POV-Ray : Newsgroups : povray.beta-test : Artefacts using +C Server Time
18 May 2024 10:33:12 EDT (-0400)
  Artefacts using +C (Message 1 to 10 of 10)
Subject: Artefacts using +C
Date: 18 Sep 2013 10:42:54
Message: <5239bbee$1@news.povray.org>
In a long render, I twice used +C. In each case it seems, a small
artefact remained from the previous render session (see image in
p.b.i.). Could this be a bug?
I used:
+w1024 +h576 -a +am2 +bm2 +wt6 +SR288 +EC512 +C
in both cases.
Subject: Re: Artefacts using +C
Date: 18 Sep 2013 10:55:04
Message: <5239bec8$1@news.povray.org>
> I used:
> in both cases.
> Thomas
I'm sure the artefact is obvious to you, and will forever be spotted
once you know it, but I fail to see it in the posted image
(which is smaller than 1024 x 576 )
Can you circle it with a red pen ? (sort of)
Just because nobody complains does not mean all parachutes are perfect.
Date: 18 Sep 2013 13:50:01
Message: <web.5239e75b1ca0d3dd126b6c50@news.povray.org>
> > I used:
> > in both cases.
> > Thomas
Yes I cannot see it too. The last discussion we had about +c issues and
artifacts was due to photon settings and radiosity. Jaime explained and solved
this problem:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.50366087f6191b69535f0ed20%40news.povray.org%3E/?ttop=386863
&toff=200
But here I cannot see a problem. Can it be that I have looked at this cutout
some days ago? It looks very familiar.
Best regards,
Michael
Date: 19 Sep 2013 03:10:09
Message: <523aa351$1@news.povray.org>
My laziness ;-)  Done.
Date: 19 Sep 2013 03:16:28
Message: <523aa4cc$1@news.povray.org>
> this problem:
> &toff=200
No. In my view this has nothing to do with radiosity and there are no
photons in this scene. Jaime's is a different problem.
It is part of the Aftermath scene, using focal blur. The artefacts are
the two little squares (now highlighted) that remain from the pretrace.
Date: 19 Sep 2013 03:29:14
Message: <523aa7ca$1@news.povray.org>
You can see /my/ comment in the following thread:
http://news.povray.org/povray.beta-test/thread/%3Cweb.5033e17517f31266b62e53d00%40news.povray.org%3E/?ttop=386875&toff=50
However, that concerned RC6. The mentioned problem has been solved for
RC7 but there seems to remain some little glitches.
Date: 19 Sep 2013 15:10:01
Message: <web.523b4b3b1ca0d3dc5c73f630@news.povray.org>
f=50
> Thomas
Hm, seems that this issue is not repaired completely with RC 7. I haven't used
+c much recently, but I can only remember one flaw. In this special case I
overlooked that I had entered another block size within the command line field
and had forgotten to clear the field resuming an other rendering using an
ini-file. Since the Windows version always uses given settings from the
rendering before, I attributed the problem to my fault not erasing the old
Settings, assuming that the ini-file options and the options from the command
line field were added. Unfortunatelly I cannot reproduce this behaviour since I
rerendered the image completely and didn't stored the state-file. And may be my
assumption is wrong.
If you have a smaller area with a long rendering time (may be a diamond) but the
bigger part of the picture is fast, then smaller block sizes can speed up the
total rendering time (slightly).
Best regards,
Michael
Date: 29 Sep 2013 03:55:01
Message: <web.5247dc0f1ca0d3d9e9562260@news.povray.org>
> +c much recently, ...
Now I did (see the related thread at p.b.i by Thomas for the image). I see
another problem with radiosity as I had in the past. Now the recalculated
radiosity mosaic overwrites pixels rendered already.
Best regards,
Michael
Date: 10 Nov 2013 09:26:15
Message: <527f9787@news.povray.org>
Am 18.09.2013 16:42, schrieb Thomas de Groot:
Sorry for the late response. Can you (or someone else) reproduce the
problem with some comparatively simple scene?
Date: 10 Nov 2013 10:27:51
Message: <527fa5f7$1@news.povray.org>
I can now confirm that this may happen, that it is a bug, and that it
actually /is/ radiosity related.
What happens is that the continued render starts the pretrace for the
missing blocks again; during the early stages of this pretrace, the
"pixels" may be far larger than the render blocks, and may overpaint
some already rendered blocks.
I've just coded a hotfix that will prevent pretrace results from being
written to the image buffer. This way the artifacts will still appear in
the preview window, but not in the final image file.
Avoiding the artifacts entirely seems a bit tricky, and is probably not
worth the pain as the pretrace step is scheduled for a redesign anyway.
