POV-Ray : Newsgroups : povray.beta-test : beta.3 and ./ and ../ weirdness Server Time
15 May 2026 13:53:20 EDT (-0400)
  beta.3 and ./ and ../ weirdness (Message 1 to 6 of 6)
Subject: beta.3 and ./ and ../ weirdness
Date: 19 Feb 2017 20:33:09
Message: <58aa4755$1@news.povray.org>
I was going to whip off some frames from a project development directory
and beta.3 tells me
File 'reeferMagnets.inc' line 169: Possible Parse Error: Cannot find file
  '../../ttCommon/ariali.ttf', even after trying to append file type
extension.
File 'reeferMagnets.inc' line 169: Possible Parse Error: Cannot open
font file.
alpha-8451792 renders this fine.
relevant code:
  36	#declare TtCommonDir="../../ttCommon/";
141	#declare ArialiFont=concat(TtCommonDir, "ariali.ttf");
165	text {
166		ttf ArialiFont
167		"Hi mom"
168		0.15,0
169		scale 3.6
170		translate <31*inches,36*inches,0>
171		pigment {Black}
172	}
I also see that "./subdir/include.inc" also fails.  I didn't notice this
last night, because I had changed the prefix directory to "" instead of
This is weird, my farm has run 100 frames on beta.3 and my production
code contains "../ttCommon/ariali.ttf" (one level back).
I thought I'd create a 3 file tar demonstrating this, except it doesn't
fail.
This renders fine:
#declare dir="../../";
#include concat(dir, "include.inc")
So, I'm still confused. Schrödinger's bug: it's both broken and not broken.
dik
Subject: Re: beta.3 and ./ and ../ weirdness
Date: 20 Feb 2017 07:29:45
Message: <58aae139@news.povray.org>
> and beta.3 tells me
> extension.
> font file.
> relevant code:
> 165    text {
> 166        ttf ArialiFont
> 167        "Hi mom"
> 168        0.15,0
> 169        scale 3.6
> 171        pigment {Black}
> 172    }
> fail.
> This renders fine:
Windows, linux or both OSs showing the hard "./subdir/include.inc"
fails? Can you get to a small test case for this one?
Windows, linux or both OSs showing the flaky "../../ttCommon" behavior?
Thanks.
Bill P.
Date: 22 Feb 2017 15:48:18
Message: <58adf912$1@news.povray.org>
Am 20.02.2017 um 02:33 schrieb dick balaska:
> extension.
> font file.
I figured out where this comes from...
... but this is puzzling me, because I know I've fixed it in commit
9cf8a79 (2017-02-16). Can you please double-check this one? Otherwise I
would have to wonder whether the beta.3 installer really contains what's
tagged as beta.3 on GitHub.
The problem only arises with relative paths that effectively go two
levels up (or more) from whatever is considered the base directory at
that point.
> fail.
> This renders fine:
Let me guess: There also happens to be an "include.inc" in the current
directory?
Also, just for clarity: Am I right in assuming that this all happens
only on the Windows machine?
We'll see whether it can be explained with a hidden variables theory.
Date: 22 Feb 2017 23:43:39
Message: <58ae687b$1@news.povray.org>
Am 2017-02-22 15:48, also sprach clipka:
>> extension.
>> font file.
Yay. For a minute I thought it was another manifestation of the stack
woes, what with the broken/not broken behavior.
povconsole64-9cf8a79.exe fails.
povconsole64-63e9b8ad.exe works. (The 2017-02-22 location of
origin/release/v3.7.1)
Oh wait. I meant "../../" works. Re-reading before pressing send, I see
you meant specifically "./" .  Let me re-check...
Yes, "./" works on 9cf8a79 on povconsole64.  I'm not sure what I was
looking at the other day.  "./" also works inside of your built povwin
beta.3 .
I could have sworn I saw it fail there.  I blame pebkac.
>> fail.
>> This renders fine:
> directory?
Nah, "3 files"  ttfail.ini, ttfail.pov, and ../../subdir/include.inc
(I thought maybe 'down 2 and up 1')
I also tried it with a .ttf .
I was shocked it worked. I thought I was going to have to do the "start
with the whole project and prune away everything" thing again.
"only" is a strong word.
My preferred geek workflow is to develop on Windows and deploy on Linux.
I can run eclipse (povclipse, c++) on Ubuntu, but under the cygwin/x
server, it looks poopy. (kbreakout looks/plays great, though ;) )
I just tried it on Linux.  "./" and "../../" work on beta.3 .
dik
Date: 23 Feb 2017 07:43:36
Message: <58aed8f8$1@news.povray.org>
Am 23.02.2017 um 05:43 schrieb dick balaska:
>>> fail.
>>> This renders fine:
>> directory?
That's seriously puzzling, unless the directory in which "include.inc"
resides also happens to be one of your include directories.
Because when processing the `#include` statement beta.3 will erroneously
collapse `../../include.inc` to `incldue.inc`, and unless POV-Ray
happens to find some `include.inc` in one of the paths it looks at (the
directory of the including scene, as well as all include directories) it
should complain that it doesn't find the file.
Date: 23 Feb 2017 08:08:51
Message: <58aedee3$1@news.povray.org>
Am 2017-02-23 07:43, also sprach clipka:
pebkac.
I'm sure of it. For all I know, I up-arrowed to a povray-alpha and it
worked.
dik
