POV-Ray : Newsgroups : povray.beta-test : PovRayUnofficial_3.8.0-alpha.9322209 for macintosh available Server Time
22 Mar 2026 13:40:38 EDT (-0400)
  PovRayUnofficial_3.8.0-alpha.9322209 for macintosh available (Message 1 to 10 of 12)
Subject: PovRayUnofficial_3.8.0-alpha.9322209 for macintosh available
Date: 23 Sep 2017 05:50:20
Message: <59c62e5c@news.povray.org>
Copy-pase :-)
POV-Ray v3.7.1 has been redesignated v3.8.0, and we'll be back at alpha
stage for now.
http://megapov.inetart.net/povrayunofficial_mac/alphapov.html
Yvo
POV-Ray 3.7 unofficial: http://megapov.inetart.net/povrayunofficial_mac/
UberPOV Mac: http://megapov.inetart.net/uberpov_mac/index.html#Mac
MegaPOV: http://megapov.inetart.net
E-mail: yvo(DOT)s(AT)gmx.net
Subject: Re: PovRayUnofficial_3.8.0-alpha.9322209 for macintosh available
Date: 13 Oct 2017 16:20:00
Message: <web.59e11fc1f4864f8f1e101ef10@news.povray.org>
I just ran a few comparisons with 3.7.0-unofficial for Mac.
The first test, a pretty simple model, seemed to run significantly faster on
3.8.0.  So I tried a quite complex model.  At quality level 9 but a 320x180
output to keep run time reasonable, I see the following:
3.7.0: 5:52 total, 2727 seconds trace time (8 threads), 741770 rays
3.8.0: 4:42 total, 1829 seconds trace time (8 threads), 786430 rays
So 3.8.0 is doing a bit more work (more rays, and the detailed work listing also
show more intersection tests etc.) but it does it substantially faster.
Naturally, I don't mind, but I thought it was curious, there's nothing I saw in
the changes list that suggests this is expected.   Could it just be a better
compiler?  3.7.0 mentions  Compiler: gcc 4.2.1 Compatible Apple LLVM 6.0
(clang-600.0.54) -- the 3.8.0 message window omits that information.
There is no obvious difference in the generated output images.
Date: 14 Oct 2017 12:18:11
Message: <59e238c3$1@news.povray.org>
Le 23/09/2017 à 11:50, E-mailyvo s gmx.net a écrit :
> Copy-pase :-)
> stage for now.
Great !
Small note : Preferences from 3.7.1_Beta8 are not resumed.
Kurtz le pirate
Compagnie de la Banquise
Date: 14 Oct 2017 13:25:22
Message: <59e24882@news.povray.org>
> listing also
I see a completely different result, 3.8.0 is 5 to 6 times *slower* than 3.7.0.
Benchmark.pov scene with exactly the same settings:
3.8.0 >> 583,35 seconds
3.7.0 >> 114,76 seconds
Glasschess.pov scene:
3.8.0 >> 143,23 seconds
3.7.0 >>   23,85 seconds
A while back I noticed that 3.7.1 was a bit slower then 3.7.0 but not
as extreme as the difference between 3.7.0 and 3.8.0
I verified the compiler options and I made no mistake there, optimized
settings for release.
It would be good to know if the Windows or/and Linux version show the
same difference between 3.7.0 and 3.8.0
BTW: your 3.7.0 version isn’t the latest, “r9” from august 2017 is the
last version (compiler used is LLVM 8.1.0 (clang-802.0.42)):
http://megapov.inetart.net/povrayunofficial_mac/finalpov.html
Yvo
Date: 14 Oct 2017 13:28:39
Message: <59e24947@news.povray.org>
On 2017-10-14 16:18:10 +0000, kurtz le pirate said:
>> Copy-pase :-)
>> stage for now.
> Great !
That is no mistake, 3.8.0 is using new preferences!
Yvo
Download 'iso-8859-1' (3 KB)
Date: 14 Oct 2017 16:40:01
Message: <web.59e27586f4864f8f1e101ef10@news.povray.org>
Yes, I see that too.  On my machine, 3.7.0 (the older version, I haven't
installed the correct one yet) took 200.4 seconds trace time, while 3.8.0 took
1118.9 seconds trace time.
