POV-Ray : Newsgroups : povray.beta-test : Wavefront OBJ import Server Time
28 Mar 2024 18:06:35 EDT (-0400)
  Wavefront OBJ import (Message 11 to 20 of 31)
Subject: Re: Wavefront OBJ import
Date: 15 Sep 2016 13:18:57
Message: <57dad801$1@news.povray.org>
Le 15/09/2016 à 18:59, William F Pokorny a écrit :
> On 09/15/2016 12:03 PM, Jim Holsenback wrote:
>> On 9/15/2016 7:13 AM, William F Pokorny wrote:
>>> FYI - A new object in the "lemon" is in the master branch and not yet
>>> documented in povray's documentation. Jérôme has some documentation for
>>> it already on his page at:
>> it's been added http://wiki.povray.org/content/Reference:Lemon
>> looks like the opening paragraph could use some help so I also created a
>> talk page as well: http://wiki.povray.org/content/Reference_Talk:Lemon
> Thanks. I've attempted some descriptive text at:
> Bill P.
I like it, but the introducing description is a bit harsh for the
non-mathematically-addicted.
So I added a bit in the discussion too
Date: 15 Sep 2016 18:34:03
Message: <57db21db$1@news.povray.org>
a combination of both: http://wiki.povray.org/content/Reference:Lemon
Date: 16 Sep 2016 04:08:40
Message: <57dba888$1@news.povray.org>
I really liked the passage about the american football and other real
evocations. It gave flesh to the description.
The constraint on minimal inner_radius is really a dangerous beast:
If base & cap radius are both 0, the inner_radius must be at least half
the distance between base and cap point (it would be a sphere)
So, as stated, the doc is false.
If base & cap radius are identical, the minimal inner_radius would be
sqrt( radius² + (distance/2)² ) , where distance is the length between
base and cap points.
when base & cap radius are different, it become nightmare (the exact
equation is in the code, if you dare to want to know it).
Date: 16 Sep 2016 08:53:23
Message: <57dbeb43$1@news.povray.org>
no worries /but/ i wish you'd been as verbose with your previous post
... however i see a bit of a conflict (perhaps i've characterized
incorrectly) item 4 and 5 seem a bit murky or are the /both/ correct:
Date: 16 Sep 2016 09:33:21
Message: <57dbf4a1@news.povray.org>
Argh. Sorry Jim. I got the wording for what I believe is the lower-most
bound for the inner radius wrong. I had in my head only to offer general
guidance there.
Adding the full equations is an option I guess - we do for other objects
in the docs. If we stick with a general description, we could build on
what you, Jérôme, wrote with perhaps:
the distance between base and cap point (it would be a sphere).
Otherwise the minimum inner radius is larger than half the distance
between base and cap point. Any time the inner radius given is too
small, the code uses the minimum radius over the specified one and
issues a warning.
Bill P.
Date: 16 Sep 2016 09:49:12
Message: <57dbf858$1@news.povray.org>
I believe we need to delete the following list item (me originally
leading you wrong I think):
* generally speaking Inner_Radius must be greater than or equal to the
distance between end points
or change it to:
* generally speaking the Inner_Radius must be greater than or equal to
half the distance between end points
Bill P.
Date: 16 Sep 2016 10:41:14
Message: <57dc048a$1@news.povray.org>
> guidance there.
like i said ... no worries
sticking with general description
> issues a warning.
i /think/ i've got it this time:
Date: 16 Sep 2016 12:05:09
Message: <57dc1835$1@news.povray.org>
>> guidance there.
>> issues a warning.
I added yet another comment in the discussion.
Date: 17 Sep 2016 08:57:10
Message: <57dd3da6$1@news.povray.org>
Date: 17 Sep 2016 09:52:39
Message: <57dd4aa7$1@news.povray.org>
Suggesting a correction and further tweak at bottom of the page:
Bill P.
