POV-Ray : Newsgroups : povray.beta-test : More To Test Server Time
18 May 2024 08:37:21 EDT (-0400)
  More To Test (Message 11 to 19 of 19)
Subject: Re: More To Test
Date: 26 Nov 2016 07:02:18
Message: <583979ca$1@news.povray.org>
On 11/26/2016 6:14 AM, Jim Holsenback wrote:
> On 11/25/2016 11:41 AM, Jim Holsenback wrote:
>> On 11/25/2016 11:20 AM, clipka wrote:
>>> Am 25.11.2016 um 16:30 schrieb Jim Holsenback:
>>>> On 11/25/2016 10:21 AM, clipka wrote:
>>>>> Am 25.11.2016 um 15:29 schrieb Jim Holsenback:
>>>>>> Error: Bad operands for period operator.
>>>>>> #local Pt1 = Vec + x*(OTO_Get_Offset(Vec).x) +
>>>>>> y*(OTO_Get_Offset(Vec+x).y);
>>>>> Need more input -- what is OTO_Get_Offset(..)?
>>>> it's in sam's odd tiles marco ... attached is complete include
>>> It's a bug in OTO_Get_Offset(), which had previously been lying somewhat
>>> dormant, but has now been exposed.
>> come again ... are we looking at the same thing?
>> in the include file i'm seeing:
>> #macro OTO_Get_Offset(Cell)
>>   #local CX = Cell.x;
>>   #local CY = Cell.y;
>>   (1-Bev*2)*<1,1,0>*(.5-OTO_FOffs(CX,CY,0))
>> #end
> no help?!?
if it's /in/ the OTO_Get_Offset macro then why does commenting out the
.y and .x notation (after the call to macro) get rid of the error:
#if(OTO_Get_Mask(Vec)=1 )
      #local Pt1 = Vec + y*(OTO_Get_Offset(Vec)/*.y*/) +
x*(OTO_Get_Offset(Vec+y)/*.x*/);
      #local Pt2 = Vec + y*(OTO_Get_Offset(Vec+x+y)/*.y*/) +
x*(OTO_Get_Offset(Vec-y+x+y)/*.x*/) +x+y;
     #else
      #local Pt1 = Vec + x*(OTO_Get_Offset(Vec)/*.x*/) +
(y*OTO_Get_Offset(Vec+x)/*.y*/);
      #local Pt2 = Vec + x*(OTO_Get_Offset(Vec+x+y)/*.x*/) +
y*(OTO_Get_Offset(Vec-x+x+y)/*.y*/) +x+y;
Date: 26 Nov 2016 08:17:37
Message: <58398b71$1@news.povray.org>
Am 26.11.2016 um 12:14 schrieb Jim Holsenback:
>>   #local CX = Cell.x;
>>   #local CY = Cell.y;
>> #end
> no help?!?
Give me a few moments -- I can't /always/ respond lightning-fast ;)
Date: 26 Nov 2016 08:25:34
Message: <58398d4e$1@news.povray.org>
>>>> somewhat
>>>   #local CX = Cell.x;
>>>   #local CY = Cell.y;
>>> #end
>> no help?!?
>     #else
>     #end
I'm working with the "corner finding" portion of the include. added the
following:
      #local Pt1 = Vec + y*(OTO_Get_Offset(Vec).y) +
x*(OTO_Get_Offset(Vec+y).x);
      #local Pt2 = Vec + y*(OTO_Get_Offset(Vec+x+y).y) +
x*(OTO_Get_Offset(Vec-y+x+y).x) +x+y;
     #else
      #debug concat ("\nResults: <", vstr(3, Pt1,",",5,6),">\n")
      #local Pt2 = Vec + x*(OTO_Get_Offset(Vec+x+y).x) +
y*(OTO_Get_Offset(Vec-x+x+y).y) +x+y;
debug echos a 3-way vector ... so what's wrong with the expectation of
getting the dot product using the notation given. the while loop that
encloses the above conditional eventually sends it through both branches
and begins to render after commenting  out all the offending notation.
quick visual inspection doesn't reveal any problems with the odd tiles
Date: 26 Nov 2016 08:31:20
Message: <58398ea8@news.povray.org>
Am 26.11.2016 um 13:02 schrieb Jim Holsenback:
>>>> somewhat
>>>   #local CX = Cell.x;
>>>   #local CY = Cell.y;
>>> #end
>> no help?!?
