POV-Ray : Newsgroups : povray.beta-test : bezier.pov Server Time
26 Jul 2026 11:26:12 EDT (-0400)
  bezier.pov (Message 17 to 26 of 26)
Subject: Re: bezier.pov
Date: 6 Mar 2016 01:20:03
Message: <web.56db04ff8ece4badc77518d0@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> Even a bigger hammer: if I use memset with a value of 0xFF (instead of 0), I get a
100% background image.
> Reliably.
That did the trick.
Found the culprit and about to submit a fix any moment now.
Message: <web.56db0b418ece4badc77518d0@news.povray.org>
ThH <no.spam@address> wrote:
> I don't see a bicubic_patch 8[
Please test the newest master.
Date: 6 Mar 2016 03:18:01
Message: <56dbe7b9$1@news.povray.org>
POV-Ray 3.7.1-alpha.8508492.unofficial seems ok, at least for valgrind (but I was only
getting small artefacts, randomly)
Date: 6 Mar 2016 03:19:15
Message: <56dbe803$1@news.povray.org>
Good to be back on news.povray.org:119 !
Am 05.03.2016 um 17:37 schrieb clipka:
Bezier is fine now. Thanks clipka :))
Thorsten aka ThH
povray --V
Date: 6 Mar 2016 03:25:11
Message: <56dbe967$1@news.povray.org>
Am 06.03.2016 um 09:18 schrieb Le_Forgeron:
only getting small artefacts, randomly)
Does it also affect the Leak Summary?
Date: 6 Mar 2016 03:31:19
Message: <56dbead7$1@news.povray.org>
Am 06.03.2016 um 09:20 schrieb ThH:
bezier.pov shows some artefacts.
flatness seems to have some influence on this. Lower flatness, less/no
artefacts.
Just to let you know ;)
Date: 6 Mar 2016 03:42:12
Message: <56dbed64@news.povray.org>
If you want more details about the leak, attached file was done with:
valgrind --log-file=memcheckpovray2.txt --track-origins=yes --leak-check=full dmpovray
bezier.pov
Download 'memcheckpovray2.txt' (24 KB)
Date: 6 Mar 2016 03:46:10
Message: <56dbee52$1@news.povray.org>
Am 06.03.2016 um 09:32 schrieb ThH:
> artefacts.
Thin lines?
They're normal, and the flatness parameter is indeed the setting to
counteract them.
Date: 6 Mar 2016 03:47:35
Message: <56dbeea7$1@news.povray.org>
dmpovray bezier.pov
And to compare with the stable head, another attached file.
It was less leaking before :-)
Download 'memcheckpovray.txt' (6 KB)
Date: 6 Mar 2016 04:09:43
Message: <56dbf3d7$1@news.povray.org>
Am 06.03.2016 um 09:46 schrieb clipka:
> Thin lines?
Yes.
> counteract them.
Looked up the docs. That's why I tried this ;)
To be honest... I've never used bicubic_patch before.
For me the image is fine :)
The 'rest' is yours.
Only citing valgrind here: Go fix your program! ;))
