POV-Ray : Newsgroups : povray.beta-test : 3.7rc6 on Raspberry PI, compile errors Server Time
2 Jul 2026 05:22:09 EDT (-0400)
  3.7rc6 on Raspberry PI, compile errors (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: 3.7rc6 on Raspberry PI, compile errors
Date: 17 Aug 2012 17:19:16
Message: <502eb554@news.povray.org>
Am 17.08.2012 22:08, schrieb Le_Forgeron:
> Should the literal be extended with a "u" to make it happy ?
Yes.
> (only the 3 big ones)
Why not all of them?
Date: 17 Aug 2012 17:35:47
Message: <502eb933$1@news.povray.org>
On 8/17/2012 4:17 PM, clipka wrote:
>>    vfesession.cpp:594:11: warning: case label value is less than minimum
>> value for type [enabled by default]
> That line seems somewhat bogus.
Variable 'm_BackendState' is declared as type 'State' (vfe/vfesession.h
line 1316). The switch statement (vfe/vfesession.cpp line 576) contains
a 'case -1:'. Whoever wrote that code perhaps expected that
m_BackendState could have the value '-1'. If it does, then the case will
never be caught since '-1' is not a valid value for that enum.
Date: 17 Aug 2012 17:42:40
Message: <502ebad0$1@news.povray.org>
Am 17.08.2012 23:35, schrieb Dave:
Yes, that's what I'm thinking. Have done some quick code digging to see
if it is ever set to -1 somewhere, but it turns out to be more than a
5-minute job.
Date: 17 Aug 2012 18:40:01
Message: <web.502ec8257f588ef385de7b680@news.povray.org>
> Am 17.08.2012 19:53, schrieb Dave:
> >    renderfrontend.cpp:1165:57: warning: trigraph ??) ignored, use
> > -trigraphs to enable [-Wtrigraphs]
> Trigraphs suck, but yes, we should avoid them.
Hard to believe there was a time when not all English-based computers understood
7-bit ASCII.
Date: 17 Aug 2012 18:58:05
Message: <502ecc7d$1@news.povray.org>
Am 18.08.2012 00:39, schrieb Cousin Ricky:
> 7-bit ASCII.
Well, the trigraphs were there for /non/ English-based computers, which
often used 7-bit national derivatives of ASCII. Those typically replaced
a common set of 8 characters - curly braces, square brackets, pipe
symbol, backslash, tilde and hash - with language-specific characters
(in the German "GSCII", for instance, those were the umlauts, the sz
ligature, and the German paragraph sign), so C programs without
trigraphs would look pretty odd on those computers.
BTW, the UK also had their own derivative of ASCII, replacing the hash
sign with a pound sterling sign, but AFAIR the other characters were
left unharmed.
Date: 17 Aug 2012 21:10:01
Message: <web.502eea727f588ef385de7b680@news.povray.org>
Why does a German acronym begin with the letter 'G'?
Date: 18 Aug 2012 03:29:11
Message: <502f4447$1@news.povray.org>
Le 17/08/2012 23:19, clipka nous fit lire :
> Yes.
Your wish are my command.
Date: 18 Aug 2012 05:28:46
Message: <502f604e$1@news.povray.org>
Am 18.08.2012 03:05, schrieb Cousin Ricky:
Because in this case it's a variation of an English acronym?
Date: 18 Aug 2012 06:10:19
Message: <502f6a0b$1@news.povray.org>
Le 17/08/2012 23:17, clipka nous fit lire :
The issue with trigraph is that young coders do not know they might
indeed use them without knowing. Same would go for digraph, but the
pattern is less obvious for them.
Trigraph in C are started by a doube ?. So chess comments are dangerous
in C. ( ?? (blunder, in chess) ).
http://en.wikipedia.org/wiki/Digraphs_and_trigraphs
Here, trigraph happens with ??)
Date: 20 Oct 2012 16:40:45
Message: <50830c4d$1@news.povray.org>
Trigraphs were there for computers using EBCDIC, 6-bit bytes, and so on.
> Those typically replaced a
> common set of 8 characters - curly braces, square brackets, pipe symbol,
> backslash, tilde and hash - with language-specific characters (in the German
> "GSCII", for instance, those were the umlauts, the sz ligature, and the
> German paragraph sign), so C programs without trigraphs would look pretty
Well, that too. But I think it was more for being able to code C on punched
cards than it was replacing umlauts with equally-unreadable trigraphs.
> BTW, the UK also had their own derivative of ASCII, replacing the hash sign
> with a pound sterling sign, but AFAIR the other characters were left unharmed.
That's why Americans sometimes call # the "pound sign".
   "They're the 1-800-#-GORILA of the telecom business."
