![](/i/fill.gif) |
Hello,
I reinstall a system, (so ~/.povray was not existant), and then
installed povray from sources, as a normal user (excepted the
installation step):
$ ./configure ...
$ make
$ make check
$ sudo make install
I find these steps pretty much standard.
The problem I'm noticing is that the $HOME/.povray hierarchy get owned
by root (hey, it's *MY* directory !). There is a chown in the Makefile
for the target files (povray.ini & povray.conf), as well as subtree but:
* povowner & povgroup are hard coded to 0 (I would expect a copy of the
owner & group of $HOME, wouldn't I ?)
For getting povowner, I would suggest `stat -c "%u" $HOME`
For povgroup, `stat -c "%g" $HOME`
Are they portable enough ? (I could ask on Monday a Solaris system, but
I do not have bsd and the other flavours of unix)
(Stat is in section 1 of man, part of gnu coreutils, /usr/bin/stat)
Side note: This is fine to install for the local user, but new later
users could benefit also from a ~/.povray/3.7/ subtree ; what about also
filling the /etc/skel (when available) ? (and in /etc/skel, root owner
is fine!)
![](/i/fill.gif) |
