POV-Ray : Newsgroups : povray.beta-test : Syntax extension: Passing multiple values out of a macro Server Time
28 Mar 2026 19:01:24 EDT (-0400)
  Syntax extension: Passing multiple values out of a macro (Message 1 to 10 of 12)
Subject: Syntax extension: Passing multiple values out of a macro
Date: 28 Feb 2015 20:51:35
Message: <54f270a7$1@news.povray.org>
I've just implemented a syntax extension that you might like: As of the
newest development version, you'll now be able to assign multiple
variables with a single #declare (or #local) statement, like so:
   #declare (A,B,C) = (X,Y,Z);
Obviously, this now allows for a single macro to return multiple items,
like this:
   #macro WindowFrameAndCutout(Pos,H,W)
     #local Frame  = union {...};
     #local Cutout = box {...};
     (Frame,Cutout,Area)
   #declare (MyFrame,MyCutout) = WindowFrameAndCutout(...);
How's that? :D
Subject: Re: Syntax extension: Passing multiple values out of a macro
Date: 1 Mar 2015 03:27:23
Message: <54f2cd6b$1@news.povray.org>
> like this:
>      (Frame,Cutout,Area)
>    #end
> How's that? :D
Probably neat, but I confess I do not really understand the example and
what it does...
Date: 1 Mar 2015 03:30:04
Message: <54f2ce0c@news.povray.org>
>      (Frame,Cutout,Area)
>    #end
You are returning three values and assigning them into two identifiers?
Date: 1 Mar 2015 13:05:25
Message: <54f354e5$1@news.povray.org>
Am 01.03.2015 um 09:30 schrieb Warp:
>>       (Frame,Cutout,Area)
>>     #end
Whoops :) - that should have been:
     #declare (MyFrame,MyCutout,MyArea) = WindowFrameAndCutout(...);
Date: 1 Mar 2015 13:12:38
Message: <54f35696@news.povray.org>
Am 01.03.2015 um 09:27 schrieb Thomas de Groot:
>> like this:
Sorry, forgot some part of the code (I guess I was a bit tired):
         #local Area   = H*W;
>>      (Frame,Cutout,Area)
>>    #end
       #declare (MyFrame,MyCutout,MyArea) = ...
>> How's that? :D
> what it does...
Suppose you have a set of macros to generate architecture; in such a
framework, for windows you'll want both the windows itself, as well as a
shape to cut a matching hole into the wall. And for some reason you
might also be interested in knowing the area of the window, though I
confess I just put it in there just to demonstrate that you can return
values of different types.
Date: 2 Mar 2015 09:50:01
Message: <web.54f47877c9a0646a16086ed00@news.povray.org>
> >> like this:
>          #local Area   = H*W;
> >>      (Frame,Cutout,Area)
> >>    #end
> >> How's that? :D
> > what it does...
I like it. It looks like some Python feature was it an inspiration?
Date: 2 Mar 2015 10:12:42
Message: <54f47dea$1@news.povray.org>
Am 02.03.2015 um 15:49 schrieb Mr:
No, just general tuple-ish syntax.
Date: 3 Mar 2015 03:07:22
Message: <54f56bba$1@news.povray.org>
Yes, I understand the principle but - as is always the case with my slow
brain - I shall need to play with it in order to fully understand the
potentials :-)
Date: 16 Mar 2015 00:00:01
Message: <web.55065426c9a0646ac90a82220@news.povray.org>
> like this:
>      (Frame,Cutout,Area)
>    #end
> How's that? :D
That's great !
I really hope that it also works with functions, arrays, transforms, vectors,
cameras, light sources, materials etc. I.e. everything that be stored in a
variable.
Tor Olav
http://subcube.com
Date: 16 Mar 2015 00:31:20
Message: <55065c98$1@news.povray.org>
Am 16.03.2015 um 04:55 schrieb Tor Olav Kristensen:
> variable.
I wouldn't dare to raise my head with this otherwise :) (I haven't
tested most of them, but the implementation is simple enough to be
confident about it.)
