POV-Ray : Newsgroups : povray.beta-test : Colour of blurred reflections in unbiased tracing Server Time
28 Dec 2024 19:37:36 EST (-0500)
  Colour of blurred reflections in unbiased tracing (Message 1 to 6 of 6)
Subject: Colour of blurred reflections in unbiased tracing
Date: 30 Jan 2013 08:58:31
Message: <51092707$1@news.povray.org>
As I heard some form of unbiased algorithm might be making its way into
POV 3.7 at some point (similar to mcpov) I thought I'd bring up some
thoughts/questions I had about how colours are used.
I understand that in mcpov the surface colour is determined by shooting
out multiple rays and averaging their result, matching the real world
closer and closer as the number of rays is increased. I also understand
that you simulate diffuse or varying levels of blurred reflections by
shaping the distribution of rays across the hemisphere. A very shiny
surface (like a mirror) would only shoot rays in one direction, whereas
a totally diffuse surface would shoot rays in all directions randomly.
My understanding from real life is that colour is handled differently in
each case though. When I see a blue piece of plastic it's blue because
all the light being reflected off it has its spectrum attenuated
accordingly to make it blue. But when I see a glossy specular reflection
(even if blurred slightly) in the same material the colour is not
changed (white lights still appear white, not blue).
My assumption therefore is that the spectral attenuation that gives the
appearance of colour somehow affects light more the further away the ray
is from direct mirror reflection. It appears however mcpov does not
allow for this. In the current POV this isn't an issue as specular and
diffuse reflection are very clearly separated and you can choose the
colour and amount of each, but if something like mcpov is to be
incorporated into POV then the two terms become blurred and it's not
clear how to correctly simulate the real life situation.
My guess is you need some kind of falloff parameter that determines how
the diffuse colour specified affects the light as the angle increases
away from direct mirror reflection. But that's a pure guess, I have no
theoretical understanding of why this should be.
Subject: Re: Colour of blurred reflections in unbiased tracing
Date: 30 Jan 2013 09:24:42
Message: <51092d2a$1@news.povray.org>
Am 30.01.2013 14:58, schrieb scott:
No, that is not the case.
Instead, the following two physical effects will happen (except for
metals, which follow different physical effects):
(1) At the very surface of an object, specular reflection is happening,
more or less blurred depending on how rough the surface is, and more or
less strong depending on both the material's index of refraction and
surface structure. This reflected light will /always/ be "white", and
its distribution will /always/ be related to the incoming light direction.
(2) Any light that is not reflected will penetrate into the object and
scatter around in the material, where it will be subject to filtering
(depending on wavelength), and if it is not thus "swallowed" it will
ultimately exit the object once again in a very random direction. This
scattered light will /always/ be "colored" depending on the material,
and its distribution will (almost) /always/ be (almost) totally
independent of the incoming light direction.
MCPov does it exactly the way it should be done (except that it has a
bug in computing the contribution from (2), getting it wrong by a factor
of 2, but that's another story).
Date: 30 Jan 2013 10:05:25
Message: <510936b5$1@news.povray.org>
That makes sense.
Is it really a uniform colouring effect across the entire range of
angles though? I would have thought light that scatters less will come
out nearer to "white" and nearer the "direct" reflection angle, whereas
the light that is scattered more will be filtered more and come out more
randomly spread.
It's hard to judge with real materials because even with no obvious
specular I think there are still specular effects that are extremely
blurred, it might just be this that I'm seeing.
Is there a rule then to ensure physical correctness in mcpov when
supplying parameters for the diffuse and reflection contributions? So
far I've been working on diffuse+reflection=1, but it seems like that's
wrong now.
I'm still amazed though at how easy it is to produce ultra-realistic
lighting in mcpov with relatively little effort.
Date: 30 Jan 2013 10:35:55
Message: <51093ddb$1@news.povray.org>
Am 30.01.2013 16:05, schrieb scott:
> randomly spread.
The light that scatters less will indeed come out nearer to "white", but
its direction is as random as any other light that manages to come back
out. (At least that's true for most solid materials, in which the
scattering is sufficiently anisotropic.)
> wrong now.
It is wrong indeed, for quite a bunch of reasons as far as MCPov is
concerned:
- It doesn't properly handle the variation in specular reflection
depending on incoming angle and ior (modeled by the "fresnel" setting
for reflections).
- MCPov gets diffuse reflections wrong by a factor of 2.
- When using a "brilliance" setting of something other than 1.0, the
value specified in "diffuse" is /not/ the percentage of light scattered
back diffusely. Instead, the "diffuse" parameter directly controls the
brightness of the brightest spot. The new "albedo" keyword takes care of
this discrepancy: If you specify "diffuse albedo X", then X is indeed
the ratio of light scattered back diffusely (of all the light that comes
in).
If you don't use "fresnel" on the reflection (nor variable reflection,
for that matter), and if MCPov didn't have this factor-2 bug, then it
should indeed be:
     diffuse albedo + reflection <= 1.0
As you can see there are still some details missing for physically
realistic materials. But I'll keep working on it.
Date: 31 Jan 2013 03:19:45
Message: <510a2921$1@news.povray.org>
OK that was the fact I was missing in my analysis. I didn't expect it
was a digital difference between surface reflection rays emerging at a
specific angle and then "reflection" rays from just under the surface at
completely random angle. I had assumed it was some kind of transition
between the two.
> for reflections).
Do you mean the specular reflections for point light sources controlled
by the specular keyword? Or the specular reflections you get by using
the reflection and power parameters (which the fresnel setting has an
effect on)?
Can I correct for this by simply halving the diffuse factor in the
finish statement?
> in).
OK, I've not played about with brilliance before - but I assume albedo
is not part of mcpov.
Do you have an idea how much work it is to get mcpov type rendering into
3.7? Currently I use a simple program that fires off multiple mcpov
instances and then merges the results, which works ok but obviously it
doesn't take advantage of all the other goodies in 3.7.
Date: 31 Jan 2013 08:30:31
Message: <510a71f7$1@news.povray.org>
Am 31.01.2013 09:19, schrieb scott:
>> for reflections).
> effect on)?
I mean the fresnel stuff in general: At low angles there is a lot of
specular reflection. That reflected light obviously won't enter the
material to be scattered diffusely. At high angles, however, the
specular reflection is significantly lower, so more light enters the
Neither POV-Ray nor MCPov honor this effect when computing the diffuse
stuff.
> finish statement?
To the contrary, you'll need to set the diffuse factor twice as high in
MCPov.
>> in).
No, indeed not.
It's not a thing to pull off in a week or so, that's for sure. I have
already thrown together a patch that does blurred reflections, but
blurred refractions are still missing, and I haven't yet fully
integrated it with the other stochastic (or could-be-made-stochastic)
elements already in POV-Ray (focal blur, anti-aliasing, area lights,
diffraction and SSLT come to my mind). Importance sampling is still
missing as well. It also doesn't render the image over and over again
until you're satisfied - instead it uses a special oversampling mode
that uses stochastic analysis of the rendered pixels to decide when to
stop working on a render block and move on to the next one.
