Am 2017-04-02 02:50, also sprach dick balaska:
> D:\Projekte\POV-Ray Build Stage\windows\vs2015\bin64\pvengine64.pdb
Here is the call stack of the crash for starters.
povconsole64d.exe!_free_dbg(void * block, int block_use) Line 1009 C++
[External Code]
povconsole64d.exe!pov::Parser::Destroy_Ident_Data(void * Data, int Type)
Line 9343 C++
povconsole64d.exe!pov::Parser::Test_Redefine(int Previous, int *
NumberPtr, void * Data, bool allow_redefine) Line 9570 C++
povconsole64d.exe!pov::Parser::Parse_RValue(int Previous, int *
NumberPtr, void * * DataPtr, pov::Sym_Table_Entry * sym, bool ParFlag,
bool SemiFlag, bool is_local, bool allow_redefine, bool allowUndefined,
int old_table_index) Line 9121 C++
povconsole64d.exe!pov::Parser::Parse_Declare(bool is_local, bool
after_hash) Line 8804 C++
povconsole64d.exe!pov::Parser::Parse_Directive(int After_Hash) Line 2331 C++
povconsole64d.exe!pov::Parser::Get_Token() Line 458 C++
povconsole64d.exe!pov::Parser::Parse_Frame() Line 6809 C++
povconsole64d.exe!pov::Parser::Run() Line 220 C++
povconsole64d.exe!pov::Task::TaskThread(const boost::function0<void> &
completion) Line 168 C++
povconsole64d.exe!boost::_mfi::mf1<void,pov::Task,boost::function0<void>
const & __ptr64>::operator()(pov::Task * p, const boost::function0<void>
& a1) Line 166 C++
povconsole64d.exe!boost::_bi::list2<boost::_bi::value<pov::Task *
__ptr64>,boost::_bi::value<boost::function0<void> >
>::operator()<boost::_mfi::mf1<void,pov::Task,boost::function0<void>
const & __ptr64>,boost::_bi::list0>(boost::_bi::type<void> __formal,
boost::_mfi::mf1<void,pov::Task,boost::function0<void> const &> & f,
boost::_bi::list0 & a, int __formal) Line 320 C++
povconsole64d.exe!boost::_bi::bind_t<void,boost::_mfi::mf1<void,pov::Task,boost::function0<void>
const & __ptr64>,boost::_bi::list2<boost::_bi::value<pov::Task *
__ptr64>,boost::_bi::value<boost::function0<void> > > >::operator()()
Line 1295 C++
povconsole64d.exe!boost::detail::thread_data<boost::_bi::bind_t<void,boost::_mfi::mf1<void,pov::Task,boost::function0<void>
__ptr64>,boost::_bi::value<boost::function0<void> > > > >::run() Line
117 C++
povconsole64d.exe!boost::`anonymous
namespace'::thread_start_function(void * param) Line 296 C++
povconsole64d.exe!invoke_thread_procedure(unsigned int(*)(void *)
procedure, void * const context) Line 92 C++
povconsole64d.exe!thread_start<unsigned int (__cdecl*)(void *
__ptr64)>(void * const parameter) Line 115 C++
dik
The stack for this crash on the unix verison.
(gdb) r ttto.ini +sf100 +ef120
Starting program: /home/dick/povray/povray/unix/povray ttto.ini +sf100
+ef120
Persistence of Vision(tm) Ray Tracer Version 3.7.1-beta.5.unofficial
(g++ 5.4.0
@ x86_64-pc-linux-gnu)
Thread 6 "povray" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffef967700 (LWP 6407)]
__GI___libc_free (mem=0x34) at malloc.c:2949
2949 malloc.c: No such file or directory.