> ..y and .x notation (after the call to macro) get rid of the error:
>     #else
>     #end
The problem is rooted in how POV-Ray macros work: They're not
/functions/, but essentially "SDL code generators".
So if I have a macro
      #local CX = Cell.x;
      #local CY = Cell.y;
then the macro invocation
does /not/ first compute the macro and then take the y component of the
result:
    // intended result
    y*((  (1-Bev*2)*<1,1,0>*(.5-OTO_FOffs(CX,CY,0))  ).y)
Instead, the body of the macro is essentially just pasted in:
    // actual result
    y*(  (1-Bev*2)*<1,1,0>*(.5-OTO_FOffs(CX,CY,0))  .y)
which -- obviously, once you format it a bit differently -- is something
entirely different:
    y*(  (1-Bev*2)  *  <1,1,0>  *  (.5-OTO_FOffs(CX,CY,0)).y  )
Now if you drop the `.y`, what you get is:
    y*(  (1-Bev*2)  *  <1,1,0>  *  (.5-OTO_FOffs(CX,CY,0))  )
which /happens/ to give exactly the same result as the intended
function, because given a vector V,
    y*(V.y)
aka
    <0,1,0>*(V.y)
scalar-to-vector promotion turns this into:
    <0,1,0>*<V.y,V.y,V.y>
which results in
    <0,V.y,0>
which happens to be the same as
    <0,1,0>*<V.x,V.y,V.z>
which is equivalent to
    <0,1,0>*V
aka
    y*V
The proper solution is to redefine the macro to include the intended
parentheses:
      #local CX = Cell.x;
      #local CY = Cell.y;
Date: 26 Nov 2016 08:35:54
Message: <58398fba$1@news.povray.org>
Am 26.11.2016 um 14:30 schrieb clipka:
> parentheses:
>       #local CX = Cell.x;
>       #local CY = Cell.y;
>     #end
... or use the "result variable" idiom:
      #local CX = Cell.x;
      #local CY = Cell.y;
      #local result = (1-Bev*2)*<1,1,0>*(.5-OTO_FOffs(CX,CY,0));
      result
Date: 26 Nov 2016 10:13:06
Message: <5839a682$1@news.povray.org>
>> parentheses:
>>       #local CX = Cell.x;
>>       #local CY = Cell.y;
>>     #end
>       #local CX = Cell.x;
>       #local CY = Cell.y;
>       result
>     #end
yes that's what i ended up doing, but got distracted (woof) with
something else before i could reply. i'm trying to make sure i
understand the pathology here ... earlier in this thread a bug was
mentioned. the array/dictionary changes exposed the issue? devils
advocate would say that this should be documented as a {{Change}} ...
i'm guessing somewhere in the array talk page that's been currently
reworked?
Date: 26 Nov 2016 11:26:20
Message: <5839b7ac$1@news.povray.org>
Am 26.11.2016 um 16:13 schrieb Jim Holsenback:
> reworked?
No, the array/dictionary changes are not to blame (not for this at any
rate; despite the dictionary syntax also happening to use dot notation).
Instead, the change that "broke" it was commit fa4a158, "Fix promotion
bug (#130)", which fixed this bug:
http://news.povray.org/3c4bb31d$1@news.povray.org
In my opinion there is no {{Change}} to be documented: The new behaviour
matches what has always been in the docs, and what people have always
been expecting -- if it wasn't for the mucking around with macros; it is
the fundamental way macros work (which hasn't changed a jot) that
constitutes the only potentially surprising element in this context. It
is the same mechanism that has always been the potential source of
surprise in coce such as:
    #macro Sum(A,B,C)
      A+B+C
    #declare X = Sum(1,2,3)*3;
That thing has never worked as intended, so why should anyone expect the
`.y` operator to behave any different in this respect?
Date: 27 Nov 2016 07:35:20
Message: <583ad308$1@news.povray.org>
hmmm ... well i guess then we are left with agreeing to disagree
Date: 27 Nov 2016 10:40:29
Message: <583afe6d$1@news.povray.org>
Am 27.11.2016 um 13:35 schrieb Jim Holsenback:
What change, in particular, would you be documenting then?
