POV-Ray : Newsgroups : povray.beta-test : Semi-official development build v3.7.1-alpha.8004333 Server Time
25 Oct 2025 16:17:09 EDT (-0400)
  Semi-official development build v3.7.1-alpha.8004333 (Message 1 to 10 of 10)
Subject: Semi-official development build v3.7.1-alpha.8004333
Date: 21 Mar 2015 09:59:05
Message: <550d7929$1@news.povray.org>
This build should fix the issues reported about the tuple-style assignment:
https://github.com/c-lipka/povray/releases/tag/v3.7.1-alpha.8004333
Subject: Re: Semi-official development build v3.7.1-alpha.8004333
Date: 28 Mar 2015 08:04:28
Message: <551698cc@news.povray.org>
some problems building ...
parser/parser.cpp: In member function ‘void
pov::Parser::Parse_Declare(bool, bool)’:
parser/parser.cpp:8225:18: error: template argument for ‘template<class
_Tp> class std::allocator’ uses local type
‘pov::Parser::Parse_Declare(bool, bool)::LValue’
parser/parser.cpp:8225:18: error:   trying to instantiate
‘template<class _Tp> class std::allocator’
parser/parser.cpp:8225:18: error: template argument 2 is invalid
parser/parser.cpp:8225:27: error: invalid type in declaration before ‘;’
token
parser/parser.cpp:8382:17: error: request for member ‘push_back’ in
‘lvalues’, which is of non-class type ‘int’
parser/parser.cpp:8384:39: error: request for member ‘size’ in
parser/parser.cpp:8423:45: error: request for member ‘size’ in
parser/parser.cpp:8424:37: error: request for member ‘size’ in
parser/parser.cpp:8426:40: error: invalid types ‘int[int]’ for array
subscript
parser/parser.cpp:8427:33: error: invalid types ‘int[int]’ for array
subscript
parser/parser.cpp:8428:35: error: invalid types ‘int[int]’ for array
subscript
parser/parser.cpp:8429:39: error: invalid types ‘int[int]’ for array
subscript
parser/parser.cpp:8443:37: error: request for member ‘size’ in
parser/parser.cpp:8445:40: error: invalid types ‘int[int]’ for array
subscript
parser/parser.cpp:8446:33: error: invalid types ‘int[int]’ for array
subscript
parser/parser.cpp:8447:35: error: invalid types ‘int[int]’ for array
subscript
parser/parser.cpp:8448:39: error: invalid types ‘int[int]’ for array
subscript
Date: 29 Mar 2015 09:26:03
Message: <5517fd6b$1@news.povray.org>
Am 28.03.2015 um 13:04 schrieb James Holsenback:
>> assignment:
Ah, somehow I had a feeling that might cause problems.
Can you try pulling the definition of "struct LValue" out of the
function and see whether that fixes all the errors?
Date: 29 Mar 2015 12:16:37
Message: <55182565@news.povray.org>
>>> assignment:
Well it was much more involved than that ... after commenting out the
struct LValue definition it started belching on lvalves. I found the
appropriate set up for that in the previous version (alpha.7981337) file.
Attached is the ~source/parser/parser.ccp file that ended up compiled
successfully.
Download 'us-ascii' (300 KB)
Date: 30 Mar 2015 08:51:24
Message: <551946cc$1@news.povray.org>
Am 29.03.2015 um 18:16 schrieb James Holsenback:
Sorry, misunderstanding - what I meant was placing the "struct LValue"
definition before the function rather than inside it, not removing it
entirely.
Date: 30 Mar 2015 10:12:38
Message: <551959d6$1@news.povray.org>
> entirely.
I pulled struct LValue out of the function and placed it just before the
function and no joy, so I went up to the top of the file just inside the
namespace pov specification. In both cases the error was the same:
parser/parser.cpp:8217:9: error: ‘Token_Struct’ does not name a type
parser/parser.cpp:8378:16: error: ‘struct pov::LValue’ has no member
named ‘token’
parser/parser.cpp:8426:42: error: ‘struct pov::LValue’ has no member
named ‘token’
parser/parser.cpp:8445:42: error: ‘struct pov::LValue’ has no member
named ‘token’
Even though this didn't make sense to do so I then moved it just above
the namespace pov definition (after the last include) and there was more
fallout, so I think that confirms my initial assumption that it didn't
make sense:
parser/parser.cpp:104:9: error: ‘Token_Struct’ does not name a type
parser/parser.cpp:106:9: error: ‘SYM_ENTRY’ does not name a type
parser/parser.cpp:8378:16: error: ‘struct LValue’ has no member named
‘token’
parser/parser.cpp:8379:16: error: ‘struct LValue’ has no member named
‘tempEntry’
parser/parser.cpp:8426:42: error: ‘struct LValue’ has no member named
‘token’
parser/parser.cpp:8428:37: error: ‘struct LValue’ has no member named
‘tempEntry’
parser/parser.cpp:8445:42: error: ‘struct LValue’ has no member named
‘token’
parser/parser.cpp:8447:37: error: ‘struct LValue’ has no member named
‘tempEntry’
Date: 30 Mar 2015 14:18:10
Message: <55199362$1@news.povray.org>
>> assignment:
Current official master should fix the Unix build issues.
Date: 30 Mar 2015 18:09:48
Message: <5519c9ac$1@news.povray.org>
>>> assignment:
indeed it does ...
ash@linux-c2bm:~/ScratchPad/povray $ povray --version
POV-Ray 3.7.1-alpha.8017570.unofficial
Date: 2 Apr 2015 15:20:00
Message: <web.551d951b842ddb803b28a4800@news.povray.org>
There still seems to be problems. Please try this:
// POV-Ray: v 3.7.1-alpha.8004333.unofficial.msvc10(?)
// Binary: pvengine64.exe
// OS: Windows 8.1 (64 bits)
// CPU: AMD A8-6410
#declare A = array[3];
#declare A[0] = 1;
#declare A[1] = A[0];
// "Parse Error: Attempted to redefine float identifier as array identifier."
#declare A[2] = array[1] { 1 };
#declare E = A;
// "Unfortunately, it appears that a memory access violation at address
// 0x00007FFBE6F3262B has caused this unofficial POV-Ray build to crash."
#declare (A[0], A[1], A[2], E) = (1, A[0], array[1] { 1 }, A);
Tor Olav
http://subcube.com
Date: 4 Apr 2015 11:47:25
Message: <5520078d$1@news.povray.org>
Am 02.04.2015 um 21:14 schrieb Tor Olav Kristensen:
> // CPU: AMD A8-6410
> #declare A[0] = 1;
> #declare E = A;
*sigh!*
Looks like this whole thing is a deal more complicated than it first
seemed...
