POV-Ray : Newsgroups : povray.beta-test : Error in Docs: Partial Output Options Server Time
28 Mar 2026 20:39:55 EDT (-0400)
  Error in Docs: Partial Output Options (Message 1 to 10 of 14)
Subject: Error in Docs: Partial Output Options
Date: 6 Nov 2012 07:21:13
Message: <509900b9@news.povray.org>
In the Docs paragraph: 3.1.2.2.3 Partial Output Options, +Sn and +En
should respectively be replaced by: +SRn and +ERn
+Sn and +En result in an error message.
+S0.n and +E0.n just do nothing.
Subject: Re: Error in Docs: Partial Output Options
Date: 6 Nov 2012 09:57:57
Message: <50992575@news.povray.org>
> Thomas
Hmmm ... I get do nothing both of these no error/warning ... the full
image renders
Date: 6 Nov 2012 10:04:50
Message: <50992712@news.povray.org>
>> Thomas
> image renders
Semantic trouble  :-)
This is what I mean: It should /not/ be the full image. The commands do
not work. While +SR0.n and +ER0.n work correctly.
Date: 6 Nov 2012 10:11:36
Message: <509928a8$1@news.povray.org>
I am still not making myself clear enough.
+Sn, +S0.n, +En, +E0.n are /unexisting/ commands which should be removed
from the list at the start of the paragraph.
Date: 6 Nov 2012 10:13:25
Message: <50992915@news.povray.org>
>> Thomas
> image renders
OK double Hmmmm ... I was trying different combinations of the +sr0.n
and +er0.n formats and this produces a hard fail:
+sr0.50 +er0.100
POV-Ray Critical Error: Backend worker thread shut down prematurely:
please re-start POV-Ray.povray: vfepovms.cpp:208: int
vfe::SysQNode::Send(void*, int): Assertion `m_Sanity == 0xEDFEEFBE' failed.
Well after thinking WTF a did a little RTFM and see that the format I
used specifies percentage, so now I understand the error of my choice.
This shouldn't have gotten past the parser ... correct?
Date: 6 Nov 2012 10:15:53
Message: <509929a9@news.povray.org>
> Thomas
well at this point I'm not 100% sure ... given what else I've
discovered. I'm just saying ... is there a chance that those variants
ARE legit ... parser doesn't seem to care.
Date: 7 Nov 2012 04:00:15
Message: <509a231f$1@news.povray.org>
>> Thomas
Well, parser /did/ care for +Sn and +En in my system, but not
anymore.... However, they do /not/ do their job. The full image is
rendered instead of the part in-between asked for. Same story for +S0.n
and +E0.n (percentages).
Also note that +S and +E are /not/ available in the index, while +SR and
+ER are..
My impression is that they are relicts from the 3.6 version and have
been deactivated as they are redundant with +SRn and +ERn, respectively
+SR0.n and +ER0.n
Date: 7 Nov 2012 10:19:08
Message: <509a7bec$1@news.povray.org>
>>> Thomas
> +ER are..
> +SR0.n and +ER0.n
> Thomas
Yeah ... I think you may be correct about some of those variants have
been disabled ... deprecated can't say for sure, but don't think so, I
did a quick check of the change log and didn't see anything.
I'll be more than happy to change the docs when we get someone to expand
on what's legit. You know something else that doesn't seem right is that
/if/ those variants are deprecated I'd expect some kind of warning ...
also the ones that are getting through seem to have rather loose
validations rules.
Interesting find ... I'm anxious to get the straight scoop.
Date: 7 Nov 2012 10:40:07
Message: <509a80d7$1@news.povray.org>
Yes, it seems odd. We anxiously await the enlightened words of the Grand
Masters  ;-)
Date: 8 Nov 2012 07:55:46
Message: <509babd2$1@news.povray.org>
Am 07.11.2012 16:39, schrieb Thomas de Groot:
> Masters  ;-)
Guess what - turns out that the error message for unknown switches
doesn't work properly.
