POV-Ray : Newsgroups : povray.beta-test : Texture testing needed Server Time
26 Jul 2026 15:43:12 EDT (-0400)
  Texture testing needed (Message 41 to 43 of 43)
Subject: Re: Texture testing needed
Date: 6 Sep 2016 17:37:45
Message: <57cf3729$1@news.povray.org>
On 09/06/2016 06:33 AM, William F Pokorny wrote:
> I'm off to try this latest refactor/texture with additional scenes -
> especially some with meshes.
> Bill P.
To the Good.
Found another material (NK0304) which with the latest refactor/texture
is now aligned with 3.7.0-stable results where "specular 0.01 roughness
0.25" coupled with "brilliance 0.85" had been giving slightly different
results.
Bill P.
Date: 7 Sep 2016 04:44:30
Message: <57cfd36e@news.povray.org>
> Bill P.
A reminder for others doing texture testing.
The documentation warns turbulence modifiers not wrapped in a warp{}
blocks might not run in SDL apparent order or even the same order as
other modifiers over time. I've run down a set of my own texture testing
differences to this cause.
A source code change after 3.7.0-stable and sometime before (B -
167ed19) causes 'some' materials I've picked up over time to appear
differently where turbulence is not specified in a warp {} block.
In other words, code such as:
    wood turbulence 0.135 omega 0.65 lambda 3
    color_map {...}
    rotate <0,90,0>
    scale <1,0.2,0.2>
    rotate <0,0.5,10>
Needs to be written as something like:
    wood
    color_map {...}
    warp { turbulence 0.135 omega 0.65 lambda 3 }
    rotate <0,90,0>
    scale <1,0.2,0.2>
    rotate <0,0.5,10>
If one wants such textures to appear exactly the same in 3.7.1 as 3.7.0.
Bill P.
Date: 7 Sep 2016 05:34:25
Message: <57cfdf21$1@news.povray.org>
> Bill P.
Attached is a modified case eliminating previously seen differences
leaving a difference where we have only specular highlights defined for
the surface. There is some slight difference in the shadows A (3.7.0)
->B (167ed19) which persists in all later versions.
Bill P.
Download 'nk0314__f.pov.txt' (4 KB) Download 'storynk0314_norad.jpg' (124 KB)
Preview of image 'storynk0314_norad.jpg'
