POV-Ray : Newsgroups : povray.beta-test : Linux Server Time
16 Jun 2024 15:05:38 EDT (-0400)
  Linux (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Linux
Date: 8 Apr 2017 17:22:35
Message: <58e9549b$1@news.povray.org>
On 4/8/2017 3:39 PM, Mike Horvath wrote:
> Is there a guide about usage on Linux? There is no POVray editor on
> Linux, correct? How does one load a file and then start a render? Does a
> render window appear?
> Mike
Are these instructions current?
http://www.povray.org/download/linux.php
Mike
Subject: Re: Linux
Date: 9 Apr 2017 14:41:01
Message: <58ea803d@news.povray.org>
Am 08.04.2017 um 23:23 schrieb Mike Horvath:
You will need a stand-alone editor. Any ASCII text editor will do.
To start a render, you need to run POV-Ray from the command line and
specify the file to render as well as any options, like so:
    povray -kfi1 -kff100 myanim.pov
or
    povray myscene.ini
No, they're pretty outdated.
As I said, download the package from GitHub, then follow the
instructions in `unix/README.md` within that package.
Subject: Re: Linux
Date: 9 Apr 2017 14:45:07
Message: <58ea8133$1@news.povray.org>
No, they are for installing a pre-compiled executable for version 3.6.
Some of these instructions still pertain to 3.7, though.  I first
installed to GNU/Linux in 2012, before the official release of 3.7.0, so
some of the preparation had already been done by the 3.6 install before
I installed 3.7.  If you want to install 3.6 first, then do run the
instructions as is.  For 3.7, I'll see if I can sort it out here.
1. Open a shell.
2. Create a temporary directory.
    user@machine:~> mkdir ~/povray/
    If you've already installed 3.6, you don't need to do this again
    for 3.7.
3. Get the POV-Ray for GNU/Linux binary package from the POV-Ray
    website.
    Obsolete, as there is no pre-compiled 3.7 GNU/Linux binary.
    Instead, go to https://github.com/POV-Ray/povray/tags and download
    the source code.
4. Defer.
5. Skip.
6. Unpack the distribution.
    I just use Ark.  It's easier than memorizing all those flags.
    Whichever method you use, make sure it's unpacked to its own
    version subdirectory, e.g., ~/povray/povray-3.7.1-beta.5/
4. Switch back to the shell.
7. Change into the distribution directory.
    Actually, go one further, into the Unix subdirectory:
    user@machine:~> cd ~/povray/povray-3.7.1-beta.5/unix
8. Become root.
    I prefer to use sudo rather than logging in as root.
9a. Prepare the installation environment:
     user@machine:~/povray/povray-3.7.1-beta.5/unix> ./prebuild.sh
9b. Go up to the distribution directory:
     user@machine:~/povray/povray-3.7.1-beta.5/unix> cd ..
9c. Configure the installation:
     user@machine:~/povray/povray-3.7.1-beta.5> ./configure
COMPILED_BY="Mike Horvath <mik### [at] emailcom>" LIBS="-lboost_system
-lboost_thread"
9d. Build the program and run a test render:
     user@machine:~/povray/povray-3.7.1-beta.5> make check
9e. If you want to keep to a previous version of POV-Ray, rename the
     executable:
     user@machine:~/povray/povray-3.7.1-beta.5> cd /usr/local/bin
     user@machine:/usr/local/bin> sudo mv povray povray-3.6
       (Enter the root password.)
     user@machine:/usr/local/bin> cd -
9f. Install the program:
     user@machine:~/povray/povray-3.7.1-beta.5> sudo make install
10. Leave the root environment:
     Unnecessary if you used sudo.
11. If you had previously installed POV-Ray:
     user@machine:~/povray/povray-3.7.1-beta.5> cd unix
     user@machine:~/povray/povray-3.7.1-beta.5/unix> ./install user
     I haven't done this in a while, so I'm not sure how necessary this
     is.  I have a ~/.povray/3.7 directory, and I do not know at what
     point this directory was created.
     The master povray.ini file is in this directory, and the changes I
     made to that file are *not* overwritten when I upgrade without the
     ./install user step.  However, the 3.6 and 3.7 files are in
     different directories, so whatever changes you made for 3.6, you
     will have to do them again for the 3.7 file.
12. If you are using KDE:
     user@machine:~/povray/povray-3.7.1-beta.5/unix> ./install kde
     I have not been able to get this to work in 3.7.  Jim Holsenback
     has a workaround:
http://news.povray.org/povray.binaries.utilities/thread/%3C4f4092fb%40news.povray.org%3E/
13. To test if installation was successful:
     This does not work for me, but a check was already done in
     step 9d.
14a. If you aren't already there, change to the Unix subdirectory:
14b. Cleanup after the installation:
      user@machine:~/povray/povray-3.7.1-beta.5/unix> ./prebuild clean
Subject: Re: Linux
Date: 9 Apr 2017 22:18:50
Message: <58eaeb8a$1@news.povray.org>
> 1. Open a shell.
>    for 3.7.
>    website.
>    the source code.
Thanks so much for the help! One more thing I want to know is how do I
download the source using only a terminal window? I am using a Google
Cloud VM and they allow only SSH terminal access I think.
Mike
Subject: Re: Linux
Date: 9 Apr 2017 22:56:45
Message: <58eaf46d$1@news.povray.org>
> Mike
I am doing some additional research in case there's a way to connect to
the instance using some GUI tool that allows me to see the dekstop.
Mike
Subject: Re: Linux
Date: 10 Apr 2017 00:50:37
Message: <58eb0f1d$1@news.povray.org>
I found out that the Debian VMs Google uses have no desktop. So I will
just use Windows as per normal.
Mike
Subject: Re: Linux
Date: 10 Apr 2017 00:56:39
Message: <58eb1087$1@news.povray.org>
I also just found out when trying to set up a VM that you have to
"upgrade" your account (i.e. don't use a free trial account) to use more
than 8 CPU cores. :(
Mike
Subject: Re: Linux
Date: 10 Apr 2017 01:03:43
Message: <58eb122f@news.povray.org>
>>    the source code.
$ wget https://github.com/POV-Ray/povray/archive/v3.7.1-beta.5.tar.gz
Subject: Re: Linux
Date: 10 Apr 2017 17:36:46
Message: <58ebfaee$1@news.povray.org>
> Mike
Correction: 8 threads on 4 cores.
Mike
Subject: Re: Linux
Date: 8 May 2017 08:41:34
Message: <5910677e@news.povray.org>
This should be ./prebuild.sh clean
