POV-Ray : Newsgroups : povray.beta-test : master branch issue 29 linux compilation errors Server Time
15 May 2026 22:11:34 EDT (-0400)
  master branch issue 29 linux compilation errors (Message 41 to 41 of 41)
Subject: Re: master branch issue 29 linux compilation errors
Date: 7 Jul 2014 12:51:05
Message: <53bacff9$1@news.povray.org>
Am 06.07.2014 13:18, schrieb clipka:
> I finally found out what's going on here.
> The implementation of adaptive area lights uses an N*M cache for
> "lightlet" data it has already computed. Previously, yet-uncomputed data
> was flagged by setting the respective colour's red channel to -1. I had
> changed this to use a NaN ("Not-a-Number") value instead, to avoid
> problems when a user deliberately sets a light source's colour to
> negative red.
> Now of course this NaN value has to be tested for; according to IEEE
> standard, a NaN value has the property that it is non-equal to anything,
> even itself. So I wrote the test: "if (red != red)...".
> Well, it turns out that the g++ compiler optimizes this comparison away
> when in "-ffast_math" mode.
Solved as follows:
Configure will now test whether NaNs and/or Infinities are available for
both double and single precision, survive conversion between the two
types, and can be tested for.
Attempted ways to test for NaNs include std::isnan(), global isnan(), or
comparison of the value with itself (or, more precisely, a volatile copy
thereof, to prevent the test from being optimized away).
Attempted ways to test for Infinities include std::isnan(), global
isnan(), or comparison of the value's absolute with the highest finite
value representable by the respective type (or, more precisely, a
volatile copy thereof, to prevent the test from being optimized away).
If NaNs are available, survive type conversion and are testable, those
will be used to mark a colour as invalid.
Otherwise, if Infinities are available, survive type conversion and are
testable, negative infinity will be used instead.
Otherwise, as a last resort, the negative of the highest finite value
representable by single-precision float will be used instead.
On g++ with -ffast_math, it turns out that negative infinity is a viable
option; while isinf() is dysfunctional as expected, infinities do
survive type conversion and can be tested for by comparing the value's
absolute with the highest finite value representable.