The model I used for those earlier results is one with many simple objects
(about 19k of them), all but about 50 are opaque.
Date: 15 Oct 2017 11:39:59
Message: <59e3814f$1@news.povray.org>
> 3.7.0.
> A while back I noticed that 3.7.1 was a bit slower then 3.7.0 but not as
> Yvo
I'm running 3.7.0 and 3.8.0 versions from early July. I see the
following results for glasschess.pov which are in line with what we
expect - a slight slowdown 3.7.0 to 3.8.0 and one which is a little
worse when threads > cores; Excepting, where new intel/amd optimized
noise is used (new to *nix compiles) and helps substantially. Where the
new noise code helps we are usually faster - though with that code too -
we have seen a few scenes coming in slower, but not run down why those
particular ones slower with the new noise code.
I am running:
Ubuntu 16.04
g++ 5.4.0 20160609
i3-4130 CPU @ 3.40GHz
On what hardware are you guys running?
What happens if you use +wt<n> to run threads<=cores?
Note. These days timing is very sensitive to how the cache(s) on the
system are being used when you do timing renders. 5-6x slower seems
extreme for cache impacts. I've seen as much as about 2x slower on a
busy system on occasion, but never more - and you are seeing similar
across multiple renders...
glasschess.pov
3.7.0
65.86user 0.03system 0:17.53elapsed  +wt4
65.97user 0.00system 0:17.53elapsed  +wt4
131.83
42.68user 0.02system 0:22.12elapsed  +wt2
43.44user 0.02system 0:22.54elapsed  +wt2
128.8
3.8.0
67.51user 0.04system 0:17.98elapsed +wt4
67.33user 0.08system 0:17.93elapsed +wt4
134.84  +2.28% slower
44.05user 0.04system 0:22.90elapsed +wt2
42.90user 0.04system 0:22.27elapsed +wt2
43.10user 0.02system 0:22.38elapsed +wt2
130.05  +0.97% slower
Perhaps related: Early this year - I think - Dick Balaska reported
seeing much, much slower results for a 3.7.1 version on linux for frames
of his animation hitting a certain linux machine in his collection of
render machines.
Bill P.
Date: 15 Oct 2017 12:46:48
Message: <59e390f7@news.povray.org>
>> Yvo
> - we have seen a few scenes coming in slower, but not run down why
> those particular ones slower with the new noise code.
> I am running:
> Ubuntu 16.04
> g++ 5.4.0 20160609
> glasschess.pov
> 3.7.0
> 131.83
> 128.8
> 3.8.0
> frames of his animation hitting a certain linux machine in his
> collection of render machines.
> Bill P.
Tanks for your report!
The slowdown is related to the new compiler version (Xcode 9), somehow
the compiler isn’t optimizing the code for this project.
I’ll revert back to Xcode 8 until I know what is causing this.
Yvo
Download 'utf-8' (7 KB)
Date: 15 Oct 2017 13:03:44
Message: <59e394f0$1@news.povray.org>
Off doing other things when I remembered years ago I did have a
situation where my other than trivial renders were running many times
slower than expected. My CPU fan had clogged & died unknown to me and my
Intel i7 throttled the CPU frequency back substantially to where it was
running right at the TDP temperature. Modern CPUs do this slow down
thing so as not to cook themselves. Older CPUs sometimes do not and I
know folks here have fried such CPUs with POV-Ray renders in the past.
The turbo feature of many CPUs complicates timing too - my i3 doesn't
have it.
Anyway, suppose just an off the wall thought maybe these huge slow downs
are due temperature and self throttling CPUs. Though that would mean
3.8.0 code runs hotter than the 3.7.0 code and enough so that the CPU
throttles down. A long shot reason I suppose, but the 5-6 slower seems
so out there given some of what you ran was faster. The -32% faster is
quite large for a 3.7 to 3.8 improvement from what I've seen that was
faster.
Bill P.
Date: 15 Oct 2017 13:08:16
Message: <59e39600$1@news.povray.org>
> Yvo
Glad you found the cause! :-)
Bill P.
