POV-Ray : Newsgroups : povray.beta-test : Version 3.6 flag and SSLT Server Time
29 Mar 2026 00:19:04 EDT (-0400)
  Version 3.6 flag and SSLT (Message 1 to 4 of 4)
Subject: Version 3.6 flag and SSLT
Date: 12 Feb 2011 14:10:27
Message: <4d56db23@news.povray.org>
I rendered a scene with SSLT but forgot to add #version 3.7 to the
scene. It rendered fine with little difference between them, just noise
on the Mesh. There was no warning about the version, should there be?
I re-rendered the #version 3.7 again and there are differences on all
the images as if I was using crand. Does it matter which noise generator
you use. I was using Perlin.
Regards
Subject: Re: Version 3.6 flag and SSLT
Date: 12 Feb 2011 17:36:22
Message: <4d570b66$1@news.povray.org>
At higher aa settings it is hardly noticeable.
Regards
Date: 12 Feb 2011 20:29:52
Message: <4d573410$1@news.povray.org>
Am 12.02.2011 20:10, schrieb Stephen:
As a general rule-of-thumb, the #version setting only affects /changed/
features (that would otherwise break backward compatibility), not new ones.
No, the Perlin-alike-noise generator used for patterns (e.g. bozo) and
turbulence (which is always Perlin-alike) has nothing to do with it;
SSLT doesn't need a 3D random pattern - just a stream of pseudo-random
numbers and vectors.
The difference in the noise is simply due to differences in the order in
which pixels are rendered. In POV-Ray 3.6 that's line-by-line, and in
POV-Ray 3.7 it's block-by-block (with the order of blocks being somewhat
arbitrary due to the use of multiple parallel threads, making results
differ even from render to render).
Date: 13 Feb 2011 07:44:19
Message: <4d57d223@news.povray.org>
That is good to know.
Again, good to know.
That makes sense as when comparing different rendering of the same
scene, some blocks are identical.
Thanks for your reply/
Regards
