POV-Ray : Newsgroups : povray.beta-test : Test of RC6 distribution packages Server Time
15 May 2026 17:33:47 EDT (-0400)
  Test of RC6 distribution packages (Message 1 to 9 of 9)
Subject: Test of RC6 distribution packages
Date: 21 Jun 2012 11:11:40
Message: <4fe339ac$1@news.povray.org>
Once again, before officially announcing RC6 we'd appreciate if some of
you could sanity-check the distribution packages:
   http://www.povray.org/beta/povwin-3.7.RC6-setup.exe
   http://www.povray.org/beta/povray-3.7.0.RC6.tar.gz
(As you probably guess, the former is for Windows while the latter is
for Linux :-))
Subject: Re: Test of RC6 distribution packages
Date: 21 Jun 2012 12:40:21
Message: <4fe34e75@news.povray.org>
  Compiled and worked without any problems on an OpenSUSE box.
  Btw, one minor thing: When using the +ua command-line option, the preview
window shows a black background instead of the checkerboard background it
shows in povray 3.6. (The alpha channel is correct in the generated image
file, though.)
Date: 21 Jun 2012 12:45:56
Message: <4fe34fc4$1@news.povray.org>
> file, though.)
yeah ... I have that as well. IIRC that issue has already been raised.
Date: 21 Jun 2012 13:28:49
Message: <4fe359d1$1@news.povray.org>
Installed fine Win 7, 64 bit:
Icon on Desktop
Target
"C:\Program Files\POV-Ray\v3.7 RC6\bin\pvengine64.exe"
Start in
"C:\Users\Me\AppData\Roaming\Microsoft\Windows\Start
Menu\Programs\POV-Ray for Windows v3.7 RC6
Documents
C:\Users\Me\Documents\POV-Ray\v3.7
BTW In the Help file the index entries still map to the entry above.
Regards
Date: 21 Jun 2012 17:37:37
Message: <4fe39421@news.povray.org>
Still no file association with .pov files after install here, otherwise fine
with Windows 7 64bit.
Date: 21 Jun 2012 19:24:09
Message: <4fe3ad19@news.povray.org>
> for Linux :-))
Photons reflection is back! Yeah!
Installed like a charm and uninstalled the previous version while
preserving the user's own scenes and added inc files.
Date: 22 Jun 2012 10:57:22
Message: <20120622115720.3761ed41.john@johncoppens.com>
On Thu, 21 Jun 2012 17:11:36 +0200
> for Linux :-))
Hello guys...
Thanks for the work!
LIBPNG:
On my (aging) x86_64 Linux system, ./configure still detects libpng 1.4
instead of version 1.5. This is strange, because, as far as I can see,
everything is correctly configured:
$ pkg-config --modversion --cflags --libs libpng
1.5.1
-I/usr/include/libpng15  -lpng15
Though earlier versions of Povray had problems compiling with 1.5, the
latest RCs didn't. So I had to modify configure.ac, run bootstrap. It
seems configure is rather strict in _not_ finding 1.5:
AX_CHECK_LIB([png], [$required_libpng_version], [png14 png png12 png],
[png_get_libpng_ver], [png.h], [png_get_libpng_ver(NULL)], [$with_libpng])
Maybe it's time to add png15 there? Or rely on pkg-config?
STRANGE -L/usr/lib inclusion:
Near the end of compilation, I get:
g++  -pipe -Wno-multichar -Wno-write-strings -fno-enforce-eh-specs -s -O3 -ffast-math
-march=native -pthread  -L/usr/lib  -L/usr/lib -o povray disp_sdl.o disp_text.o
../vfe/libvfe.a ../source/backend/libbackend.a ../source/frontend/libfrontend.a
../source/base/libbase.a ../source/libpovray.a -lSDL -L/usr/lib64
-Wl,-rpath,/usr/lib64 -lSDL -lpthread -lXpm  -lSM -lICE -lX11  -lIlmImf -pthread
-lIlmImf -lz -lImath -lHalf -lIex -lIlmThread   -lIlmThread -ltiff -ljpeg -lpng15 -lz
-lrt -lm -lboost_thread-mt  -pthread
/usr/lib64/gcc/x86_64-slackware-linux/4.5.2/../../../../x86_64-slackware-linux/bin/ld:
skipping incompatible /usr/lib/libSDL.so when searching for -lSDL
RC5 didn't show this... I haven't found the reason yet.
John
Date: 22 Jun 2012 15:34:18
Message: <20120622163417.48107a5f.john@johncoppens.com>
On Fri, 22 Jun 2012 11:57:20 -0300
The libpng15 issue, mentioned in previous mail, is still valid, but the
-L/usr/lib warnings do not seem to have any effect on the generation of
the executable. I'll try to find where those flags are coming from.
John
Date: 25 Jun 2012 13:25:11
Message: <4fe89ef7@news.povray.org>
thanks for the info, I'll look into this.
-- Chris
