POV-Ray : Newsgroups : povray.beta-test : animations (2 in 1) Server Time
16 Feb 2026 03:03:29 EST (-0500)
  animations (2 in 1) (Message 1 to 5 of 5)
Subject: animations (2 in 1)
Date: 6 Mar 2016 04:48:06
Message: <56dbfcd6$1@news.povray.org>
I'm using float1 as an example.
Part 1 - Render output: float1.ini
8< snip >8
   OpenEXR and IlmBase, Copyright (c) 2002-2011 Industrial Light & Magic.
Most likely detected an unquoted string with spaces in INI file.
Assuming string ends at the of the line.
Make sure all strings with spaces are properly quoted in the INI file.
Use either " or ' to quote strings. For details, please check the user
manual!
manual!
Rendering frame 1 of 51
Parser Options
8< snip >8
Please note the double output. This is only happening for the 1st frame.
Part 2 - Most likely detected an unquoted string...
8< snip >8
Input_File_Name=float1.pov
8< snip >8
It works. But why not using Input_File_Name="float1.pov" to avoid
irritations ?
Thorsten aka ThH
povray --V
POV-Ray 3.7.1-alpha.8508492.unofficial
Subject: Re: animations (2 in 1)
Date: 6 Mar 2016 07:48:35
Message: <56dc2723@news.povray.org>
Am 06.03.2016 um 10:49 schrieb ThH:
> manual!
> manual!
> 8< snip >8
> 8< snip >8
> irritations ?
Just noticed something is different in float1.ini:
8< snip >8
Test_Abort_Count=50
8< snip >8
There's a space-sign behind Test_Abort_Count=50 8)
Removed it and so got rid of this Most-likely-output :)
So please forget about the original Part 2.
The new Part 2 asks only for removing 1 space-sign ;))
Date: 6 Mar 2016 08:42:23
Message: <56dc33bf$1@news.povray.org>
Am 06.03.2016 um 13:49 schrieb ThH:
Related, so I add this question here.
fractalzoom.pov rendered using the the .ini with subset...
8< snip >8
Initial_Frame=1
Final_Frame=60
Initial_Clock=0
Final_Clock=1
Subset_Start_Frame=11
Subset_End_Frame=30
8< snip >8
The render output shows
8< snip >8
Rendering frame 1 of 20
8< snip >8
How about making it this way?
Rendering frame 11 of 60
or even
Rendering frame 11 of 60 (subset frame 11 to 30)
Please have in mind this is a question. Nothing more, nothing less :)
Date: 28 Apr 2016 20:24:56
Message: <5722a9d8$1@news.povray.org>
Am 06.03.2016 um 14:43 schrieb ThH:
> 8< snip >8
> Initial_Frame=1
> Final_Frame=60
> Initial_Clock=0
> Final_Clock=1
> Subset_End_Frame=30
> 8< snip >8
> 8< snip >8
> 8< snip >8
> or even
I'll be going for
    Rendering frame 1 of 20 (#11)
Also, while I'm at it, if you use `Frame_Skip=2` (or whatever), it will
no longer go
    Rendering 1 of 20
    Rendering 3 of 20
    Rendering 5 of 20
but
    Rendering 1 of 10 (#11)
    Rendering 2 of 10 (#13)
    Rendering 3 of 10 (#15)
I think this most concisely reports the key pieces of information you
(well, a typical user at any rate) might be interested in while
rendering an animation:
- How is work progressing?
- What's the total workload?
- Which particular frame is currently being worked on?
(As a matter of fact, a corresponding new version can already be found
at https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8586521)
Date: 1 May 2016 07:16:15
Message: <5725e57f$1@news.povray.org>
Am 29.04.2016 um 02:24 schrieb clipka:
> I'll be going for
> no longer go
>      Rendering 1 of 20
>      Rendering 3 of 20
>      Rendering 5 of 20
> but
Better. Fine :)
Next on my ToDo-List...
