POV-Ray : Newsgroups : povray.beta-test : master branch issue 29 linux compilation errors Server Time
15 May 2026 19:57:33 EDT (-0400)
  master branch issue 29 linux compilation errors (Message 21 to 30 of 41)
Subject: Re: master branch issue 29 linux compilation errors
Date: 2 Jul 2014 13:22:50
Message: <53b43fea@news.povray.org>
Am 02.07.2014 18:44, schrieb Le_Forgeron:
> Yes. Compile, link, run.
> * make check : ok for the 3 (g++, icpc, clang++)
> Yet, it seems gcc (only) is too fast on benchmark. (4 seconds on 12 threads)
> Rendering benchmark gives the attached pictures (the icpc seems ok,
> within usual time, but gcc is bogus and too fast, far too fast)
Did you do a clean build for the gcc version? Maybe one of the earlier
builds left some crap behind.
If the bug persists even with a clean build, please open a new issue on
GitHub, as we're no longer talking about build problems now.
Date: 2 Jul 2014 13:23:23
Message: <53b4400b@news.povray.org>
Le 02/07/2014 19:19, clipka nous fit lire :
> Am 02.07.2014 19:07, schrieb Le_Forgeron:
>> Le 02/07/2014 12:04, clipka nous fit lire :
>>> While you're at it, could you please do me a favour and also try
>>> building the new "feature/colour_model" branch? I did some nasty
>>> template stuff there, and need to know if the Linux compilers can digest
>>> it.
>> You're welcome, until my soon-to-be-holidays (very soon now!).
>> g++ does not like it.
>> clang++ neither.
>> And icpc is not better.
>> All of them get a problem with ">>" in template.. it should be "> >" to
>> avoid ambiguity with >> operator... so it fails. But even correcting
>> that is not enough.
>> The error log of gcc and icpc are past the 1.8MBytes (the largest is 7
>> MBytes)... so I just attach the clang one.
> Can you please give me the output with ">>" corrected to "> >"? Thanks a
> lot!
Here it is, attached.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Download 'errorcolourcl2.txt' (555 KB)
Date: 2 Jul 2014 13:25:00
Message: <53b4406c$1@news.povray.org>
Le 02/07/2014 19:22, clipka nous fit lire :
>> threads)
I rebuilt it two times. So the issue is on its way. :-)
Date: 2 Jul 2014 13:37:38
Message: <53b44362$1@news.povray.org>
Am 02.07.2014 19:23, schrieb Le_Forgeron:
>> lot!
Thanks. Next incarnation of feature/colour_model is ready for testing.
Date: 2 Jul 2014 13:52:25
Message: <53b446d9$1@news.povray.org>
Am 02.07.2014 19:25, schrieb Le_Forgeron:
>>> threads)
 From what you wrote earlier, I take it that the biscuits scene renders
fine.
Can you narrow down which feature causes the problems in the benchmark
scene? Photons? Media? Radiosity?
It would also be helpful if you could figure out which version was the
last one that compiled & rendered ok. (If the one after that still
compiled ok, but rendered bogus, that would also be useful to know.)
Date: 2 Jul 2014 13:58:58
Message: <53b44862@news.povray.org>
Le 02/07/2014 19:37, clipka nous fit lire :
>>> lot!
It's getting bigger (here the clang version, as gcc is above 5M)
Download 'errorcolourcl3.txt' (673 KB)
Date: 2 Jul 2014 14:50:25
Message: <53b45471@news.povray.org>
Am 02.07.2014 19:58, schrieb Le_Forgeron:
>>>> lot!
Future versions will be in experimental/colour_model from now on.
Date: 2 Jul 2014 15:43:29
Message: <53b460e1@news.povray.org>
Le 02/07/2014 20:49, clipka nous fit lire :
>>>>> Thanks a
>>>>> lot!
Beware, gcc errors once un-bzip2-ed is 1 699 869 bytes long in
errorcolor.txt.
clang errors in the other file.
Download 'errorcolor.txt.bz2.zip' (13 KB) Download 'errorcolorcl.txt.bz2.zip' (6 KB)
Date: 2 Jul 2014 16:01:44
Message: <53b46528@news.povray.org>
Le 02/07/2014 19:51, clipka nous fit lire :
>>>> threads)
> fine.
It might be a long road.
I just went back to compile 3.7-stable with gcc and the image of
benchmark is even a bit different from the one at head with icpc.
There is a change in the clouds, basically the same place and
shape...but some holes...
Download 'icpc.png' (448 KB) Download 'stable.png' (439 KB)
Preview of image 'icpc.png'
Preview of image 'stable.png'
Date: 2 Jul 2014 17:23:45
Message: <53b47861$1@news.povray.org>
Am 02.07.2014 22:01, schrieb Le_Forgeron:
That's a known side effect of commit 5a081e92, which fixes a bug in the
way media used to be sampled (see also FS#318).
