POV-Ray : Newsgroups : povray.beta-test : Wavefront OBJ import Server Time
25 Apr 2026 08:43:08 EDT (-0400)
  Wavefront OBJ import (Message 1 to 10 of 31)
Subject: Wavefront OBJ import
Date: 13 Sep 2016 20:08:07
Message: <57d894e7$1@news.povray.org>
Source code:
https://github.com/c-lipka/povray/tree/feature/obj_import
Syntax is as follows:
    mesh {
      obj FILENAME
      [ OBJ_TEXTURE_LIST ]
      [ inside_vector VECTOR ]
    OBJ_TEXTURE_LIST:
      texture_list {
        [ OBJ_TEXTURE_LIST_ITEM ... ]
    OBJ_TEXTURE_LIST_ITEM:
      STRING texture { TEXTURE } |   (A)
      STRING material { TEXTURE } |
      prefix STRING |                (B)
      suffix STRING
At present, associated .mtl files will /not/ be evaluated; instead,
textures must be defined using one of the following means:
(A) in the texture_list, as a list of the individual material names as
used in the .obj file and the respective texture definition to use; or
(B) before the `mesh` statement, by defining texture variables with
corresponding names. For some ease of use, a pre- and suffix can be
defined that will be added to the material name as used in the .obj file.
For additional ease of use, materials can be used instead of textures;
however, in that case only the texture is taken from the material, while
the interior_texture and interior are ignored.
e.g.
    #declare MyTexture = texture { ... }
    #declare MyMaterial = material { ... }
    mesh {
      obj "MyMesh.obj"
      texture_list {
        "Foo" texture { MyTexture }
        "Bar" material { MyMaterial }
        prefix "Tx"
        suffix "_"
      inside_vector y
will map the material name "Foo" in the .obj file to `MyTexture` and the
material name "Bar" to `MyMaterial`, while any other name, say, `Fnord`
or `Uqbar`, would be mapped to `TxFnord_` and `TxUqbar_`, respectively.
OBJ import provides rudimentary support for non-triangular polygons, but
currently just blindly cuts up such polygons into triangles, relying on
the polygons to be nicely planar and convex. This may also affect the
apparent curvature of such polygons.
That said, I have a hunch that someone might like this feature.
Subject: Re: Wavefront OBJ import
Date: 14 Sep 2016 01:20:00
Message: <web.57d8ddb5d98a4381a1334c0c0@news.povray.org>
[snip]
Excellent! This will be very useful. Almost everything can export to obj, so
this immediately improves workflow for any project that uses a third-party
modeller.
Presumably the slight increase in read speed over mesh2 stems from the fact that
..obj is slightly less verbose in its syntax?
Bill
Date: 14 Sep 2016 03:39:51
Message: <57d8fec7$1@news.povray.org>
Am 14.09.2016 um 07:18 schrieb Bill Pragnell:
> clipka <ano### [at] anonymousorg> wrote:
> [snip]
> modeller.
That of course depends on the quality of the exporter. If it exports
poor meshes, with flipped normals and stuff, an external tool like
PoseRay is still recommended.
> ...obj is slightly less verbose in its syntax?
Exactly.
Date: 14 Sep 2016 16:10:19
Message: <57d9aeab$1@news.povray.org>
It's been documented: http://wiki.povray.org/content/Reference:Mesh
I also created a talk page in case it's needed.
Date: 14 Sep 2016 16:40:42
Message: <57d9b5ca$1@news.povray.org>
Am 14.09.2016 um 22:10 schrieb Jim Holsenback:
Thanks; I guess I'll have to hurry to integrate it into the official
branch then ;)
Date: 14 Sep 2016 17:43:40
Message: <57d9c48c$1@news.povray.org>
> branch then ;)
why the limitation of interior when material is used? that would leave
out a glass object just to name one
Date: 14 Sep 2016 18:52:24
Message: <57d9d4a8$1@news.povray.org>
Am 14.09.2016 um 23:43 schrieb Jim Holsenback:
>> branch then ;)
Because POV-Ray's architecture currently doesn't support different
interiors in a single primitive (which may not even make much sense),
and OBJ import is currently designed to generate a single mesh.
You can always add an interior to the entire mesh as part of the
OBJECT_MODIFIERS.
Date: 15 Sep 2016 07:13:30
Message: <57da825a$1@news.povray.org>
Now I know who has the real power to get things into the master branch :-).
FYI - A new object in the "lemon" is in the master branch and not yet
documented in povray's documentation. Jérôme has some documentation for
it already on his page at:
   http://wiki.povray.org/content/User:Le_Forgeron#Lemon
Unsure if on yours or Jérôme's todo list. If I can help in some way
update the docs for the lemon, let me know.
Bill P.
Date: 15 Sep 2016 12:03:23
Message: <57dac64b@news.povray.org>
it's been added http://wiki.povray.org/content/Reference:Lemon
looks like the opening paragraph could use some help so I also created a
talk page as well: http://wiki.povray.org/content/Reference_Talk:Lemon
Date: 15 Sep 2016 12:59:06
Message: <57dad35a$1@news.povray.org>
Thanks. I've attempted some descriptive text at:
Bill P.
