POV-Ray : Newsgroups : povray.beta-test : Error in Docs: Partial Output Options Server Time
25 Apr 2026 16:15:32 EDT (-0400)
  Error in Docs: Partial Output Options (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Error in Docs: Partial Output Options
Date: 6 Nov 2012 10:13:25
Message: <50992915@news.povray.org>
On 11/06/2012 09:57 AM, James Holsenback wrote:
> On 11/06/2012 07:20 AM, Thomas de Groot wrote:
>> +Sn and +En result in an error message.
>> +S0.n and +E0.n just do nothing.
>> Thomas
> Hmmm ... I get do nothing both of these no error/warning ... the full
> image renders
OK double Hmmmm ... I was trying different combinations of the +sr0.n
and +er0.n formats and this produces a hard fail:
+sr0.50 +er0.100
POV-Ray Critical Error: Backend worker thread shut down prematurely:
please re-start POV-Ray.povray: vfepovms.cpp:208: int
vfe::SysQNode::Send(void*, int): Assertion `m_Sanity == 0xEDFEEFBE' failed.
Well after thinking WTF a did a little RTFM and see that the format I
used specifies percentage, so now I understand the error of my choice.
This shouldn't have gotten past the parser ... correct?
Date: 6 Nov 2012 10:15:53
Message: <509929a9@news.povray.org>
On 11/06/2012 10:11 AM, Thomas de Groot wrote:
> On 6-11-2012 16:04, Thomas de Groot wrote:
>> Semantic trouble  :-)
>> This is what I mean: It should /not/ be the full image. The commands do
>> not work. While +SR0.n and +ER0.n work correctly.
> I am still not making myself clear enough.
> +Sn, +S0.n, +En, +E0.n are /unexisting/ commands which should be removed
> from the list at the start of the paragraph.
> Thomas
well at this point I'm not 100% sure ... given what else I've
discovered. I'm just saying ... is there a chance that those variants
ARE legit ... parser doesn't seem to care.
Date: 7 Nov 2012 04:00:15
Message: <509a231f$1@news.povray.org>
>> Thomas
Well, parser /did/ care for +Sn and +En in my system, but not
anymore.... However, they do /not/ do their job. The full image is
rendered instead of the part in-between asked for. Same story for +S0.n
and +E0.n (percentages).
Also note that +S and +E are /not/ available in the index, while +SR and
+ER are..
My impression is that they are relicts from the 3.6 version and have
been deactivated as they are redundant with +SRn and +ERn, respectively
+SR0.n and +ER0.n
Date: 7 Nov 2012 10:19:08
Message: <509a7bec$1@news.povray.org>
>>> Thomas
> +ER are..
> +SR0.n and +ER0.n
> Thomas
Yeah ... I think you may be correct about some of those variants have
been disabled ... deprecated can't say for sure, but don't think so, I
did a quick check of the change log and didn't see anything.
I'll be more than happy to change the docs when we get someone to expand
on what's legit. You know something else that doesn't seem right is that
/if/ those variants are deprecated I'd expect some kind of warning ...
also the ones that are getting through seem to have rather loose
validations rules.
Interesting find ... I'm anxious to get the straight scoop.
Date: 7 Nov 2012 10:40:07
Message: <509a80d7$1@news.povray.org>
Yes, it seems odd. We anxiously await the enlightened words of the Grand
Masters  ;-)
Date: 8 Nov 2012 07:55:46
Message: <509babd2$1@news.povray.org>
Am 07.11.2012 16:39, schrieb Thomas de Groot:
> Masters  ;-)
Guess what - turns out that the error message for unknown switches
doesn't work properly.
Date: 8 Nov 2012 19:39:14
Message: <509c50b2@news.povray.org>
>> Masters  ;-)
does now ... pulled your fix :-)
Oh and BTW: looks like you were correct Thomas I'll fix the docs
Date: 9 Nov 2012 03:18:00
Message: <509cbc38$1@news.povray.org>
We got the best of two worlds then :-)
Date: 9 Nov 2012 06:51:30
Message: <509cee42@news.povray.org>
> Thomas
If you wouldn't mind having a look (sanity check) ... the docs have been
changed. I deleted the old non-supported variants, and added a "Note"
about support for those variants being dropped.
http://wiki.povray.org/content/Reference:General_Output_Options#Partial_Output_Options
Date: 9 Nov 2012 07:24:58
Message: <509cf61a$1@news.povray.org>
Clear as crystal, James!
