POV-Ray : Newsgroups : povray.beta-test : 3.7rc6 on Raspberry PI, compile errors Server Time
20 Mar 2026 21:08:10 EDT (-0400)
  3.7rc6 on Raspberry PI, compile errors (Message 1 to 10 of 14)
Subject: 3.7rc6 on Raspberry PI, compile errors
Date: 17 Aug 2012 13:53:35
Message: <502e851f$1@news.povray.org>
I built pov 3.7 rc6 on my Raspberry PI. There are a couple of issues.
Here's the blurb from configure (source was povray-3.7.0.RC6.tar.gz):
   POV-Ray 3.7.0.RC5 has been configured.
   Built-in features:
     I/O restrictions:          enabled
     X Window display:          enabled (using SDL)
     Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff
     Unsupported image formats: openexr
   Compilation settings:
     Build architecture:  armv6l-unknown-linux-gnueabi
     Built/Optimized for: armv6l-unknown-linux-gnueabi
     Compiler vendor:     gnu
     Compiler version:    g++ 4.6
     Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -pthread
I got the following compiler errors:
   shape/poly.cpp:188:3: warning: this decimal constant is unsigned only
in ISO C90 [enabled by default]
   processoptions.cpp:1180:9: warning: case label value is less than
minimum value for type [enabled by default]
   povms.cpp:304:3: warning: anonymous type with no linkage used to
declare variable '<anonymous struct> POVMSStreamOrderTables' with
linkage [enabled by default]
   renderfrontend.cpp:1165:57: warning: trigraph ??) ignored, use
-trigraphs to enable [-Wtrigraphs]
   vfesession.cpp:594:11: warning: case label value is less than minimum
Of the above, the errors in processoptions.cpp & vfesession.cpp are
significant. On this platform a 'char' is unsigned by default. Here's a
test program that exhibits the same error message and shows that there
are actual errors:
   #include <stdio.h>
   enum badT  { bAA, bBB        } bad_e;
   enum goodT { gAA, gBB, xx=-1 } good_e;
   main( int ac, char ** av )
     char ch = EOF;
     signed char sch = EOF;
     printf( "ch=%d, sch=%d\n", ch, sch );
     bad_e = (badT) -1;
     good_e = (goodT) -1;
     printf( "bad_e=%d, good_e=%d\n", bad_e, good_e );
     switch( bad_e ) {
       case bAA: printf( "case bad_e == bAA\n" ); break;
       case -1:  printf( "case bad_e == -1\n" ); break;
       default:  printf( "case bad_e == ? (default)\n" ); break;
     switch( good_e ) {
       case gAA: printf( "case good_e == gAA\n" ); break;
       case -1:  printf( "case good_e == -1\n" ); break;
       default:  printf( "case good_e == ? (default)\n" ); break;
   $ g++ t.cpp
   t.cpp: In function 'int main(int, char**)':
   t.cpp:19:11: warning: case label value is less than minimum value for
   $ ./a.out
   ch=255, sch=-1
   bad_e=-1, good_e=-1
   case good_e == -1
Thus you can see that neither the 'case EOF:' at line 1180 of
processoptions.cpp nor the 'case -1:' at line 594 of vfesession.cpp will
match unless the patches below are applied.
Here are a couple of patches that fix those two significant errors. For
simplefrontend.h someone who understands why the enum variable gets
assigned a '-1' will have to rework the patch and fix the actual
assignment rather the kludging the declaration.
