POV-Ray : Newsgroups : povray.beta-test : Windows XP (or Server 2003) testing required Server Time
13 May 2024 22:10:32 EDT (-0400)
  Windows XP (or Server 2003) testing required (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Windows XP (or Server 2003) testing required
Date: 4 Mar 2017 02:54:23
Message: <58ba72af$1@news.povray.org>
Am 04.03.2017 um 01:27 schrieb clipka:
> Am 03.03.2017 um 20:20 schrieb clipka:
>> Hi folks,
>> I'd like to ask those of you who are still using (or have access to)
>> Windows XP (or Windows Server 2003), either 32 or 64 bit, to test-drive
>> the following binaries:
>> http://wiki.povray.org/clipka-files/povray-3.7.1-beta.3-140xp-Win32.zip
>> http://wiki.povray.org/clipka-files/povray-3.7.1-beta.3-140xp-Win32-sse2.zip
>> http://wiki.povray.org/clipka-files/povray-3.7.1-beta.3-140xp-Win64.zip
> Update - I have reason to expect the above to not work properly; please
> test the following instead:
> http://wiki.povray.org/clipka-files/povray-3.7.1-beta.3-140xp2-Win32.zip
> http://wiki.povray.org/clipka-files/povray-3.7.1-beta.3-140xp2-Win32-sse2.zip
> http://wiki.povray.org/clipka-files/povray-3.7.1-beta.3-140xp2-Win64.zip
They say three time's a charm:
http://wiki.povray.org/clipka-files/povray-3.7.1-beta.3-140xp3-Win32.zip
http://wiki.povray.org/clipka-files/povray-3.7.1-beta.3-140xp3-Win64.zip
Let's ignore the SSE2 variant for now, as it needs some additional fixing.
>> All binaries need a pre-existing installation of 3.7.1-beta.3, and are
>> intended as drop-in replacements for the beta.3's binaries.
>> Please test whether these binaries run on XP at all, and if so, give
>> them a thorough shakedown.
>> In particular, please pay attention whether the binaries exhibit any of
>> the following two symptoms previously observed by StephenS with some
>> development builds:
>> - `Warning: did not find colors.inc` being reported at program start
>> - `pvengine.ini` getting overwritten at each program start
Date: 4 Mar 2017 04:02:47
Message: <58ba82b7@news.povray.org>
Am 04.03.2017 um 08:54 schrieb clipka:
While you're at it, if the above DO work nicely, please also give these
a try:
https://github.com/POV-Ray/povray/releases/download/untagged-04eb64a1a50902498e61/povray-3.7.1-x.140_xp-av390-Win32.7z
https://github.com/POV-Ray/povray/releases/download/untagged-04eb64a1a50902498e61/povray-3.7.1-x.140_xp-av390-Win64.7z
(presuming you can download them; I'm not sure if that's the case)
Date: 4 Mar 2017 06:06:14
Message: <58ba9fa6$1@news.povray.org>
Working fine, on to other test file.
Stephen S
Date: 4 Mar 2017 06:19:35
Message: <58baa2c7$1@news.povray.org>
The link gives me a 404 error, web page not found.
Stephen S
Date: 4 Mar 2017 07:34:21
Message: <58bab44d$1@news.povray.org>
Am 04.03.2017 um 01:41 schrieb StephenS:
> pvengine32.exe still showing both.
> pvengine32-sse2.exe not starting for my processor.
BTW, what Service Pack of XP are you running?
Date: 4 Mar 2017 08:03:40
Message: <58babb2c$1@news.povray.org>
SP3
Stephen S
Date: 4 Mar 2017 10:35:24
Message: <58badebc$1@news.povray.org>
See post in p.b-t.binaries.
Stephen S
Date: 12 Mar 2017 16:09:30
Message: <58c5aafa$1@news.povray.org>
XP testing is once again highly welcome:
http://wiki.povray.org/clipka-files/pvengine32_XP_20170312.7z
http://wiki.povray.org/clipka-files/pvengine64_XP_20170312.7z
The former carries both 32-bit vanilla and 32-bit SSE2. The latter
carries the 64-bit version.
As before (except read "beta.4" instead of "beta.3"):
> development builds:
Date: 13 Mar 2017 17:29:20
Message: <58c70f30$1@news.povray.org>
Seems to be working, including current cmedit32-sse2.dll.
Stephen S
Date: 13 Mar 2017 18:02:23
Message: <58c716ef$1@news.povray.org>
Am 13.03.2017 um 22:29 schrieb StephenS:
Thanks. I think that should wrap up the topic of Visual Studio 2015 vs.
XP compatibility.
Starting with the next beta, the project files as available from GitHub
will not build XP-compatible binaries "out of the box" anymore (as it
turned out to make typical custom builds overly complicated); however,
instructions will be included on how to achieve XP-compatibility with a
more complex build process, which we'll also use for the official builds
(* Future development (alpha) builds may be an exception, as we'll
presumably be using the AppVeyor automated build service again for
those, and they might not allow to customize the build process to the
extent necessary.)
