Am 04.03.2016 um 19:01 schrieb Le_Forgeron:
> Le 04/03/2016 17:22, William F Pokorny a écrit :
>> Same here. The patch disappears in 3.7.1-alpha.8499454 while it works in
3.7.0-stable.
> Testing 3.7.1-alpha.8503825.unofficial, the object is there, same as with stable
version.
While I did my own testing with 3.7.1-alpha.8503825 as well, I'd be
quite surprised if any of the changes since alpha.8499454 had fixed it.
They appear to be as unrelated as I could possibly imagine.
Am 04.03.2016 um 18:59 schrieb clipka:
> Hey, it's an issue reported by ThH. _Of course_ it works perfectly fine
> on Windows >_<
Haha :D
No reason for me to change the OS ;))
Just hoping it's your natural interest to get it fixed for Linux users :))
3.7.0-stable.
version.
Think you are correct. I just pulled and compiled 3.7.1-alpha.8503825 on
seeing Jérôme at a newer version, but still nothing (no ray patch
intersections are found). So maybe a 14.04 vs 15.1 difference ?
My compiler is g++ 4.8.
Bill P.
3.7.0-stable.
version.
> Think you are correct. I just pulled and compiled 3.7.1-alpha.8503825 on seeing
Jérôme at a newer version, but still nothing (no ray patch intersections are found).
Nope, even with a produced "right" picture, valgrind reports a definitive problem of
uninitialised data.
Just ignore the syscall param write, the interesting parts seem to be in bezier.cpp
I presume even windows get the same problem if you have some auditing tools on it.
And using the same valgrind on the stable version: no such issue.
It's new, it's fresh, it's hidden and unreliable, due to the memory content.
Download 'memcheck2.txt' (48 KB)
Am 04.03.2016 um 19:25 schrieb ThH:
>> on Windows >_<
> Haha :D
It is. But alas! ...
Well, you probably know the drill: Toy around and try to figure out
/some/ useful information.
@Jerome: Care to do some "binary search" again to narrow down the
offending version?
(Let me guess: It's that range of commits again that refuses to compile
on Linux, right?)
Am 04.03.2016 um 19:51 schrieb Le_Forgeron:
uninitialised data.
If valgrind was right, that would certainly explain the problems.
Unfortunately it's mistaken.
Valgrind's report indicates that Bezier_Node_Struct::Radius_Squared is
not (or not always) initialized properly when
BicubicPatch::bezier_tree_walker() is called.
But if that is the case, then adding
Node->Radius_Squared = -1;
to BicubicPatch::create_new_bezier_node() and adding
POV_ASSERT(Node->Radius_Squared >= 0);
to the beginning of BicubicPatch::bezier_tree_walker() should force the
code to bomb.
It doesn't. Valgrind must be seeing ghosts.
Am 05.03.2016 um 08:54 schrieb clipka:
SIR YESSSS SIR... Just had some other things to do... SIR !
8< snip >8
//bicubic_patch { type 1 flatness 0.1 u_steps 8 v_steps 8
bicubic_patch { type 0 flatness 0.1 u_steps 8 v_steps 8
8< snip >8
Line 1: no_image effect ;)
Line 2: 8D
SIR!
Time for breakfast here...
Am 05.03.2016 um 10:11 schrieb ThH:
SOLDIER, I don't remember having ordered you to do OTHER THINGS!
> 8< snip >8
> 8< snip >8
> Line 2: 8D
Does that mean "it works"?
Am 05.03.2016 um 10:19 schrieb clipka:
Sir soldier used it's brain SIR !
>> Line 2: 8D
Yes.
of uninitialised data.
> code to bomb.
I do not say that the Radius_Squared is not initialized...
but adding
memset(Node, 0, sizeof(BEZIER_NODE));
in create_new_bezier_node does remove the issue with valgrind.
Now, remember that we are using -O3 as default level of optimisation,
which means the execution can be reported on line X while the compiler
is actually performing some operations of line X-1 or X+1.
And we are dealing with an hybride code: the declaration of Bezier_Node_Struct is a
100% C++ thing,
with an implicit constructor that would call Véctor3d constructor for Center,
yet create_new_bezier_node is a C thing, calling a memory allocator and casting the
type.
The other members of Bezier_Node_Struct are still C thing, so they are not
initialised.
Nevertheless, for Center, the code that computes it has been "optimised".
Instead of using a temporary variable, initialised to 0 (xc, yc, zc), to add the
various contributions
and then copying the result in Center at the end, the function now add directly the
to Center. But what if... you start with *garbage* in Center ? Garbage in, Garbage
out.
(it's in bezier_bounding_sphere() )
And to finish it (give me a hammer, that's the last nail on the coffin):
If I replace the memset over the whole structure with just (in addition to Data_Ptr =
NULL):
Node->Center = Vector3d();
valgrind become as happy as with the full initialisation.
Even a bigger hammer: if I use memset with a value of 0xFF (instead of 0), I get a
100% background image.
Reliably.
