POV-Ray : Newsgroups : povray.beta-test : Preview output messes up with higher resolutions. Server Time
17 May 2024 20:48:00 EDT (-0400)
  Preview output messes up with higher resolutions. (Message 1 to 3 of 3)
Subject: Preview output messes up with higher resolutions.
Date: 28 Mar 2013 16:20:02
Message: <5154a5f2$1@news.povray.org>
Rendering at 1920x1080 I get the result as shown in p.b.i (900+ renders).
Running at a lower resolution shows the correct preview.
The stored images are correct.
Ger
Subject: Re: Preview output messes up with higher resolutions.
Date: 29 Mar 2013 03:30:08
Message: <51554300$1@news.povray.org>
Hint for investigators, it seems, from the description in p.b.i, that
when the preview (in Unix) need to be scaled (because the window
wouldn't fit the display), preview of animations do not get the same
treatment as when preview is not scaled. One might clear the preview and
the other might not.
Ger, can you confirm that this describes your problem ?
And that the version of povray is 3.7RC7 ?
Just because nobody complains does not mean all parachutes are perfect.
Date: 29 Mar 2013 13:12:45
Message: <5155cb8d$1@news.povray.org>
I don't think that's  totally true. In both scaled and non-scaled the
preview image should be overwritten. In the scaled preview it looks more
like the next image gets added to the existing image on screen. That's why
you get the washed out motion-like result.
Correct. 3.7 RC7 compiled with boost/OpenEXR libs on Opensuse Linux 12.3,
running on AMD 8-core.
Ger