--- ./source/base/processoptions.cpp.orig       2012-02-05
14:54:15.000000000 -0600
+++ ./source/base/processoptions.cpp    2012-08-16 11:17:19.773490094 -0500
@@ -1167,7 +1167,7 @@
         str[0] = 0;
         for (int i = 0; i < 65536; i++, *pos = 0)
-               char ch = file->getchar();
+               int ch = file->getchar();
                 if (hadEscape && (ch == '"' || ch == '\'' || ch == '\\'))
                         hadEscape = false;
--- ./source/frontend/simplefrontend.h.orig     2012-02-05
14:54:18.000000000 -0600
+++ ./source/frontend/simplefrontend.h  2012-08-16 11:22:46.244738423 -0500
@@ -124,7 +124,8 @@
         kStopping,
         kStopped,
         kFailed,
-       kDone
+       kDone,
+       kminusone = -1
Subject: Re: 3.7rc6 on Raspberry PI, compile errors
Date: 17 Aug 2012 16:08:31
Message: <502ea4bf$1@news.povray.org>
Le 17/08/2012 19:53, Dave nous fit lire :
The array is declared unsigned int, prefilled with numbers up to
0x8B18014C ( 2 333 606 220 ), with two neighbours at 2 203 961 430
(0x835DC856).
Are your int 64 bits ? Because I fail to see the issue on a classical 32
bits.
Should the literal be extended with a "u" to make it happy ?
(only the 3 big ones)
Date: 17 Aug 2012 16:12:50
Message: <502ea5c1@news.povray.org>
> (0x835DC856).
In C90 those are signed long long ints, and they are being assigned to
unsigned ints, hence the warning.
Write 0x8B18014CU and 0x835DC856U to make it explicit that unsigned ints
are desired.
Date: 17 Aug 2012 17:17:15
Message: <502eb4db$1@news.povray.org>
Am 17.08.2012 19:53, schrieb Dave:
Should not be a problem. Theoretically, that is. We can fix it, and we
probably should.
This, folks, is actually an outright error, leading to issues when the
The compiler has a point there.
Trigraphs suck, but yes, we should avoid them.
That line seems somewhat bogus.
> are actual errors:
This has nothing to do with char being unsigned by default - except that
it helped spot the errors. But they're errors either way.
Thanks for reporting those warnings.
Date: 17 Aug 2012 17:19:16
Message: <502eb554@news.povray.org>
Am 17.08.2012 22:08, schrieb Le_Forgeron:
Yes.
Why not all of them?
Date: 17 Aug 2012 17:35:47
Message: <502eb933$1@news.povray.org>
Variable 'm_BackendState' is declared as type 'State' (vfe/vfesession.h
line 1316). The switch statement (vfe/vfesession.cpp line 576) contains
a 'case -1:'. Whoever wrote that code perhaps expected that
m_BackendState could have the value '-1'. If it does, then the case will
never be caught since '-1' is not a valid value for that enum.
Date: 17 Aug 2012 17:42:40
Message: <502ebad0$1@news.povray.org>
Am 17.08.2012 23:35, schrieb Dave:
Yes, that's what I'm thinking. Have done some quick code digging to see
if it is ever set to -1 somewhere, but it turns out to be more than a
5-minute job.
Date: 17 Aug 2012 18:40:01
Message: <web.502ec8257f588ef385de7b680@news.povray.org>
Hard to believe there was a time when not all English-based computers understood
7-bit ASCII.
Date: 17 Aug 2012 18:58:05
Message: <502ecc7d$1@news.povray.org>
Am 18.08.2012 00:39, schrieb Cousin Ricky:
> 7-bit ASCII.
Well, the trigraphs were there for /non/ English-based computers, which
often used 7-bit national derivatives of ASCII. Those typically replaced
a common set of 8 characters - curly braces, square brackets, pipe
symbol, backslash, tilde and hash - with language-specific characters
(in the German "GSCII", for instance, those were the umlauts, the sz
ligature, and the German paragraph sign), so C programs without
trigraphs would look pretty odd on those computers.
BTW, the UK also had their own derivative of ASCII, replacing the hash
sign with a pound sterling sign, but AFAIR the other characters were
left unharmed.
Date: 17 Aug 2012 21:10:01
Message: <web.502eea727f588ef385de7b680@news.povray.org>
Why does a German acronym begin with the letter 'G'?
