Am 04.03.2016 um 19:25 schrieb ThH:
> Am 04.03.2016 um 18:59 schrieb clipka:
>> Hey, it's an issue reported by ThH. _Of course_ it works perfectly fine
>> on Windows >_<
> Haha :D
> No reason for me to change the OS ;))
> Just hoping it's your natural interest to get it fixed for Linux users :))
It is. But alas! ...
Well, you probably know the drill: Toy around and try to figure out
/some/ useful information.
@Jerome: Care to do some "binary search" again to narrow down the
offending version?
(Let me guess: It's that range of commits again that refuses to compile
on Linux, right?)
Am 04.03.2016 um 19:51 schrieb Le_Forgeron:
> Le 04/03/2016 19:41, William F Pokorny a écrit :
> Nope, even with a produced "right" picture, valgrind reports a definitive problem of
uninitialised data.
If valgrind was right, that would certainly explain the problems.
Unfortunately it's mistaken.
Valgrind's report indicates that Bezier_Node_Struct::Radius_Squared is
not (or not always) initialized properly when
BicubicPatch::bezier_tree_walker() is called.
But if that is the case, then adding
Node->Radius_Squared = -1;
to BicubicPatch::create_new_bezier_node() and adding
POV_ASSERT(Node->Radius_Squared >= 0);
to the beginning of BicubicPatch::bezier_tree_walker() should force the
code to bomb.
It doesn't. Valgrind must be seeing ghosts.
Am 05.03.2016 um 08:54 schrieb clipka:
SIR YESSSS SIR... Just had some other things to do... SIR !
8< snip >8
//bicubic_patch { type 1 flatness 0.1 u_steps 8 v_steps 8
bicubic_patch { type 0 flatness 0.1 u_steps 8 v_steps 8
8< snip >8
Line 1: no_image effect ;)
Line 2: 8D
SIR!
Time for breakfast here...
Am 05.03.2016 um 10:11 schrieb ThH:
SOLDIER, I don't remember having ordered you to do OTHER THINGS!
> 8< snip >8
> 8< snip >8
> Line 2: 8D
Does that mean "it works"?
Am 05.03.2016 um 10:19 schrieb clipka:
Sir soldier used it's brain SIR !
>> Line 2: 8D
Yes.
of uninitialised data.
> code to bomb.
I do not say that the Radius_Squared is not initialized...
but adding
memset(Node, 0, sizeof(BEZIER_NODE));
in create_new_bezier_node does remove the issue with valgrind.
Now, remember that we are using -O3 as default level of optimisation,
which means the execution can be reported on line X while the compiler
is actually performing some operations of line X-1 or X+1.
And we are dealing with an hybride code: the declaration of Bezier_Node_Struct is a
100% C++ thing,
with an implicit constructor that would call Véctor3d constructor for Center,
yet create_new_bezier_node is a C thing, calling a memory allocator and casting the
type.
The other members of Bezier_Node_Struct are still C thing, so they are not
initialised.
Nevertheless, for Center, the code that computes it has been "optimised".
Instead of using a temporary variable, initialised to 0 (xc, yc, zc), to add the
various contributions
and then copying the result in Center at the end, the function now add directly the
to Center. But what if... you start with *garbage* in Center ? Garbage in, Garbage
out.
(it's in bezier_bounding_sphere() )
And to finish it (give me a hammer, that's the last nail on the coffin):
If I replace the memset over the whole structure with just (in addition to Data_Ptr =
NULL):
Node->Center = Vector3d();
valgrind become as happy as with the full initialisation.
Even a bigger hammer: if I use memset with a value of 0xFF (instead of 0), I get a
100% background image.
Reliably.
> Reliably.
That did the trick.
Found the culprit and about to submit a fix any moment now.
ThH <no.spam@address> wrote:
> I don't see a bicubic_patch 8[
Please test the newest master.
POV-Ray 3.7.1-alpha.8508492.unofficial seems ok, at least for valgrind (but I was only
getting small artefacts, randomly)
Good to be back on news.povray.org:119 !
Am 05.03.2016 um 17:37 schrieb clipka:
Bezier is fine now. Thanks clipka :))
Thorsten aka ThH
povray --V