(gdb) back
#0 __GI___libc_free (mem=0x34) at malloc.c:2949
#1 0x00000000005165ee in pov::Parser::Parse_RValue
(this=this@entry=0x7fffe8004db0, Previous=Previous@entry=67,
NumberPtr=NumberPtr@entry=0x7fffdc0ac480,
DataPtr=DataPtr@entry=0x7fffdc0ac478,
sym=sym@entry=0x0, ParFlag=ParFlag@entry=false, SemiFlag=true,
is_local=true, allow_redefine=true, allowUndefined=true,
old_table_index=100) at parser/parser.cpp:9315
#2 0x00000000005179b8 in pov::Parser::Parse_Declare
(this=this@entry=0x7fffe8004db0, is_local=<optimized out>,
after_hash=<optimized out>) at parser/parser.cpp:8804
#3 0x000000000061fa07 in pov::Parser::Parse_Directive
(this=this@entry=0x7fffe8004db0, After_Hash=After_Hash@entry=1) at
parser/parser_tokenizer.cpp:2330
#4 0x000000000061b1b3 in pov::Parser::Get_Token
(this=this@entry=0x7fffe8004db0) at parser/parser_tokenizer.cpp:456
#5 0x0000000000620609 in pov::Parser::Get_Token
(this=this@entry=0x7fffe8004db0) at parser/parser_tokenizer.cpp:323
#6 0x0000000000518978 in pov::Parser::Parse_Frame (this=0x7fffe8004db0)
at parser/parser.cpp:6809
#7 0x0000000000519424 in pov::Parser::Run (this=0x7fffe8004db0) at
parser/parser.cpp:217
#8 0x00000000004a54d5 in pov::Task::TaskThread (this=0x7fffe8004db0,
completion=...) at backend/support/task.cpp:168
#9 0x00007ffff70ae5d5 in ?? () from
/usr/lib/x86_64-linux-gnu/libboost_thread.so.1.58.0
#10 0x00007ffff63e26ba in start_thread (arg=0x7fffef967700) at
pthread_create.c:333
#11 0x00007ffff611882d in clone () at
../sysdeps/unix/sysv/linux/x86_64/clone.S:109
(gdb)
Am 2017-04-06 01:56, also sprach dick balaska:
I found it.
#range (Start, End)
#local V=
#break
I tried this code, but it correctly gives me an "RValue expected"
#version 3.7;
#switch (1)
#range (0,1)
#local V=
#break
So, here's another uber-trimmed tteoac.
wget http://www.buckosoft.com/tteoac/video/ttcrash2.bz2
tar -xvjf ttcrash2.bz2
cd ttto
povray ttto.ini -sf100 -ef100
Note in ttto/direct.inc line 133
#local _v=
If you comment that out, it doesn't crash
(It also won't render much, because everything is gone)
dik
Am 06.04.2017 um 09:39 schrieb dick balaska:
Whines about "beatdebug.inc" missing.
Am 2017-04-06 04:24, also sprach clipka:
with -sf100 -ef100?
dik
Fixed cut/paste instructions (was a bad cd)
cd ttcrash2/ttto
My theory from the stack trace was that it gave up on a #declare's
rvalue, and double freed it. That seems to be likely.
This crash also is in 3.7.0, which is what runs when I paste the above
into ubuntu.
dik
Am 06.04.2017 um 10:31 schrieb dick balaska:
> with -sf100 -ef100?
Ah, sorry. Forgot that.
Crashes now. Which is neat, because it means it's reproducible ;)
Am 06.04.2017 um 10:44 schrieb dick balaska:
> cd ttcrash2/ttto
No, not exactly.
It turns out that the "switch" construct around the incomplete
declaration is irrelevant; it's the "#include" that's working the magic.
The recipe for desaster is as follows:
<start of "local" scope>
#local <Identifier> = <Valid RValue>
<end of "local" scope>
<Valid RValue>
For example, the following also causes a crash:
#macro Foo()
#local Bar=1;
#local Bar=
Foo()
sphere {<0,0,0>,1}
The end of local scope causes the identifier and its content to be
ditched, but the code responsible for parsing `#local` statements tries
to ditch the content again in order to replace it with the new content.
Am 06.04.2017 um 12:08 schrieb clipka:
> <Valid RValue>
> #macro Foo()
> #local Bar=1;
> #local Bar=
> #end
> Foo()
> sphere {<0,0,0>,1}
The same kind of crash can also be triggered with the following construct:
#declare Foo=1;
#declare Foo=
#undef Foo
sphere {<0,0,0>,1}
Now tracked on GitHub as issue #265
(https://github.com/POV-Ray/povray/issues/265).
