POV-Ray : Newsgroups : povray.beta-test : Picture index out of range. - Fatal error in renderer: Uncategorized error. Server Time
25 Apr 2026 18:10:04 EDT (-0400)
  Picture index out of range. - Fatal error in renderer: Uncategorized error. (Message 11 to 14 of 14)
Subject: Re: Picture index out of range. - Fatal error in renderer: Uncategorizederror.
Date: 16 Jan 2012 05:52:01
Message: <4f140151@news.povray.org>
Le 15/01/2012 22:20, clipka a écrit :
> The root cause has been identified by now; it only shows when a ray
> happens to hit the image map extremely close to the image border (about
> a trillionth (1e-12) of a pixel off in this case), and is due to
> precision issues apparently not considered by the original code author.
I guess it's yet another case of computer ending with mathematically
impossible result, like computing the dot product of two unit vectors
and being aware that the result might indeed be bigger than 1, before
trying to compute the arccos of the result to get the value of the
angle. It should not happen... and yet it does in a very few cases.
Good detective work then, dear Clipka!
Date: 22 Jun 2012 08:35:58
Message: <4fe466ae$1@news.povray.org>
After installing RC6 I am still getting the same error.
Below is a link to the scene rendered with one thread. You can see that
the render fails before the block reaches the image border. For
comparison I have included a link to the scene rendered with eight threads.
1 thread
http://imgur.com/8BG0X
8 threads
http://imgur.com/HTldu
Code:
#version 3.7;
global_settings {
  adc_bailout       0.0039
  ambient_light     rgb <1.000,1.000,1.000>
  assumed_gamma     1.00
  irid_wavelength   rgb <0.250,0.180,0.140>
  max_trace_level   5
  number_of_waves   10
  noise_generator   3
  charset           ascii
background { colour rgb <0.000,0.000,0.000> }
#declare Ring_Texture1 =
  uv_mapping
   image_map{
    png "sat_ring_color.png"
    interpolate 2
    map_type 0
   rotate    <90.000,90.000,0.000>
  finish {
   ambient     rgb <0.100,0.100,0.100> *5
   brilliance  1.000
   crand       0.000
   diffuse     0.600
   metallic    0.000
   phong       0.000
   phong_size  40.000
   specular    0.000
   roughness   0.050
#declare Camera0 =
  perspective
  location <3843.816,38.892,-2660.667>
  up y
  right 1.333*x
  angle 33.000
  sky <-0.004,1.000,0.002>
  look_at < 0.449, 18.943, 0.102 >
}  // end Camera0
disc {  // Disc0
  0,y,4.400000,2.500000
  texture{ Ring_Texture1 }
     scale     <750.000000,750.000000,750.000000>
  rotate    <0.000000,0.000000,-20.000000>
  translate <-3500.000000,900.000000,900.000000>
}  // end Disc0
camera{ Camera0 }
Regards
Date: 22 Jun 2012 11:01:57
Message: <4fe488e5$1@news.povray.org>
Am 22.06.2012 14:35, schrieb Stephen:
Yes; this issue accidently "fell off the bench" and didn't get picked up
again until just after RC6 had been built. Sorry for that, my bad.
Date: 22 Jun 2012 14:54:17
Message: <4fe4bf59$1@news.povray.org>
No worries on my part. I made up a colour map that looks better imo.
Regards
