POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.9322209 Server Time
25 Apr 2026 14:24:05 EDT (-0400)
  POV-Ray v3.8.0-alpha.9322209 (Message 31 to 34 of 34)
Subject: Re: POV-Ray v3.8.0-alpha.9322209
Date: 4 Oct 2017 18:55:01
Message: <web.59d5663ed17574579c5d6c810@news.povray.org>
"omniverse" <omn### [at] charternet> wrote:
> clipka <ano### [at] anonymousorg> wrote:
> > Am 04.10.2017 um 14:20 schrieb Jim Holsenback:
> > > well i uninstalled 3.7.1 beta and put the pvengine64 into my remaining
> > > 3.7.0 bin directory and povray.chm into help directory. now the help
> > > buttons work but all i get is the left pane and none of the links are
> > > clickable ... not that big of an issue for /me/ because i prefer the
> > > html version
> > Now that's odd... can anyone confirm?
> Same thing here. Before I was going to say anything I was trying a few things to
> see if I could get it to work, such as trying to default to Internet Explorer
> rather than Windows 10 Edge.
> I used the direct link to the Help file you provided, although I had gotten that
> file from github before that and it was the same way but there were two
> different byte sizes for the files.
> Install directory is actually 3.7.0, not just 3.7 so I can only wonder if that
> has anything to do with this.
Have now tried something else. Right-click on povray.chm and go into Properties.
Under General tab is checkbox "unblock". That was a suggested fix I found on the
'net about these chm help files.
Get message when attempting that: "Too many posts were made to semaphore".
When button for Ignore is pressed, or Ignore All, nothing changes regarding
empty contents of the help file when opened next time.
Maybe this will make sense, all I know about it is what I find on the 'net and I
guess this is supposed to be about multiple calls to places within the file
going wrong somehow.
Date: 4 Oct 2017 19:10:01
Message: <web.59d56929d17574579c5d6c810@news.povray.org>
Okay, Speaking of Ignore... please disregard my previous reply below.
See if you can right-click on the povray.chm file and in Properties, on the
General tab, check the box for Unblock.
Don't Ignore or Ignore All, and instead use Try Again (if same is seen on your
Windows system), then maybe the Administrator message will pop up and you can
let that get you through this like I did.
My Help contents now appear intact. Of course, I haven't looked at it all yet
but the context help seems to be okay now (selecting a keyword and pressing F1
key) and the menu buttons for POV-Win and Scene Help show up for me after doing
the above.
> > > > html version
Date: 4 Oct 2017 20:51:27
Message: <59d5820f$1@news.povray.org>
Am 05.10.2017 um 01:05 schrieb omniverse:
> the above.
Sounds to me like the help file viewer doesn't like it when the .chm
file is flagged as "downloaded from the internet and hence potentially
unsafe".
Since this won't be a problem once we create an installer, I tend to
consider this a non-issue.
Date: 5 Oct 2017 06:27:56
Message: <59d6092c$1@news.povray.org>
thanks ... works now
