POV-Ray : Newsgroups : povray.beta-test : Parser Statistics anomaly Server Time
6 Jun 2026 23:27:57 EDT (-0400)
  Parser Statistics anomaly (Message 11 to 18 of 18)
Subject: Re: Parser Statistics anomaly
Date: 7 Dec 2012 06:34:14
Message: <50c1d436$1@news.povray.org>
On 12/07/2012 12:20 AM, clipka wrote:
> Am 06.12.2012 22:16, schrieb James Holsenback:
>> LOL ... starting with the simple scene it does not report finite until
>> scale is set to 1000
>  From the math, the threshold should be between 1357 and 1358 if the
> sphere is just transformed and/or rotated. (If a rotation is applied via
> an arbitrary matrix, the threshold might be as low as 783 to 784 in
> extreme cases.)
> An infinite object is not excluded from bounding /per se/, but does not
> benefit from /hierarchical/ bounding.
> (Fun fact: Spheres have such a simple math that they skip bounding box
> testing entirely, so they only benefit from hierarchical bounding at all.)
Seems that everyone is OK with this ... I don't recall this limitation
in the past. Could this be side-effect of a recent change?
Date: 7 Dec 2012 07:39:13
Message: <50c1e371@news.povray.org>
Am 07.12.2012 12:34, schrieb James Holsenback:
Nothing truly recent, that's for sure. Did you test 3.6 behaviour?
Date: 7 Dec 2012 08:34:00
Message: <50c1f048$1@news.povray.org>
I feel a bit concerned though. I did not test your code, but what does
it mean for the render?
Date: 7 Dec 2012 09:25:00
Message: <50c1fc3c$1@news.povray.org>
> Thomas
Well this all started when I noticed "1" infinite object reported when I
knew that I had none, or at least I thought ... that led to the
discovery that my skydome object (generally just has a hdr image) was
the culprit. In the past I usually had scale in the 100 to 500 range but
recently I found the need for 1000+ ...
The guys who would know more about such things don't seem alarmed, and
I'm quite content calling my skydome object infinite when it's that big
... new (lol or new to me) paradigm right!
Date: 7 Dec 2012 10:17:35
Message: <50c2088f$1@news.povray.org>
I had not noticed the /infinity/ of some of my objects before and they
seem to render normally indeed. In /The Sultana/ scene there are the sea
and the Earth below for instance, as well as the atmosphere which are on
the 10e5 radius level.
Date: 7 Dec 2012 20:28:52
Message: <50c297d4@news.povray.org>
The limit seems a bit arbitrary, considering that it depends on the
scene scale. I suspect this means that in some cases a scene can render
slower if it is modelled, e.g., in mm per unit vs. m per unit (in the
former case an object in the 1000 - 10000 range may not be uncommon).
Date: 8 Dec 2012 05:04:32
Message: <50c310b0@news.povray.org>
> Am 06.12.2012 19:30, schrieb Warp:
> > Le_Forgeron <jgr### [at] freefr> wrote:
> >> an object is considered infinite when it is big enough...
> > What exactly is the advantage of this?
> If an object is virtually everywhere, testing against its bounding box
> is wasted computing time.
But the volume of the object doesn't tell this. The camera could well be
located such that the object in question is very small on screen. And
conversely, even a small object could fill up the entire view (eg. because
the camera is inside or extremely close to it.)
Shouldn't the algorithm be slightly more involved? In other words, try
to estimate the size of the object with respect to the camera position
and direction, rather than simply as a function of its volume.
Date: 9 Dec 2012 15:16:05
Message: <50c4f185@news.povray.org>
I remember some renders using 3.6 where there was no infinits objecte
that reported some infinite objects. Those where mostly large "world
spheres" or other objects that would show wherever the background would
have been visible if those where not present.
My first impression was that when an object bounding box or extent
totaly enclosed the camera, then that object would be treated as infinite.
