POV-Ray : Newsgroups : povray.beta-test : Memory access violation @ 0x005EC54C: RC4 SSLT + reflections + height_fields Server Time
16 Mar 2026 17:29:06 EDT (-0400)
  Memory access violation @ 0x005EC54C: RC4 SSLT + reflections + height_fields (Message 1 to 4 of 4)
Subject: Memory access violation @ 0x005EC54C: RC4 SSLT + reflections + height_fields
Date: 17 Mar 2012 19:45:07
Message: <4f652203$1@news.povray.org>
Got a bit of a problem here. POV-Ray crashes when rendering the following:
#version 3.7;
global_settings{
  mm_per_unit 3
  subsurface{samples 20, 2}
#declare HF =
  height_field{
   function 128, 128{
    pigment{
     granite
   smooth
   translate -(x+z)/2
   scale 2*<1,.1,1>
   translate y*.5
#declare Obj =
  intersection{
   object{HF}
   object{HF rotate x*90}
   object{HF rotate x*180}
   object{HF rotate x*270}
   object{HF rotate z*90}
   object{HF rotate z*270}
merge{
  #declare Seed = seed(1023);
  #for(V,0,10)
   object{
    Obj
    scale .5*pow(1-.4*rand(Seed),3)
    rotate 360*<rand(Seed),rand(Seed),rand(Seed)>
    translate .5*(1-2*<rand(Seed),rand(Seed),rand(Seed)>)
  pigment{rgb 1}
  finish{
   reflection{0.1, 1.0 falloff 2} conserve_energy
   subsurface{translucency 1}
I'm not convinced that it only occurs with height_fields, but it might
be a clue as to why it's happening.
Version: 3.7.0.RC4.msvc 10-sse2.win32
Operating System: Windows XP SP 2
Processor(s): Intel Core 2 Quad Q6600 @ 2.40GHZ
RAM: 2.00GB
Sorry for posting this here, but Flyspray isn't accepting my passcode
for some reason. I can provide a dump if absolutely necessary.
Sam
Subject: Re: Memory access violation @ 0x005EC54C: RC4 SSLT + reflections + height_fields
Date: 17 Mar 2012 20:16:50
Message: <4f652972$1@news.povray.org>
Am 18.03.2012 00:45, schrieb stbenge:
> Hi,
Please try with RC5; it was mainly released to fix some SSLT-related
hard crash scenario that may well be relevant for your scene.
Subject: Re: Memory access violation @ 0x005EC54C: RC4 SSLT + reflections+ height_fields
Date: 17 Mar 2012 21:21:37
Message: <4f6538a1@news.povray.org>
>> Hi,
>> following:
Ah, will do. Thanks Christoph~
Subject: Re: Memory access violation @ 0x005EC54C: RC4 SSLT + reflections+height_fields
Date: 17 Mar 2012 23:44:19
Message: <4f655a13@news.povray.org>
>>> Hi,
>>> following:
Everything appears to be working as it should; no crashes so far. Great
job on getting SSLT implemented. I truly appreciate all the work you and
the rest of the POV team are putting in!
