POV-Ray : Newsgroups : povray.beta-test : Picture index out of range. - Fatal error in renderer: Uncategorized error. Server Time
27 Sep 2024 18:27:33 EDT (-0400)
  Picture index out of range. - Fatal error in renderer: Uncategorized error. (Message 1 to 10 of 14)
Subject: Picture index out of range. - Fatal error in renderer: Uncategorized error.
Date: 14 Jan 2012 09:06:04
Message: <4f118bcc$1@news.povray.org>
The following code fails with the following message:
Render failed
The texture scale is relevant.
It does not fail in Pov 3.62
The image map can be downloaded from:
http://www.mmedia.is/~bjj/data/s_rings/sat_ring_color.png
#version 3.7;
global_settings {
  adc_bailout       0.0039
  ambient_light     rgb <1.000,1.000,1.000>
  assumed_gamma     1.00
  irid_wavelength   rgb <0.250,0.180,0.140>
  max_trace_level   5
  number_of_waves   10
  noise_generator   3
  charset           ascii
background { colour rgb <0.000,0.000,0.000> }
#declare Ring_Texture1 =
  uv_mapping
   image_map{
    png "sat_ring_color.png"
    interpolate 2
    map_type 0
   rotate    <90.000,90.000,0.000>
  finish {
   ambient     rgb <0.100,0.100,0.100>
   brilliance  1.000
   crand       0.000
   diffuse     0.600
   metallic    0.000
   phong       0.000
   phong_size  40.000
   specular    0.000
   roughness   0.050
#declare Camera0 =
  perspective
  location <3843.816,38.892,-2660.667>
  up y
  right 1.333*x
  angle 33.000
  sky <-0.004,1.000,0.002>
  look_at < 0.449, 18.943, 0.102 >
}  // end Camera0
disc {  // Disc0
  0,y,4.400000,2.500000
  texture{ Ring_Texture1 }
     scale     <750.000000,750.000000,750.000000>      // Fails 32 bit
//  scale     <800.000000,800.000000,800.000000>      // Fails 64 bit
  // scale     <600.000000,600.000000,600.000000>     // does not fail
  rotate    <0.000000,0.000000,-20.000000>
  translate <-3500.000000,900.000000,900.000000>
}  // end Disc0
camera{ Camera0 }
Regards
Subject: Re: Picture index out of range. - Fatal error in renderer: Uncategorizederror.
Date: 14 Jan 2012 10:02:55
Message: <4f11991f$1@news.povray.org>
> Render failed
Don't know why it passes 3.6 but not 3.7 ... I can verify that it DOES
indeed happen with 3.7. Here's what else I've discovered ... on a lark
since disc primitive doesn't support uv_mapping I commented it out in
texture definition and OK fine. Added uv_mapping statement back in and
changed disc to sphere and it worked ... so it appears to be related to
uv_mapping and disc????
Date: 14 Jan 2012 14:14:38
Message: <4f11d41e$1@news.povray.org>
> Render failed
I can confirm too, it happens with 3.7 binary (win7-64), even when
version is set to 3.6, but not with 3.6.
A tiny shift in the rotation
rotate    <90.000,90.000,0.000> + <0, 1e-14, 0>
fixes this. Perhaps it's something to do with tangents somehow?
Date: 15 Jan 2012 03:38:32
Message: <4f129088@news.povray.org>
Oops! I did not check that.
I get an image if I change the map_type to 1, 2 or 5. At least with
these settings. Incidentally, Bishop3D has a map_type 8 which Hugo
called Parametric. I can see no mention of it in the docs.
Regards
Date: 15 Jan 2012 04:02:59
Message: <4f129643$1@news.povray.org>
> Render failed
Please report this at bugs.povray.org. The mapping falls out of range
internally, which should not happen (or be handled better). It seems like a
coincidence that it occurs only in 3.7 though.
     Thorsten, POV-Team
Date: 15 Jan 2012 09:19:33
Message: <4f12e075$1@news.povray.org>
the parametric object is mentioned in the uv_mapping section of the docs:
http://wiki.povray.org/content/Documentation:Reference_Section_5.2#Supported_Objects
however in the map_type section is does not:
http://wiki.povray.org/content/Documentation:Reference_Section_5.6#The_map_type_Option
I tried map_type 8 and it parsed ok fine ... but get this I also tried
map_type 10 then map_type 100 and those BOTH parsed as well!!!
A separate bug from what you've uncovered???
Also if someone else on the team could provide a clue as to what the
map_type 8 narrative should say, I'll make that change.
On a separate note ... Christoph posted a fix for parametric uv_mapping
back in June of last year, that will roll with RC4
http://bugs.povray.org/task/210?project=2&order=id&sort=desc
Date: 15 Jan 2012 10:00:02
Message: <4f12e9f2@news.povray.org>
added bug report for this:
http://bugs.povray.org/task/232?project=2&order=id&sort=desc
@Stephen: I'll leave the other bug report for you to follow up
Date: 15 Jan 2012 10:41:25
Message: <4f12f3a5@news.povray.org>
>> Render failed
> like a coincidence that it occurs only in 3.7 though.
> Thorsten, POV-Team
Thanks and done:
FS#233 - Picture index out of range. - Fatal error in renderer:
There seems to be a formatting error, comment "//" has been removed and
there are two scales in the texture not commented out.
Regards
Date: 15 Jan 2012 10:49:09
Message: <4f12f575@news.povray.org>
Done after a struggle :-)
Regards
Date: 15 Jan 2012 16:20:12
Message: <4f13430c@news.povray.org>
Am 15.01.2012 20:13, schrieb bart:
>> Render failed
The root cause has been identified by now; it only shows when a ray
happens to hit the image map extremely close to the image border (about
a trillionth (1e-12) of a pixel off in this case), and is due to
precision issues apparently not considered by the original code author.
