POV 3.5 RC1 icl on WinNT Sp 6 PII 233 with 128 MB
According to documentation "Val_1, Val_2, etc, are the value of the spline
parameter at each specific point. " (6.1.9). So when there is different point
for t=0 and t=1 than I expect that Spline(0) is different than Spline(1).
Below example shows that for cubic spline it is not true. When I parse below
script as is then it stops at last macro call and tells that both points are
the same. When I comment last line it parses ok. When prepare spline first,
and convert later (at macro call) there is everything ok as first part shows.
// START
#macro List() 0 <1,1,0> 1 <3,8,0> 2 <7,7,0> 3 <7,3,0> #end
#macro Test(S) cylinder{ S(0) S(1) 1 } #end
#local Spline = spline { List() };
Test( spline{ Spline linear_spline } )
Test( spline{ Spline quadratic_spline } )
Test( spline{ Spline natural_spline } )
Test( spline{ Spline cubic_spline } )
Test( spline{ linear_spline List() } )
Test( spline{ quadratic_spline List() } )
Test( spline{ natural_spline List() } )
Test( spline{ cubic_spline List() } )
// END
ABX
There is becouse new type is ignored and spline is still linear
(I forgot in last known bug list my report
http://news.povray.org/m7fq3u41ctia9e6i3tbnlstn6ek739vpke%404ax.com
is part of "Problems still being worked on")
ABX
Moreover when I tried forcing type conversion at evaluation time with:
#macro Test(S) cylinder{ S(0,cubic_spline) S(1,cubic_spline) 1 } #end
I have got strange error:
cylinder{ S(0,cubic_spline <----ERROR
Parse Error: linear_spline, quadratic_spline, natural_spline,
or cubic_spline expected.
ABX
Perhaps something related:
http://news.povray.org/povray.beta-test/22758/
ABX
<4j0obu8bqevuf7spm93rlj2nl7rp8tlkb7@4ax.com>...
point
>// START
>// END
This is because of the way cubic_splines (aka Catmull-Rom splines) are
defined: the first and last points are tangents, rather than points on the
spline. As a result, cubic_spline interpolation is only valid between the
second and next-to-last points. For all other spline types, interpolation
is valid from the first point to the last point. For t-values outside the
valid range, POV-Ray returns the value of the nearest valid point. As a
result,
>Test( spline{ cubic_spline 0 <1,1,0> 1 <3,8,0> 2 <7,7,0> 3 <7,3,0> } )
uses the points S(0) = <3,8,0> and S(1) = <3,8,0>, since the first valid
point on a cubic_spline is the second one in the list.
Whoever's maintaining the relevant part of the documentation should make a
note of this.
Mark
The Universe is expanding.
The budget for its exploration is shrinking.
> make a note of this.
Will be added.
Ingo
"Mark Wagner" <mar### [at] gte net> wrote in message
news:3cbd0171@news.povray.org...
spline
> point
> >// START
> >// END
> result,
<7,3,0> } )
Yep, I ran into a problem on the other end. This spline,
#declare splArm = spline {
cubic_spline
-1, <-1, 1, 0>
0, <0, 0, 0>
0.3, <1, -.5, -1>
1.0, <1.3, 1.0, 1.5>
//1.1, <1.1, 1.2, 1.7>
1.2, <1, 0.5, 2.0>
gave me a lot of headaches with the following macro:
#macro splDir(spl, ps) vnormalize(spl(ps+1e-4)-spl(ps-1e-4)) #end
splDir(splArm, 1.02) gives a <0,0,0> result which caused a error further
afield. When I added the line which I have commented out here, the problem
went away.
> note of this.
> Mark
