POV-Ray : Newsgroups : povray.beta-test : Public Beta Release v3.7.1-beta.2 Server Time
26 Jul 2026 09:45:35 EDT (-0400)
  Public Beta Release v3.7.1-beta.2 (Message 11 to 20 of 46)
Subject: Re: Public Beta Release v3.7.1-beta.2
Date: 12 Jan 2017 12:06:39
Message: <5877b79f$1@news.povray.org>
On 01/11/2017 07:02 PM, LanuHum wrote:
>>> I have another computer. AMD (1 kernel,1 thread) Povray has not been set. It was
>>> the first compilation.
>>> ...../configure --prefix=/usr COMPILED_BY=Lanuhum  no problem
>>> make no problem
>>> make install no problem
>>> run povray - problem
>> There is little we can do if all the feedback we get is "run povray -
>> problem".
>> /What/ problem?
> While only I see it:
> Error in `/usr/bin/povray': free(): invalid next size (fast): 0x00007f2ff0017120
$ man 3 mallopt
    can give some help for trying to solve the problem...
> Creation of the source code takes a lot of time.
> In my free time, I try more...
Date: 13 Jan 2017 06:28:56
Message: <f0fbf391-a557-8f5e-c92a-f3c935d3e437@nomail.com>
On 11/01/2017 12:59 AM, clipka wrote:
> POV-Ray 3.7.1 has now officially entered public beta testing phase.
> Source code and Windows binaries are available on GitHub:
> https://github.com/POV-Ray/povray/releases/tag/v3.7.1-beta.2
> (beta.1 was an internal release only.)
> The beta version is designed to install in its own dedicated directory,
> and live happily alongside an existing 3.7 installation.
> Happy testing!
Will we be supporting WinXP 32 anymore?
A quick test suggests the render works, may have problems with editor.
More testing on Sunday morning local time.
Stephen S
Date: 13 Jan 2017 06:30:35
Message: <5878ba5b$1@news.povray.org>
> Happy testing!
Stephen S
Date: 13 Jan 2017 07:30:31
Message: <5878c867$1@news.povray.org>
Am 13.01.2017 um 12:30 schrieb StephenS:
>> Happy testing!
To all my current knowledge, the beta versions should work fine with XP.
In contrast to the alpha development binary-only builds, which were a
byproduct of automated build testing using a 3rd party service running
Visual Studio 2015 (which we couldn't get to spit out fully XP-comatible
binaries), the beta release was lovingly hand-crafted with good old
Visual Studio 2010, and we intend to do the same for all further 3.7.1
releases (betas, RCs and final release).
As for 32 bit, the installer contains all three binaries (32 bit, 32 bit
SSE2, and 64 bit) and should pick the one most appropriate for your machine.
Thus, should you encounter any problems with the beta on a 32 bit
Windows XP, please do let us know, as that would be unintentional.
Hm... I'll have to check with Chris whether he also used Visual Studio
2010 for the beta editor DLLs. (The beta does need its own version of
the DLLs to not interfere with an existing installation of 3.7.0 proper.
Other than that they should be interchangeable, though the beta DLLs
also contain some bugfixes.)
Date: 13 Jan 2017 14:50:18
Message: <58792f7a@news.povray.org>
Am 13.01.2017 um 13:30 schrieb clipka:
Chris just informed me that the editor DLLs have been built with Visual
Studio 2015, so they may or may not work on XP. Please do let us know
how you're faring.
Date: 14 Jan 2017 09:20:34
Message: <587a33b2$1@news.povray.org>
> Happy testing!
well since i'm not a doze user perhaps it's just me but ... this release
seems to be having trouble honoring the Display = On option in the
master povray.ini file as well as having it in a povray.ini file in the
directory that the povray sdl file resides. In order to get a render
display i have to add +d in toolbar command line. btw: it (beta) is
reading all the other options (library path) options that i have in the
Date: 14 Jan 2017 10:28:15
Message: <587a438f$1@news.povray.org>
also stumbled upon a windows docs issue as well ...
in 3.2.4.1 output file type towards the bottom in the paragraph that
starts as: The Radiance Synthetic Imaging System ... there are two
external links: Radiance  and  OpenEXR. the Radiance link opens up the
web page inside the windows help viewer, the OpenEXR link opens up the
web age in default web /browser/ OpenEXR also appears as >>OpenEXR
also have a look from 2.5.6 --> to the bottom of that page there is a
mix of external links that exhibit the same behavior ... links that are
preceded by >> open up the web page in default web browser and the links
/without/ >> open web page inside the windows help viewer.
looked on the wiki and /all/ links markup are consistent and the nix
docs look fine (no >> anywhere) so i'm guessing it's regex issue in the
post processing that creates the doze docs
Date: 14 Jan 2017 10:39:05
Message: <587a4619$1@news.povray.org>
make that from 2.5.1
Date: 14 Jan 2017 11:28:31
Message: <587a51af$1@news.povray.org>
> how you're faring.
On WinVista home premium sp2 64-bit
All three POV-Ray application files run fine, no problems noted.
pvengine, pvengine-sse2, pvengine64(default).
On WinXP sp3 32-bit
pvengine and pvengine-sse2(default), POV-Ray runs fine, the editor has
problems opening a file tab.
 From windows_explorer, click-hold-drag drop on editor works, new tab is
opened.
Menu/File/recently used list, select, new tab is opened.
Open icon, select file - open, no new tab is opened.
Menu/File/Open, select file - open, no new tab is opened.
Still working through some combinations.
Stephen S
Date: 14 Jan 2017 13:33:11
Message: <587a6ee7$1@news.povray.org>
Am 14.01.2017 um 17:28 schrieb StephenS:
>> how you're faring.
> On WinXP sp3 32-bit
> opened.
Don't bother -- it doesn't work properly on XP, that's all we need to
know for now. This is (in all likelyhood) not a matter of identifying
and fixing problematic source code, but of choosing the right build
settings (or even the right compiler version).
