.02.2018 um 03:10 schrieb Mike Horvath:
>> Yes in Ver 3.7
According to that table, and presuming that POV-Ray export of LDraw
models uses 1 LDU = 1 unit in POV-Ray, you should use
    global_settings {
      mm_per_unit 0.4
and either of:
    // opaque (ABS, acrylnitrile butadien styrene)
    interior { ior 1.6 }
    // transparent (Makrolon(R), a polycarbonate)
    interior { ior 1.585 dispersion 1.02 }
    // axles (polyamide, maybe Nylon)
    interior { ior 1.53 }
(The `ior.inc` in the master branch contains values for ABS and PC,
named `iorABS`, `iorPC` and `dispPC`, respectively, but not for PC yet;
it also needs a POV-Ray version newer than v3.7.0.)
As for the subsurface translucency values, you'll have to tinker. I know
of no measured values, and the properties may differ from colour to colour.
Date: 5 Feb 2018 12:34:04
Message: <5a78958c$1@news.povray.org>
Am 05.02.2018 um 13:56 schrieb Mike Horvath:
I guess you mean the `translucency` setting.
No, use neither the pigment colour nor black.
This is actually not a colour /per se/, but rather a value related to
the average distance a photon will travel inside the material before
being absorbed/scattered/both (can't remember the exact interpretation
off the top of my head), which can be specified differently for the
three colour channels (R,G,B).
There are no limits to the setting -- particularly translucent materials
might have values like <10,10,10> or even higher, while "dense"
materials might have values like <0.1,0.1,0.1> or even lower.
I'd start at <1,1,1> and see how it looks. If the material appears too
waxy, reduce the value. If it appears too "hard", increase the value.
Date: 5 Feb 2018 17:33:30
Message: <5a78dbba$1@news.povray.org>
I think I've been confusing two entirely different features. What I've
been trying to achieve is *blurred reflections*, not SSLT. Are they
related? I got confused because my old Uberpov scenes tried to do both.
But blurred reflections are still an Uberpov-only thing right?
Mike
Date: 6 Feb 2018 08:53:13
Message: <5a79b349$1@news.povray.org>
Am 05.02.2018 um 23:33 schrieb Mike Horvath:
> related?
No, not at all. Essentially the only thing they have in common is that
they both are stochastic algorithms and as such create a bit of pixel noise.
Yup.
Date: 6 Feb 2018 21:00:00
Message: <web.5a7a5cacff8943e7a47873e10@news.povray.org>
> global_settings
> [snip]
>  subsurface
>   samples 5, 5
>   radiosity true
I have only limited experience with SSLT so far, but your samples count should
be much higher (try 100,100); otherwise you'll still see some linear-like
stochastic noise or blotches. I *think* the noise appearance has no relation to
the size of the object or its distance from the camera; it shows up as the same
'size' in the render no matter what.
Date: 8 Feb 2018 16:15:48
Message: <5a7cbe04$1@news.povray.org>
>> global_settings
>> [snip]
>>   subsurface
>>    samples 5, 5
>>    radiosity true
The dafault values are 20, 20. You can reduce that if you can live with
some graininess. In my experience, something around 10 to 15 tend to
give acceptable results.
If you have very low translucency, or very large relative to the size of
the object, you may be able to get away with smaller values.
Also, when taking radiosity into account, you probably need to take more
samples.
